Results 1 to 3 of 3
    Oct 2013
    DB Release 3 Shock
    So I just finally got my Release 3 last week and got it Tubeless today and tuned the fork and shock.
    70 psi fork
    195 psi shock
    I am 172lbs
    I read and watched videos that say you should have about 80-90% in the fork and 90% in the shock when putting full force (bouncing has hard as you can) into the bike.
    After doing some super small jumps in the parking lot I have these images and was curious if I need more PSI in the shock.
    https://imgur.com/rYAmxHN
    https://imgur.com/fBwe9qM
    Apr 2018
    Quote Originally Posted by Gedemer View Post
    70 psi fork
    195 psi shock
    I am 172lbs
    My advice would be to find the actuall end of travel by letting air out until you can gently bottom out the suspension. Then you have a real number for 100% making it much more accurate to find real sag and compressed percentages.
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    I have a Mission 2.0 with a Fox 36. I have found the pressure recommendations for pressure to be on the high side compared to recommended sag. Based on your pictures I would reduce fork pressure by 5#'s. I have also found the pressure recommendations for the rear shock to be a little low. Looks like you are close to blowing thru the travel on the rear. I would increase the rear pressure by about 10#'s. That should even everything out
  1. How difficult to transition from Shimano multi release to single release?
    By legitposter in forum Apparel and Protection
    Last Post: 10-17-2016, 07:46 PM
  2. Replies: 4
    Last Post: 07-14-2016, 12:53 PM
  3. Replies: 13
    Last Post: 05-09-2016, 10:59 AM
  4. Replies: 3
    Last Post: 04-28-2014, 01:20 PM
  5. Replies: 2
    Last Post: 03-24-2014, 09:37 PM
Members who have read this thread: 28
