Results 1 to 52 of 52
    www.lugoftheirish.com
    Sep 2004
    Custom 650b frame
    So I have a set of the Sun Charger 650b wheels and a set of Kirk's Neo Motos so I suppose it is time to start doing something with them. The Ventana 650b 4" travel rear assembly should be here in a couple of weeks so in the meantime I started cutting up some tubes and seeing what's what. Still a lot to do but not bad headway for an afternoon.
    Shamrock Cycles- Hand built frames from the mountains of Indiana.
    Reputation: MMcG's Avatar
    Jul 2003
    Going to spec a White Brothers 650b specific fork for it?
    Sep 2004
    In an ideal world, yes. But, without knowing the A-C length for the WB 650b specific, I used a Fox 130mm fork as specs. I have one in the shop and it works with the 650b wheels.
    Very cool, will be neat to see this built up. I was just checking out your site. I build old cars and eco-friendly 4WDs for a hobby with a lot of metal work... Since I recently got obsessed with MTB about a year ago and have been exploring frame building and have always loved geometry, the only math class I always got A's in I have a feeling someday maybe later in my life when I am retired or something like that (I'm only 29) I'll get into frame building, if I am patient enough to resist getting into it now. This gentleman recently moved to and is planning to set up shop in the neighboring town where my vehicle building shop is. http://www.edwincycles.com/ We have a pretty good collection of welders and metal guys who are all great interesting guys and do killer work, hopefully we can get hgim plugged in an I can hopefully resist the tempation for some custom frames...
    Jul 2003
    Get her finished before St. Patrick's day!
    Can't wait to see the finished product.
    Sep 2004
    St. Patrick's Day might be a tall order. Largely depends upon when the rear assembly darkens my door.
    Jul 2003
    Quote Originally Posted by Loretta
    What will your HT angle be with the 130mm Fox? And will you run it as 5" in front and 4" in back with the Ventana rear end?
    Sep 2004
    The A-C length I used was 490mm and 20% sag of 130mm of travel. That gives me a 70 degree head angle. 4" travel in the rear.
    Jul 2003
    Should be nice! what tubing are you utilizing for the front triangle?
    Sep 2004
    Pacenti HM 31.8 ST, Zona 31.8 TT , Deda 38mm 9/6/9 DT. External sleeving on the ST along with ample gusseting at the DT/HT junction.
    Not sure what the total frame weight will be but it will be somewhere between 4 and 12 pounds.
    Jul 2003
    4.5 pounds for the whole frame or just the front triangle portion? If that's for the whole fame - Amazingly awesome!!
    Sep 2004
    Actually that was a joke. Frame weight will probably fall in the 6.5 to 7 pound range. Just a hunch.
    Sail On!
    Reputation: Waterat Pat's Avatar
    Sure would be great if we could see some more work in progress pix.
    Sep 2004
    Probably won't do a whole lot more to it until the rear assembly arrives but I will take plenty of photos of the build along the way. I can also take some more pics of what I have so far and post them up.
    "4-12 lbs, should hopefully be somewhere in this range"
    Sep 2004
    Got a call from Theresa over at Ventana to let me know my 650b rear assembly will be here tomorrow. Hoping to make some headway on the frame over the weekend and will report back after that. I'll take plenty of pics along the way.
    The 650B 130mm WB fork is within 10mm A-to-C lenght of a 130 Fox.
    Sep 2004
    The downside to the WB 130 fork is that it is only available in thru-axle and my Charger wheels are QR hubs.
    If you call and order direct they should be able to do QR for you. Takes a few weeks though...
    Sep 2004
    Update. I ended up going for the 5" travel option and changing the frame angles. Head tube is 70.5 degrees and seat tube is 73 degrees.
    Lower pivot
    Rocker arm pivot and gusset
    Full frame mock-up
    Jul 2003
    Lookin good!
    San Diego County
    Reputation: Duzitall's Avatar
    Nice garage Tim. Gonna be good to see the finished product Thanks for sharing the construction picts.
    Quote Originally Posted by turnerbikes View Post
    Of course the easiest way to fix this is to go for a hike.
    DT
    Sep 2004
    Brazed up the seat tube pivot mount to the gusset. Now all that is left is to braze this onto the seat tube, add the lower shock mount, braze in the top tube, file and clean up the fillets, paint, and build it and ride it.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    I'm just curious on your choice of the 70.5 HA for a 5" bike. I have no doubt your preference was well thought out here, but when more manufacturers are generally going slacker on 5" and longer travel bikes, 70.5 seemed a little steep. What wheelbase do you think you'll end up with, and what's the chainstay length with the provided swingarm? The setup looks very well done, and I'm impressed with anyone who can roll their own.
    Sep 2004
    Agreed that the head angle is a little steeper than other 26" bikes but this is something of a "beta" bike and I wanted to try a head angle somewhere between my 29er and 26". I want something that will perform in Pisgah but much of the riding around here in Indy doesn't really call for a slacked out 5" travel bike. So I wanted something that could serve a little bit of double duty. This should give a trail of ~79mm but if I don't like the way it rides then I'll tear it apart and build another one.
    Also, wheelbase is 44". Chainstay is 17.45"
    Sep 2004
    Frame is all brazed up and is almost finished. Still need to braze in the lower shock mount and the headtube reinforcements. Then it is time for clean up and paint.
    Sep 2004
    Finished up the frame and did a bit of mock up to make sure that everything is as it should be. It is. Tomorrow I'll finish up the filing and it is off to the painters.
    It's looking good
    While it's off to paint, how about a list of of the motorcycles in the shop?
    Sep 2004
    1973 Honda CL350. Quite caff'd out. Stripped it to the frame and started from scratch. Too much fabricating and welding to ever get my money back out of it. Looks cool but is uncomfortable as hell. Sounds like it is screaming by you at 100 miles per hour but is more bark than bite.
    1971 Norton Commando 750. Spent a winter putting Humpty Dumpty back together. Rather proud of it and is a long-term hold.
    2005 Triumph Thruxton. It's a Thruxton. Not much to mention. I punted a 66 Bonnie a couple of years ago and bought it. It is fun and won't get you into too much trouble. Removed rear fender, painted to match front fender, bar end mirrors, new pipes, etc. Mostly off the shelf stuff that anyone with a Visa card and a mailing address can accomplish. Going up for sale next week.
    2007 Ducati Sport1000 SE- #82 of 100 that exist in the world. Basically, a standard Duc Sport 1000 Monoposto with a different pant job. Different pipes and a fender elimination kit. Other than that, it's bone stock. Easily the most fun to ride.
    Sep 2004
    COMPLETE!
    Built it up and took it for a small ride tonight. Shamrock Cycles 650b frame. Ventana 5" rear assembly. Frame weight (including shock) is right at 8lbs and total bike weight is 30.1lbs. Not exactly featherweight but . . .
    Gonna earn its stripes at PMBAR this weekend.
    For the benefit of the fashion police, yes, the blue zip ties are temporary. I ran out of black.
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Well done!
    COMPLETE!
    Looking forward to the full report next week!
    If you like my products and services tell everyone. If you don't, tell me - kirk(at)pacenticycledesign.com
    Very Very sweet!
    Looking forward to the ride report from Pisgah.
    Jul 2003
    Nice work! Is that dark blue or black paint? It looks dark blue to my eyes and if so - nice choice!!!
    Let us know about those wheels ASAP.
    Sep 2004
    It is dark pearl blue. A friend of mine here in town (Mike Corby at Corby Concepts) does a whole lot of helmet and equipment painting for the motor racing teams (Indy, MotoGP, cart racing, etc.) He does phenomenal work. He had to paint bikes and helmets for the Red Bull racing team and ordered gallons and gallons of Red Bull blue, red, white, etc. The tint on the blue was slightly off (apparently Red Bull Europe and Red Bull North America use slightly different colors) so my guy at the paint store has gallons of dark metallic blue with nothing he can do with it. It's good to have these kind of contacts.
    Jul 2003
    Awesome - that's my favorite paint color for mtbs!
    Are the celtic knot emblems on the frame stickers?
    I dig the Shamrock on the steat tube/top tube brace!
    Mighty nice!!!!!
    Reputation: SteveF's Avatar
    Wow, that looks good. If you're comfortable posting a ballpark number on a public forum, what would you say you'd sell such a set up for? (custom frame w/Ventana rear and rear shock) Not to putcha on the spot but that there bike looks a lot like what I see when I close my eyes and think about what my 650b-ike will look like.
    Sep 2004
    SteveF,
    Not sure this is the place for throwing out numbers. Email me and we can discuss one on one.
    tim -at- lugoftheirish -dot- com
    Sep 2004
    Quote Originally Posted by MMcG
    Mighty nice!!!!!
    Thanks man. Yes, the celtic knots are decals and are buried under the clearcoat. They are a whisper on the thick side so they are handsanded and then a second application of clear is laid on.
    SteveF,
    I can certainly understand that--I'm not in a hurry to take the plunge (going to pay my car off first) but I'll be interested in your impressions once you get some miles on it, and I'm going to keep you on my short list!
    Nice work...very!
    Sep 2004
    So I got in a 2.5 hour shake down ride on the 650b tonight down in Brown County State Park.
    Short answer, I love it. My thoughts are these, and they are subject to change as I log more time on the bike.
    -It has been about a year since I have ridden a full suspension bike so I had to re-learn a few things.
    -The bike acts much more like a 26" bike than it does a 29er.
    -Spin-up issues are reduced, compared to a 29er.
    -Certain rock features that normally I am forced to muscle a 26" up and through felt smoother and I was able to roll them.
    -A couple of sections that are notorious for snagging front wheels and sending you ass over teakettle did not present an issue.
    -Flickability is more akin to a 26" bike.
    -The higher bottom bracket makes easy work of rock lifts and pedaling through corners.
    -It doesn't feel like I am getting all of the shock travel, which is more of a shock fine tuning issue.
    -Fantastic traction with the Neo Motos but I am running the tires with a bit higher psi (about 38 lbs) because I am using Stan's rim strips so I don't have a tube to help keep the sidewall stiffer.
    -Ultimately the bike with the 650's feels a bit more sure-footed than a 26". The differences are subtle but they are most certainly present. The upsides versus a 26" outweigh the downsides versus a 29er.
    -Will it replace my 29er? No. Will it replace my 26"? You bet your sweet bippy.
    Next stop, Asheville.
    Jul 2003
    Loretta - your 29er is a hardtail yes?
    Would this be your prefered FS ride vs say a FS 29er?
    And can you comment on the charger rims and hubs??
    Sep 2004
    Yes, the Galway is a 29er hardtail. For most XC racing in the area the 29er will still be my bike of choice. But, for all-mountain type riding the 650 takes the cake.
    The Sun Chargers/ Pacenti Neo Motos are quite nice. I am running a Stan's strip in them so I have the tire pressure a bit higher (by about 5psi) to compensate for not having a tube to aid in sidewall stiffness. Don't get me wrong, the tires are beefy as hell, I just have to gradually ease into a tire moving about on the rim. Sort of like easing into a bathtub. You have to do it slowly but it feels nice once your there.
    I get noticiably less wheel flex out of the Sun Chargers than I do on my Industry Nine 29er wheels. I imagine if I went to the thru-axle on the Sun wheels I would notice it even more.
    Jul 2003
    Thanks for the scoop. Are these Chargers currently available as wheelsets or are yours an early release for testing and whatnot?
    Sep 2004
    You would probably have to give Hayes a call direct to see when they are releasing the Sun Chargers. maybe they already have but if you go to their website there is no mention of them.
    I bought mine as a wheelset. Since Hayes owns Wheelsmith they have them build up their wheels.
    So...how did the 650b do at PMBAR?
    Sep 2004
    Performed flawlessly. Nary a skipped chain throughout the entire race. 2.5 hour at Dupont on Friday and 9 hours on race day. We finished 34th out of 76 teams.
    My initial thoughts were reinforced. The bike behaves much more like a 26" than a 29er. The tires were perfect for the conditions. Tons of rocks, roots, techy type stuff that the bike just rolled. The climbing seemed to be just fine but I never really pushed it on the climbs.
    Jul 2003
    Good stuff. Curious - how much does your bike weigh?
    I rode a 29er last night - rigid and loved the lightweight aspect of it. I'm not sure I could go back to a really heavy FS bike. One of the guys riding with us has a gorgeous Morewood Mbuzi with a Fox Talas up front - I bet it rides sweet, but man was I surprised at how heavy the front end was.
    Perhaps that is on a different spectrum than your 650b FS bike - so I'm curious about the weight. Is is sub 30?
    Sep 2004
    It is sub-30 but just barely. By just barely I mean on my digital scale the bike comes in a 29.94lbs. That is in "ready to ride" condition (pedals, bottle cage, etc).
    Jul 2003
    Not too shabby.
    I really need to try the 650b as a front wheel.
    Anyone in CT have one I could borrow?
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    Mark, do you need a QR or 20 or 24mm?
    Aug 2005
    my experiences so far have been similar. i've had 2 rides so far on 650b's and the bike handles very similar as when outfitted with 26" wheels. the one area i expected to notice a negative difference was in the slow speed tight and twisty stuff. while i have noticed a difference it's actually been an improvement. the bike actually feels more stable at slow speeds when turning back on itself.
    since my ride was built for 26" wheels the bottom bracket is higher by .75" and it's noticeable. not a bad thing, just a difference to get used to.
    overall the combination of bigger wheels, neo moto's and going tubeless gets 2 thumbs up from me.
    Jul 2003
    Quote Originally Posted by Cracked Headtube
    Quick Release!
