    Feb 2018
    Calling the 1x conversion gurus ...
    So I have a 2015 Giant Reign 2 and an 09 specialised FSR XC and am looking to convert them both to 1x
    The reign is 2x10, shimano Deore crank (104BCD) & shimano deore slx + shadow rear derailer
    The specialised is 3x9, shimano crank & shimano deore slx shadow rear derailer
    The specialised won't index right after putting on a new SRAM chain. On the stand it does and shifts nicely but under load it keeps skipping in the middle of the rear casette no matter what I do.
    6+hrs of mucking around and im over it, so looking to convert both to 1x.
    The Reign I'm undecided on wether I'll go 1x11 or 12 and whatever is left over from the reign I'll use on the specialised so it'll be a 1x10 on the specialised using the old reign casette new sunrace casette on the Giant
    Can I get away using both derailers by winding the b tension screw on both of these to acommodate one extra gear? If so I'll stick with 1x11 on the reign. If not I'll go 1x12 on the giant and get a new derailer for it. Then put 1x10 casette and derailer on the specialised.
    I assume neither of these will need new freewheel hubs ?
    Reputation: MSU Alum's Avatar
    Often, skipping on the middle of the cassette is the sign of a bent derailleur hanger. Regardless of what you do on the front, you may want to check that, if you haven't already.
    You will need new derailleurs and chains to go up from 9 speed.
    Oct 2013
    ^^This and use this series to figure out what you need
    https://www.youtube.com/watch?v=NCEW290pJ9c
    2019 Yeti SB100
    2016 Transition Smuggler
    Dec 2014
    It's a good bet the cassette and/or chain ring are worn so the new chain skips.
    oops I wasn't clipped in
  1. Replies: 6
    Last Post: 05-20-2014, 08:37 PM
  2. Replies: 0
    Last Post: 05-31-2012, 10:27 AM
  3. Calling TALAS gurus!
    By agoura_biker in forum Shocks and Suspension
    Last Post: 06-26-2011, 01:30 PM
  4. Calling all Manitou Gurus: help with Nixon 160 "Ride Kits"
    By Tim Blabbing in forum Shocks and Suspension
    Last Post: 04-29-2011, 10:37 PM
  5. Calling all Manitou Gurus: Nixon/Sherman help
    Last Post: 04-04-2011, 08:43 AM
Members who have read this thread: 13
