Results 1 to 8 of 8
    Reputation: SIX36's Avatar
    Dec 2013
    Advice needed converting 2x10 to 1x10 (Beginner)
    I want to change from 2x10 to 1x10 on my Remedy 9 with Deore XT 38/24
    Was thinking of going to a single ring 34 would this be too big for short climbs?
    NedwannaB
    Reputation: JMac47's Avatar
    Beginner advice, checkout drivetrain forum, there's a few threads with your setup there. As for what "you" can do with a single ring is relevant to your conditioning and trail conditions etc.
    Wait whuuut, who did he tell you that!?!?....
    Quote Originally Posted by SIX36 View Post
    34 ring x 36 cog falls between a 24 ring and your 24/28 cogs, so on your next ride, stay in these gears on a climb and see how it works for you. Then you'll know if 1x10 will work for you before you spend any money.
    Just keep in mind the 28 will be easier and the 24 harder that you lowest 1x10 gear you'd have if you switch.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Reputation: madsedan's Avatar
    Aug 2010
    Replace the 34t with a 32t no-drop or narrow/wide ring.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    NedwannaB
    Keep in mind you'll be fiddling abit to get chain line worked out switching it from a 2x than you will from a 3x.
    Reputation: vikb's Avatar
    Go with a 32T unless your rides are short and you are quite strong. 32T x 36T is a reasonable gear for long rides with some decent climbing.
    Just replace the 38T and leave everything else in place for now so you can test the waters. Once you are happy you can strip the derailleur and granny.
    Safe riding,
    Vik
    www.vikapproved.com
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    What is wrong with your 2x10 setup?
    Quote Originally Posted by moefosho View Post
    Yeah, if you don't know what gears you'll need for long climbs doesn't it make sense to ride the current gears and find out?
  1. Replies: 29
    Last Post: 02-25-2014, 08:08 AM
  2. converting 2x10 to 1x10
    By Geaux'nRide in forum Specialized
    Last Post: 06-08-2013, 10:52 AM
  3. New Build: Start with either 3X10 or 2X10 for converting to 1X10?
    By marc927 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2013, 07:29 PM
  4. Converting 2x10 Sram to 1x10 bashguard?
    By bigdog100 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-26-2012, 10:53 AM
  5. Converting Stumpy EVO 29 1x10 to 2x10
    By imero in forum Specialized
    Last Post: 02-22-2012, 03:44 PM
