Results 1 to 35 of 35
    Binned
    Nov 2008
    650B wheels on a 29er frame/fork set?
    I assume this topic has been covered? Other than a very slight drop in BB height, is there any real issue here?
    Reputation: d365's Avatar
    Quote Originally Posted by ambassadorhawg View Post
    I don't understand the point. What would be the gain?
    It will still have long chainstays, and a long wheel base, with a lower BB, and smaller wheels. It's like taking away the good things about 29er, but keeping the bad.
    Binned
    Nov 2008
    I'm not really sure??? My 29er frame has "short" chain stays. I was thinking less rotational mass, slightly faster response riding techy terrain, and slightly tighter turning.
    meow meow
    Reputation: b-kul's Avatar
    its a pretty decent bb drop. probably in the area of 20mm. most 29ers already have low bbs as it is. id be careful if you ride rocky trails.
    Reputation: LukeSPOOK's Avatar
    Give it a try - I did - worked just as you described.
    Lower BB - bike handled like a dream, but not ideal for technical terrain.
    Reputation: Tendon's Avatar
    Do it in the back, which you don't need anyway. And shorten your cranks to take care of the BB thing. Speaking from a 5'5" Rider.
    Binned
    Nov 2008
    Quote Originally Posted by LukeSPOOK View Post
    What frame/fork and what travel do they have?
    B9er(b out back) felt good on my bros ride.
    '10 Marin MountVision 650b conversion
    orthonormal
    Reputation: andy f's Avatar
    Since you'll still have the same wheelbase, it won't be much help in terms of tighter turning.
    The glass is twice as large as it needs to be
    Reputation: shiggy's Avatar
    Dec 1998
    I do not consider 19mm (3/4") to be a very small drop in BB ht. For me it would take most frames into the not-suitable-for-trail-riding range.
    mtbtires.com
    May 2012
    I made the change to my 2012 Trek Superfly from 29er to 650B with Stan's flow ex with Schwalbe RaRa 650B x 2.25" and tube setup. BB is about 11.75". Yes, it is lower but feels much more easier to pedale. Don't have much time to ride though.
    Attached Thumbnails Attached Thumbnails 650B wheels on a 29er frame/fork set?-rsz_1img_3518.jpg
    '17 Giant Anthem Adv_C-Build
    '17 SC Bronson CC_C-Build
    '17 Ibis Mojo 3_C-Build
    '15 Giant Anthem1_C-Build
    '12 Trek Remedy9
    Oct 2010
    Quote Originally Posted by ckspeed View Post
    I made the change to my 2012 Trek Superfly from 29er to 650B with Stan's flow ex with Schwalbe RaRa 650B x 2.25" and tube setup. BB is about 11.75". Yes, it is lower but feels much more easier to paddle. Don't have much time to ride though.
    Weight? And please, tell me how to paddle on a bike!!
    Dec 1998
    Quote Originally Posted by donkeykong0 View Post
    That is because the pedals are always hitting the ground
    mtbtires.com
    Binned
    Nov 2008
    Quote Originally Posted by shiggy View Post
    So, you're saying my idea is dumb?
    I had a 2012 Scott Spark 29er with 100mm travel - had a chip attached to the shock linkage that can change the BB height by about .3" (or 7mm).
    I was hoping to change the travel on my Reba from 100mm to 110 or 120mm, to give some more height but was unable to.
    Had a 650b wheelset and a 29er bike, so had nothing to lose
    Found good acceleration, less gyro effect with 650b wheels and less weight.
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    I think converting a 26er may be a better id'er. The Santa Cruz TRc is a popular retrofit. Or hook up
    on a real one like a Jamis 650b. I really like my 650b conversions. And its not from any Kool-Aid talk either because I don't walk around recommending it to anyone, I just like the extra umph you get from climbing opposed to a 26 or 29 and the cornering on ST is less tedious on a than on a 29er...Good luck. And come over a ride one of mine
    MTB B'dos
    Reputation: LyNx's Avatar
    I'll try to be nice as people seem to think my replies are "Cruel" a lot
    I gave it a try, put a 650B on the rear of my Prime with it in the steep geo setting where the BB is about 13.4" (un-sagged) with 29" wheels, the pedal strikes alone annoyed the crap out of me, but I could work with that height, as d365 said, you loose all the benefits of the 29er platform and gain no benefit - I had tyres to test and both had more tread than my worn out old Ignitor I was beating on and on the same climb I cleaned previous on those Ignitors I lost traction with the 650B.
    I did it just to see if it would spin up easier, make getting up steep climbs easier since in theory it would accelerate easier, the wheel stayed on the bike for 2 rides because I had 2 650B tyres to test, that's it, case closed. Only time I'm putting a 650B anywhere it'll be on the front of a 26" wheeled bike, where you can gain some benefits.
    MTB Barbados
    My Phantom pics
    Moderator Moderator
    Reputation: Walt's Avatar
    Yes
    The reason to use 650b wheels is to get some extra rollover/traction/etc without having to make some of the geometry sacrifices of going to 29" wheels (ie chainstay length, potential toe overlap, reduced suspension travel, standover, etc). There is pretty much zero benefit to converting a 29er unless you *really* hate how high the bb is and want to drastically lower it, and are otherwise ok with the geometry.
    One last quibble - while a 650b *wheel* is definitely easier to accelerate than a 29" one, a 650b or 29" *bike and rider* have so much more mass than the wheels (not to mention that when accelerating you also have spend a lot of energy to overcome various forms of friction, especially air and rolling resistance, that are unaffected by the size of the wheels) that you'd never be able to tell a difference while riding.
    -Walt
    just some guy
    Reputation: talabardio's Avatar
    Quote Originally Posted by Walt View Post
    One last quibble - while a 650b *wheel* is definitely harder to accelerate than a 29" one, a 650b or 29" *bike and rider* have so much more mass than the wheels (not to mention that when accelerating you also have spend a lot of energy to overcome various forms of friction, especially air and rolling resistance, that are unaffected by the size of the wheels) that you'd never be able to tell a difference while riding.
    -Walt
    Do you mean that a 650b wheel is easier to accelerate, or am I just confused?
    Moderator Moderator
    Fixed, thanks.
    My brain is apparently not working very well this morning.
    Quote Originally Posted by talabardio View Post
    Dec 1998
    Not if you like dragging your pedals on the ground
    mtbtires.com
    Dec 1998
    -Walt
    A wheel that accelerates quickly also decelerates more easily.
    I have a road bike with 20x1-1/8" wheels. Very light wheels. Terrible climber. Feels like you are walking up stairs as the forward momentum almost stops at the bottom of each pedal stroke, and surge forward on the power stroke. Rollover ability is not even a factor here.
    My best off road climber is my fat bike, even for longer steep smooth trails, and my complete rear wheel alone weighs 10+ pounds.
    mtbtires.com
    The White Jeff W
    Reputation: jeffw-13's Avatar
    I ran 650B on my Yelli Screamy for awhile. It has a 140mm fork so no issues with ground clearance. I really liked how it rode but eventually put the wheels back on the the bike they came from so I could ride it again.
    Attached Thumbnails Attached Thumbnails 650B wheels on a 29er frame/fork set?-yelli-650b.jpg
    No moss...
    Life Is Short
    Mar 2006
    Ambassadorhawg---shoot me an email and come over and borrow this bike for a couple weeks.
    Its a pig though but its a 650b. Ride it up around our hillsides and see if the B is for you.
    Attached Thumbnails Attached Thumbnails 650B wheels on a 29er frame/fork set?-p4pb8632301.jpg
    MTB B'dos
    Jeff, care to give more in depth thoughts on what you liked or why you liked the 650B on your Yelli, quite interested to hear?
    Quote Originally Posted by jeffw-13 View Post
    Not what the OP was asking about, but not a bad idea to see if in general he likes the 650B platform. Suspecting though that there's something about his Pivot that he just doesn't like, thinking it's the steep HA and its handling characteristics and that bike will handle totally different for sure.
    Quote Originally Posted by fatcat View Post
    MTB Barbados
    My Phantom pics
    Binned
    Nov 2008
    I already "fixed" the steep HTA by increasing the travel of my fork from 95mm to 115mm. WOW, did that liven up this bike! I am overjoyed with my Pivot frame. Super rigid for climbing, plush for going down the hill.
    I don't ride techy, rocky stuff. I like buff, flowing ST. So, hitting the cranks wouldn't be an issue. However, if the "long chainstays" of the 29er frame would eliminate the possibility of an improvement by going with smaller wheels (650B), then that idea is out.
    The reason I am considering 650B is because I've experienced enough cons riding 26" and 29" wheels to know that IMO, neither is "perfect" for me. So, I'm wondering if the 650B is a better solution (for me). I've seen plenty of posts about throwing 650B wheels on a 26er frame but tire clearance is not good. I just hadn't seen any threads/posts (until now) about throwing 650B wheels on a 29er frame. I am looking for feedback, that's why I started this thread.
    So, thanks guys!
    I put 650b Wolverine 2.2's/Stans 355 tubeless on my Dos Niner. What a blast on flowy/carving trails (Falcon Trail, AFA, Colorado Springs). Better acceleration, more fun in the air, better braking. I am fairly light so the rollover on sand was similar to the 29er feel, and being closer to the ground made carving and S turns nicer to transition through.
    However. I ride rocky trails too, and gave up after about 10min with the pedal strikes. Dangerous even - it would strike and high side when you were not thinking it was even close.
    Try it, but be careful in the rocks/roots.
    Jon.
    MTB B'dos
    Sounds like 650B could work for you on the Pivot except AFAIK, it has very long stays, so don't think you'd be gaining any real benefits from going to the 650B. If you had a bike with <17" stays, then might be worth it - Jeffs Yelli has <16.9" stays, as does my Paradox, but the BB on my Paradox is already low with 29" wheels so no way I'd try 650B.
    ..............I don't ride techy, rocky stuff. I like buff, flowing ST. So, hitting the cranks wouldn't be an issue. However, if the "long chainstays" of the 29er frame would eliminate the possibility of an improvement by going with smaller wheels (650B), then that idea is out..................................
    So, thanks guys!
    MTB Barbados
    My Phantom pics
    The White Jeff W
    I only rode it 650B 2 or 3 times. Mainly I liked that the bike felt lower to the ground. I have long legs so I have the saddle pretty high for general riding. The lower c.o.g. was tangible and it felt a little more nimble and quick. The smaller wheels also lowered the overall gearing and made it easier to get up the hills.
    No moss...
    Seems like many people have gone from 26in to 29er, found the benefits and drawbacks of both bikes, want to try 650b wheels but don't have heaps of cash to throw around, so would like to use the frames they already have before buying a new bike.
    A 29er frame can obviously take large 650b wheels so is the easiest option for many to try / test (not as a permanent solution).
    People currently can build / purchase 650b wheelsets and if they did not like them, there is a good chance to sell them easily due to current shortage 650b components and buyers wishing to try 650b wheelsize.
    I'm curious about the Canfield Nimble 9. I think it would wind up similar to a Jamis Dragon 650b if you put a 120mm fork on it. Geometry should look something like:
    HTA: 68
    STA: 72
    BB height: 12"
    Chainstays 16.25"
    just some guy
    On another tangent, I can imagine possibly fitting 29er wheels on a 650b frame, should one want to.
    these are some of the most interesting responses i've sen on a thread in a long time
    In what I tell the nephews is "cowboy science", I tried a 29er wheel on my white brothers 650b fork. Not even close to fitting. It might fit a 700c 28 cross tire..
    Jon.
    Apr 2014
    resurection of thread!!
    Just bought a team 650b FS boardman frame, put all my previous bike bits on, all massive upgrades expect the sunour XCM fork..
    so just saw a sale on 29er forks, RS gold solo air. cheaper and will give a little more head height . ordered one so will tell you how it goes!
