Results 1 to 10 of 10
    Fox 34 160 26 and hans damph 27.5
    Anyone tried this for clearence?
    Dec 2010
    Should work,ran them on my 36 and now have High Roller II 2.4's no problem.
    Dec 2009
    Quote Originally Posted by techfersure View Post
    Was that a F36 or F34. I thought there was no clearance on the F34's?
    After info on the 34's...
    Reputation: reformed roadie's Avatar
    If there is enough clearance for a 2.3 HR2 on a 26" Fox 32 (which I currently have), I have to assume that you should be good on the 26" 34. The 27.5 34 has massive amounts of clearance with large tires.
    Two things I'd like to know: the difference in offset between the 26" and 27.5 34s and if there is any way to reduce the travel to 140 or 130 mm.
    I am Doctor Remulak
    Reputation: AZ Mikey's Avatar
    It fits. I have a 27.5x2.35 HD on my 26" 34 right now.
    Quote Originally Posted by AZ Mikey View Post
    Thanks mate, much clearence? Bow wide are your rims?
    Do you have high roller 2's 650b in yout 26 fox 32 fork?
    tried a 2.35 650b hans dampf in my fox 34's and it were rubbed the arch on the lowers.
    Hmmmm interesting...
    Any tyres that did fit?
    Was it a '13' or '14' fork?
  1. Hans Dampf 2.35 on an HD
    By clubby in forum Ibis
    Last Post: 05-08-2013, 11:13 AM
  2. Hans - you know you want to help (again!)
    By mojo_man in forum Ibis
    Last Post: 04-03-2013, 01:36 AM
  3. Question for Hans.
    By saidrick in forum Ibis
    Last Post: 01-10-2013, 09:31 AM
  4. Hans Damph or Exvacator
    By Joe76LJC in forum Wheels and Tires
    Last Post: 11-20-2011, 08:34 AM
  5. Hans Dampf
    By BikerX22 in forum Wheels and Tires
    Last Post: 05-26-2011, 10:03 AM
