Results 1 to 30 of 30
    Uncle
    Reputation: Entrenador's Avatar
    The frame I want
    It's not a complete bike. It doesn't have pivots or a shock. It's not titanium or carbon. It's not under 3lbs. It's not $1000 or more.
    It's just a plain ol' beer can Santa Cruz Chameleon with appropriately spec'ed 650b swapouts.
    Is that really too much to ask?
    PS - Anyone have this frame in their shop, and happen to have a rear 650b wheel laying around? It seems pretty burly, so perhaps a legit 2.2" rear 650b would fit?
    Every rose has it's thorn.
    enjoy the ear worm
    NedwannaB
    Reputation: JMac47's Avatar
    Pretty sure it's tight fit
    Quote Originally Posted by Entrenador View Post
    http://www.speedgoat.com/images/products/P-20134-4.jpg
    Although in the pic the upper seat stays look plenty big. Don't they have the horz sliding dropouts for runnung it SS, similar to the HighBalls?
    Wait whuuut, who did he tell you that!?!?....
    Uncle
    Yeah, same dropouts as the Highball, but I'm hoping to use a derailleur as my B-rig will be shifter enabled.
    enjoy the ear worm
    NedwannaB
    B rig?
    Sep 2012
    boise craigs lists had one check it out
    Reputation: veteran_youth's Avatar
    Nov 2006
    CONFIRMED FIT!
    L frame, RaRa 2.25, Pacenti TL28, almost 1cm clearance in every direction.
    Uncle
    post photos please
    Any chance you can snap some pictures? RaRa 2.25 isn't a huge tire, but if there's a full cm in each direction, then it should play nicely with the equivalent nobby nics, or something with a bit more volume (2.4 Nic maybe in the future?).
    Thanks for checking into it.
    enjoy the ear worm
    Uncle
    [Not] Discontinued for 2013.
    I don't see this bike or frame on their site anymore. Not a big enough market I guess?
    [edit] It comes up in a Google search, but if I go directly to SC's site it doesn't come up. Hmmm...
    [edit again] Was using my netbook and for some reason the far right hard tail tab doesn't appear, lol. Glad its still a go.
    enjoy the ear worm
    Reputation: Morpheous's Avatar
    Mar 2006
    Good job!
    Check the "store" frame clearance page on SC bicycles..They are on sale! $350.00 all sizes in orange and gloss black....click to it below.. Your wish can come true!
    Santa Cruz Bicycles
    2015 Budnitz MTB Ti Limited 650B
    2015 Surly Instigator 2.0 26+/27.5+
    Uncle
    Quote Originally Posted by Morpheous View Post
    Santa Cruz Bicycles
    Ah, close! But that's the previous generation. Newer model has a 1* slacker head tube angle and takes a tapered steer tube (for the fork I already have).
    enjoy the ear worm
    Mar 2006
    Cane Creek Angleset may well fix that....
    Nov 2006
    FWIW i was just on the SC site and the Chameleon is still there, far right under the 'Hardtails' tab.
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    What did the BB height become?
    Awesome find! I added it to the Google Drive list!
    follow it here: 650B Fit List
    Nov 2006
    To be honest, the SC bikes come partially assembled so the 1st thing I did was put it in the stand and jam the 650 wheel in to get the pic. But I then built it up with the rest of the stock R kit. If I get a chance in the near future I will measure it B'd out. Did measure the CS length with geared dropouts, I got about 16.75 axle to BB centre, not sure if SC measures horizontal for their geo chart or if it is just longer than claimed.
    I will also mention that the ultramarine colour is a lot darker in person than I thought it would be from the other pics I saw on MTBR. Pretty darn close to the 2012/2013 Tallboy C.
    Uncle
    Quote Originally Posted by veteran_youth View Post
    Man, this is great news! Stock, the BB height is listed at 12.4" with 491mm A-C (120mm fork I guess). I'm also interested in what BB height number you get, even if you just build it with the stock 26" wheels - we can figure it out from there easily enough. If the static BB height is 13" or just under that with 650b wheels, it should sit in a good range when weighted, no? I'm also considering 100mm fork with 650b wheels on this bike: ~69/73 should ride pretty good I'd think. But since you found some variation in the CS length, I'm going to wait for your BB numbers before pursuing this frame.
    enjoy the ear worm
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Also the simpler less expensive Works Components angled headset
    http://www.workscomponents.co.uk/
    Old enough to know better. And old enough not to care. Best age to be.
    NedwannaB
    100?
    Seems like this bike would warrant the 120-130 it's designed for, 650 or 26, no??
    Uncle
    Quote Originally Posted by JMac47 View Post
    I certainly would try it at 120mm first, and as long as I could climb efficiently on it, I'd leave it that way. To date, my best bikes riding (both climbing and descending) have shared a ~73* STA & a BB height in the low 12s. So I'm staying open to the idea of a 100mm fork to help find a position that stays close to these numbers. I suspect it would still handle very well at 100mm, for my purposes anyway.
    enjoy the ear worm
    Nov 2006
    Looks like 12.4 is pretty accurate +/- 0.1", and just under 13" B'd out. Most impressive though, is that my not particularly weight weenie 650 wheels (Hope/Pacenti TL28/DB spokes/RaRa tubeless) took 3 full pounds off the stock weight! 25.26 w/o pedals ain't bad with cheap/burly cockpit parts! Got some more crappy iphone pics will hopefully upload tonite.
    A waste of time it is is
    Reputation: emu26's Avatar
    Quote Originally Posted by Cracked Headtube View Post
    Nice looking spreadsheet, haven't seen that one before but I'm guessing by the dates it is a fairly new thing?
    Is it possible to add a column to it that has a link to where the info came from? This would allow people to click on the link and then see pics or whatever other relevant info the original poster has included that isn't able to be included in this document.
    Nice work CH.
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Awesome
    Better to have and not need it, than to need it and not have it.
    JRR
    JRR is offline
    Anyone have pics with a nice size 650b in back with ss sliders moved all the way back? The geometry on this frame looks like it would make for a great bike with 100mm 650 fork and 650 or 26 rear. Thinking about picking up a frame and building it up as 26 with a 140mm fork since I have parts allready which looks like it would be fun too. Then converting the front to 650 and 100mm fork
    Uncle
    Bump - Anyone riding a Chameleon on B-wheels and loving it?
    enjoy the ear worm
    Nov 2006
    Started putting a few miles on mine but winter isn't going away so they have been mostly (snowy) path and road rides, therefore can't give any real good feedback yet. Can definitely feel the slack HTA with a 120 fork though, and BB does feel high when I put a foot down at a stop. Lowering the fork would definitely improve both of these issues but I would like to see how it handles off-road like this before switching it up.
    May 2005
    Sweet frame and my only real concern (not having any HT experience) is the aluminum ride vs a steel HT. #'s look really good, especially the New England friendly near 13" BB height after converting to 650B wheels. I was really interested in the new Kona but the BB height is something I'm not willing to deal with in the endless rocks we have here. Is the aluminum ride that much more harsh than steel for those in the know?
    2013 Banshee Spitfire V2 650b
    NedwannaB
    Quote Originally Posted by skidad View Post
    Having been on both materials riding 15-16" hardtail frames, I'd say with proper sized tires/tubeless, and same seatpost and bar setup the ride is marginally negligible. In otherwords, not much difference. I guess it's possible to get a smoother ride out of steel with larger frames where the "give" would be more apparent due to the increased tube lengths. But I'm just throwing that theory out to cover my own experience.
    Uncle
    Sweet frame and my only real concern (not having any HT experience) is the aluminum ride vs a steel HT... Is the aluminum ride that much more harsh than steel for those in the know?
    I've had steel frames with skinny tubes & longer stays that felt smoother, less jarring. I currently have two hardtails that feel fairly stiff in the back end; One is steel, one is aluminum.
    I agree with Jmac: Material alone will not determine harshness of ride all that much, compared to other things like frame design, and more importantly what tires and pressure you run. Both of my hardtails were much more comfortable with a Kenda 2.2 rear tire than with other tires. Why? Because I've been able to run them tubeless with ~23psi. They're a bit heavier than race-weight tires, but they perform/tolerate under-inflated use better than other tires I've tried so far. In my limited experience, this detail has been the biggest determinant of how harsh a bike will feel (outside of fork tuning).
    enjoy the ear worm
    Uncle
    VY, thanks for posting again. Question: Which Fox fork is that one - travel, A-C, 650b specific or 26"?
    Also, is that shot next to the tunnel on 101?
    Cheers.
    enjoy the ear worm
    NedwannaB
    They have a 101 across the border in Canada~?
    Nov 2006
    Cheers.
    The fork is the 26" F32 RLC fit from a 2012 SPX kit. Air out has a few mms clearance. Not sure about A-C but it is set @ 120mm.
    And the pic is the tunnel visible from the Don Valley Pkwy just south of Lawrence Ave. in Toronto. (The DVP turns into Hwy 404 a few kms north of there, maybe that's what you are thinking of?) The rainbow paint job is actually looking pretty fresh right now. They are paving some paths through there and cleaning the area up. I remember first finding my way there years back and thinking "this place is littered with a lot more broken glass and graffiti than I imagined it would be".
