Results 1 to 3 of 3
    Aug 2017
    Frame Swap Help!
    I currently have a 2015 Diamondback Sync'r Pro (hardtail) but I've come across the frame of a 2015 Diamondback Mission 2 (Full sus).
    I've tried getting in contact with DB but theyve been super slow for some reason and I need to give the seller an answer soon! From what I've researched, It looks like all the components from my Sync'r will swap just fine to the Mission 2.
    Can anyone else verify that everything will swap properly? I still consider myself a beginner mtb'r when it comes to these things!
    Diamondback Sync'r Pro Specs
    https://www.sethsbikehacks.com/produ...ack-syncr-pro/
    Diamondback Mission 2 Specs
    https://www.sethsbikehacks.com/produ...ack-mission-2/
    Thanks!!
    Jul 2017
    Frame Swap Help!
    Your wheels are incompatible. The mission uses the older 12x142mm while the syncír is using the 12x148mm Boost standard. Rear axle standards are different as well.
    Also, the forks have 30mm difference in travel.
    Reputation: White7's Avatar
    Feb 2015
    Frame swaps are never as cheap as you think they're gonna be
  1. Replies: 1
    Last Post: 10-23-2013, 07:04 AM
  2. Replies: 7
    Last Post: 11-07-2012, 08:05 AM
  3. Replies: 442
    Last Post: 01-09-2012, 10:40 AM
  4. Wheel Swap... Chain Swap Too?
    By coopdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2011, 05:49 AM
  5. Frame swap: Want to swap my geared frame for your SS
    By bikewrench in forum 29er Bikes
    Last Post: 02-01-2011, 12:03 PM
Members who have read this thread: 33
