650b vs Tall 26 Tires?
Printable View
  • 12-27-2012
    In2falling
    Ran across this picture the other day of the tire height of a 650b with a Neo2.3 which got me thinking about the tires I am running on my AllMnt rig, Minion DHF 2.5 EXO front and High Roller II in rear. So ran out to the garage and measured the height of both tires.
    The DHF 2.5 (a tall 2.3 tire) measured out exactly the same as 650b with Neo 2.3, the HR2 was about 3/8th of inch shorter and think I could squeeze a DHF 2.5 on the rear of that bike.
    So am I running 650b :)? What is all the hype with 650b?
  • 12-27-2012
    loamranger
    The tallest 26 inch tyre I have come across measures 695mm wheel dia. ( 2.4 Continental Trail King's) compared to my 650b Schwalbe 2.3 HD's which measure 705mm wheel dia. Switching the front out only (from the TK's) I have noticed better roll and grip. Since I have had no experience of the 26 inch version of the HD, I'm not sure if the benefits are from the increased dia. or the tyre pattern itself.
    If the DHF 2.5 measures 705mm wheel dia. then effectively you are running 650b. However, there are some 650b tyres coming out that will measure 710mm or bigger wheel dia. You also need to factor in weight. What does the 2.5 DHF weigh? The HD comes in at 834 g.
  • 12-27-2012
    golden boy
    I almost hate to say it, but after my initial favorable reaction to 650b, I am starting to wonder if it is different enough from 26" to merit yet another standard. Not that my opinion matters, as it's already happening. I don't think I could tell the difference in a blind test, unlike 26 vs 29.
  • 12-27-2012
    rice rocket
    What's the practical limit on sidewall height?
    For reference, rim diameters are:
    26: 559mm
    650b: 584mm (25mm larger than 26", 38mm smaller than 29")
    29: 622mm
  • 12-27-2012
    In2falling
    My super tacky DHF 2.5 comes in at 935 and the hard compound version comes in at 835.
    Have had quite a few different set of tires over the last few years on this bike (Kenda, WTB, Intense) and this is by far the best combination (roll & grip) that I have had on it so far. Don't know how much of this is the taller diameter or the tires themselves.
    I just don't see the point of trying to convert an existing 26" bike to 650b when a set of taller tires appears to come close to accomplishing the same thing.
  • 12-28-2012
    derby
    26: 559mm
    29: 622mm
    Yes, the shorter sidewall of a larger wheel with the same rim width can be as stable, lighter overall, and use lower air pressure.
    I measured a new 26" Ardent 2.6 wide DH tire on a downhill bike to be 1/8 inch shorter than my (relatively short) 2.3 Neo-moto 650b. Sounds like the 2.5 Minions are taller than the 2.6 Ardent, I don't know.
  • 12-28-2012
    DeeEight
    26: 559mm
    29: 622mm
    There isn't one... unless you factor rim width in also. Surly Nate tires are nominally a 559mm bead seat x 3.8 inch wide tire, designed to fit on a 63mm width rim, but some fat bike riders use them on rims up to 100mm width to increase the amount of casing in contact with the snow. The diameter of those tires are so close to 29 inches that Surly and Salsa at least advertise their bikes as being good "I own 1 bike" type of bikes, because with a second 29er wheelset, they can be ridden in the summer time on regular trails. However a foldable tire for a fat bike, with a single-ply casing and a soft rubber compound good for snow riding is still at best, 1.2kg. A 29 x 2.4 is around a pound lighter and for most riders... just fine for already packed snow trails.
  • 12-28-2012
    DeeEight
    Rubber is the heaviest part of the rotating mass equation of a wheel. To get a 26er format tire tall enough to equal the roll-over ability of a larger wheel format tire, takes a LOT more weight than simply stepping up a wheel size. A Schwalbe Racing Ralph 650B x 2.25 is the same diameter as your DHF and weighs about 525 grams. A nobby nic is only maybe an ounce heavier than the RaRa in the same width. The jump in wheel weight specific to going from 26" to 650B (rim weights and slightly longer spokes) is at most 3 ounces grams for equal cross-section rims.
  • 12-28-2012
    gvs_nz
    And then there's always the possibility the DHF 2.5 will come out in 650B?
  • 12-28-2012
    gvs_nz
    I've had the TK 2.4's and they were horrible compared to even 26" HD's. The stiff casing gave a harsh ride even at very low pressures. Even worse than Big Betty's. I imagine the DHF 2.5 gives the same horrible harsh ride. Need a 180mm fork just to smooth the tire out.
    650B HD must be a huge improvement in ride quality over these tall pig iron DH tires.
  • 12-28-2012
    loamranger
    Not my experience with 2.4 Rubber Queens (TK's) with Black Chili, they roll really well, good grip and the least harsh of all the tyres I've used. Most of the user reports I have read concur. That said I'm really liking the 650b HD's and they are a good match with the TK's on the rear.
  • 12-28-2012
    loamranger
    26: 559mm
    29: 622mm
    So if Continental made a 650b version of the 2.4 TK with the same profile as their 26 inch version, then the wheel diameter would be around 720mm.
    Most 26 inch AM tyres measure no more than 685, so 720 would be a significant increase.
  • 12-28-2012
    1soulrider
    Not my experience at all.
    I found the 2.4 TKs quite supple and grippy in both the UST and normal casing. They are too big for my liking as a trailbike tire though.
    The DHF in dh casing is stiffer than a trailbike tire and it needs to be: it is a dh tire. In the lighter casing it is a great aggressive am tire choice.
    No need for a 180mm fork to help with your tires (?), that fork is for smoothing out the chunder.:D
  • 12-28-2012
    problematiks
    The weight issue can be a double-edged sword type of situation with tires.It really depends on where you're riding and makes favoring a Nobby Nic to a Minion DHF a bit ridiculous.I understand there are a lot of trails where a Minion (or even a Nobby Nic) is overkill but on the alpine terrain we ride a tire under 800-900 g won't last a month of semi-aggressive riding.
    But putting the weight issue asside, I think the question the OP posed while very interesting (I was wondering about the same thing, to be honest) is a bit outdated at this time when tire manufacturers are starting to make true high volume 650b tires, not conversion friendly ones.
    Marko
  • 12-28-2012
    gvs_nz
    I found the 2.4 TKs quite supple and grippy in both the UST and normal casing. .:D
    Compared to what? They are no where near as supple or grippy as an HD even in pacestar compound.The HD's are not a supple tire compared to schwalbe lighter, Triail snakeskin and conventional sidewall tires. Casing suppleness also adds cornering traction. I found the TK 2.4's hardly had any more cornering traction in the loose than a MK2 2.4, which are not great. They are both just too narrow.
    If DHF 2.5's are even stiffer, then even more reason for using a more supple 650B alternative as a AM tire.
  • 12-28-2012
    1soulrider
    Compared an array of tires from Kenda, Maxxis, Specialized, Schwalbe and other Conti tires. I have a ton of tires as I feel they are one of the most important aspects of a bikes performance.
    What kind of tire pressure do you run and what type of terrain do you ride? What type of bike do you run? These are key factors in why riders tend to disagree about tires.
    A ht rider from Sun Valley is going to have a completely different opinion of a tire compared to a 6" am rig rider from Az.
    The TK 2.4 is too narrow?! It is as wide as some companies 2.7 tires, and has huge volume. Big even for a dedicated dh tire.....
    Not involved in arguing that a big 26" tire is a better choice than a 27.5 tire, just didn't agree with your assessment of the tires mentioned above.
  • 12-29-2012
    GMM
    Thanks for your honesty. It's always refreshing when someone is willing to go against popular opinion with a sincere viewpoint.
  • 12-29-2012
    gvs_nz
    Agreed tire discussion is always contentious.I also have a ton of tires, in all three sizes. I was using it on the front only of my Meta 6 but it was no where near as good as an HD. I'm only 160lbs and riding it as low as 16 psi[ there's a break even point in sidewall thickness where low pressure can not reclaim ride comfort. Std snakeskin is it]. A heavier rider and bike would be able to smooth it out, but it has has serious stiff apex reinforcements which make the ride harsh.Any Geax 2.2 tire or Michelin 2.1 would be smoother. Large volume is no guarantee of a smooth ride,at least on the front anyway.
    I think your getting a lttle excited about it's size. It's only 5mm taller than a HD and the casing is narrower. As far as tread width, the widest part[only 50%of the tread] is only about 58mm.Even a No Ni 2.4 is wider.The Hd is about 61mm for the full circumference. The majority of the tread on the TK 2.4 is only about 55 mm wide. if your on the edges, in the loose, there's not enough rubber on the edges to push off.Fine if the tread can still touch hrad pack or if your only on the shoulder where most of the tread is concentrated.
  • 12-29-2012
    gvs_nz
    You wont if your looking for rollover[ bike mag hype]. You will if you compare stability and cornering traction in loose conditions. I prefer 26" on my slacker bikes as it adds too much stability and they ride like 29ers.I ride some hard pack sweeping groomed trails where it makes absolutely no difference in wheel size.
  • 12-29-2012
    loamranger
    Hi gvs, can you clarify what your trying to say here? Thanks.
    Have you tried the HD in both 650b and 26 inch?
  • 12-29-2012
    gvs_nz
    There's very little difference in rollover from a tall 26" to a 650B tire.There is however a big difference in cornering traction and stabilty at the apex of corners in loose conditions. For that reason anyone with trails that are hard pack , without trail chunder, will struggle to notice any difference in wheel size besides acceleration, momentum and steering. All negatives for the bigger wheel sizes of similar weight tires.
    I've only tried the Hd in 26" so all of the above is a direct 26" front comparison, the rear only follows. Your 650B Hd should be streets ahead of a TK2.4 in the front end cornering traction.
    I still ride the MK2 2,4 on the rear of some bikes and it's only 5mm ride height lower than the TK2.4 and a rat load lighter and smoother.
  • 12-29-2012
    smmokan
    FWIW, I just measured my 26" Maxxis Minion DHF EXO 2.5" - on an Easton Haven wheel - and it came in a hair under 26-3/4". I have no idea how the OP's tire measured a full inch taller than that.
  • 12-29-2012
    pastajet
    Note: I am a tire tester and pro-reviewer of bike components (tires, etc.), the former for one particular large brand. But I am as full of it as the next person, so take it with a grain of salt.
    Although I strive to be objective as possible in all my reviews and testing, tires are somewhat personal, and how they react and work for me, and my local terrain, makes it all the more difficult. So I try to be overly picky, and dig deep into their characteristics, and look for strengths and weaknesses in any terrain and conditions. I have tested tires on my Ibis Mojo HD (26 & 650B), Mojo Classic and Moots Mooto-XZ 29er, in any sort of terrain that Colorado, Utah, AZ (a few forays in SoCal) can throw at you. My local testing terrain is predominantly loose rocky conditions, with many long steep climbs and descents, rock gardens, slick rock, an occasional smooth singletrack and lots of ugly loose gravel. In the Colorado Springs area where I ride, we have Pikes Peak gravel (pea gravel) on most of our trails, and it's one of the most nightmarish traction eaters that I have ever dealt with. Cornering, braking and climbing can be a lesson in humility.
    Harsh TK's =>
    In regards to the 26" TK 2.4 (Black Chili version), I never found them to offer a harsh ride, at least at 18-24psi. They are still my fave tires of all time, and I have gone through at least 7-8 pairs. Found them to offer excellent flotation and traction in loose conditions, and they are sticky on slick rock, and are conformable and pliable in rock gardens. They have one of the fattest carcasses on the market at an almost true 2.4. Specified tire size by manufacturers are pretty useless, and are only a general indication of skinny, medium and fat widths. Other fat tire have more width in regards to their knobs than the TK, but not usually the carcass.
    650B vs 26 =>
    There is no way that the OP measured properly. Large 26 tire measure at most a hair over 27, 26 comes in from 26.5 to 27, while any 650B is 27.5 to almost 28, comparing the same model (NN 2.35) the difference is close to an 1 inch (give or take)
    gvs_nz =>
    How much experience have you had riding 650B tires and wheels? What are your local conditions that you ride? I find the 650B have better rollover than 26 IMHO, though obviously not a 29er. Personally in my local conditions, I don't like the MK2 2.4's, I find they aren't as sticky on rock ramps and don't offer near the traction in loose conditions, though they do offer better acceleration, rolling, faster steering, and are lighter.
    MK2 2.4 Protection
    Casing width - 2.25 inches
    Casing height - 2.05 inches
    TK 2.4 Black Chili
    Casing width - 2.38 inches
    Casing height - 2.27 inches
  • 12-29-2012
    In2falling
    Opps my bad :), I measured it with the wheel on and looked like it was 27-1/2. I just took the wheel off and it measures out at 27-1/4 right down the middle knobby to knobby.
  • 12-29-2012
    rideit
    Exactly the point, for me. as soon as it starts to be really noticeable, then I start feeling all of the things in the ride that I hate about 29-ers!
  • 12-30-2012
    gvs_nz
    gvs_nz =>
    /QUOTE]
    A couple of years. I've done back to back tests of rollover with Ra Ra 2.25's in all sizes on the same hard tail. It is noticeable to a small extent with similar volume tires but not large volume 26" tires. The extra dynamic stabilty and cornering traction by far out way any small rollover or momentum benefits. I'm pretty sure that would also sustain crtical analysis with a few engineering calculations.
    I ride varied trails , mainly forrest trails, some similar to Pacific Northwest. Lots of tree roots and very few rocks. In the summer it's loose over hard pack and some trails can get pretty loose with a sandy base.Obviously polar opposite to your trails.
    Once again, TK 2.4 is not harsh on the front in comparison to what? I'm comparing trail / light AM tires, not DH tires. It's harsher than the tires I prefer to ride, possibly the exception is the Big Betty. I consider a soft riding tire something like a a Race king 2.2 which is not far off in volume to the TK 2.4 but leagues apart in ride quality. Obviously not a trail tire but the comfort end of the spectrum I prefer at my light weight. I don't need heavy sidewall protection . I'm for a compromise. The TK2.2 or MK2 2.4 are that compromise as a rear tire with something like a Hd on the front.
    We obviously ride in totally different conditions and the large gaps in the tread of the TK2.4 obviously hook up well for you in pea gravel etc. Quite the opposite on wet roots . The large gaps don't give much hold on wet tree roots. However they are in general a great rear tire. Just not a great front tire compared to an HD in deep loose over hard[ soil and sand not pea gravel]. In genearl they are just too heavy and harsh for general trail / AM tire when the Hd offers everything it does plus some at a lighter weight. It's obviously got to be near the top of the list if your priority is a tough as nuts tire for rocky conditions.
    From memory you didn't like Hd's in particualr the wear. Ever tried pacestar Hd's. IMHO the trailstar is to soft for the small Hd tread blocks in dry and hard pack conditions anyway. Better suited to the larger blocks of the Big Betty.
    Hd's are selling like hot cakes. In their wake the Tk 2.4's are in demise. Tk2.2 is still a popular tire, especially on the rear.
    If i remember right you did an initial review of Neo 2.3's a few years back and rubbished both 650b rollover and neo 2.3's in general.
    Times have changed?
  • 12-30-2012
    gvs_nz
    That's why i don't like them at 67 degree and slacker. Great for carving corners but you loose too much agility. Too 29erish.
  • 12-30-2012
    RagerXS
    There are too many different comparisons in this thread. If it is the same tire in both sizes then the diameter should be very noticeable with the performance differences that go hand in hand with that. But if we stick to the OP's topic the primary answer is weight. For comparison let's consider my two sets:
    Neo-Motos (2.3 F, both a 2.3 and 2.1 R)
    Conti Trail Kings, both at 2.4
    I run the Neo-Motos for three seasons and the TKs in the winter here in New England. The TKs are black chili, not harsh to me, and grip so well that I have not tried studded tires yet. But the weight penalty is around 3/4 lbs per wheel and when spring comes the acceleration improvement is huge with the lighter tires.
    I dream of a 650b tire that grips like a TK (or better) with close to the same weight and diameter of a 2.3 Neo-Moto.
    Fred
  • 12-30-2012
    gvs_nz
    The 2.25" 650B 27.5 HD in Trail star compound. Doesn't have the paddle tread of the TK for tractoring up climbs in the snow. Should easily equal the TK on wet rocks and roots though. And you get that little extra diameter for edging over rocks and roots in climbs. That infamous 650B rollover comes in handy trudging up rocky climbs;)
  • 12-30-2012
    zorg
    Makes me want to try big volume tires on my 26er.
  • 12-30-2012
    phoenixbikes
    I have Panaracer Fire Xc Pro tires in both 26 and 27.5. In either diameter, it's a fairly stiff tire. I know the Fire Xc Pro is a dated design at this point but it's still around for a reason.
    For the same trail, I come back from a ride feeling less sore on the 27.5 tires. The 27.5 version grips better on climbs, and has better traction in corners.
  • 12-31-2012
    loamranger
    Rager, might be worth checking out the 650b Vee Rubber Trail Taker's, apparently they have Pacenti marked on the side walls and appear to be the same pattern as Pacenti Mega Moto's. They weigh around 730g and measure 710mm wheel dia.
  • 12-31-2012
    pastajet
    gvs_nz =>
    /QUOTE]
    Times have changed?
    Yep, slightly different terrain. I do sometimes get that locally, but it's not as common. Currently we have more snow, so I have been out on my 29er with some uber fat test tires.
    I do like the HD up front, as it does hook up well and is long lasting, I just prefer a stickier fat one in the rear, so I like the TK2.4 (no 650B though). I love the Big Betty, but I destroy those in a matter of weeks in my local rocky terrain, though they're excellent for that period of time, but die too quick. I have been riding the Neo 2.3 of late since I don't have anything never, and they certainly are durable though not as fat or sticky as I like. I have them on some DL31 rims, which helps somewhat. I find they give a harsh ride since they lack volume, but they're very flickable and fast and tough.
    I am waiting on some new HD's, but I wanted to try the Super Gravity version, and Schwalbe haven't sent me a pair as yet.
    Thanks for the info, always nice to have a good rapport with a fellow forum rider.
  • 12-31-2012
    gvs_nz
    I won't go back to them unless he does a version with a lighter casing and dual compound. The Neo 2.1's with their lighter casing ride smoother so he can squeeze a bit more comfort in to them yet.
    The 2.1 would make a good 29er tire if he could keep it about the same weight with dual compound. Relabel it as a 2.2 or 2.25 though . You don't get sales under selling the size of your tires compared to the competition.
  • 01-02-2013
    gvs_nz
    MK2 2.4 Protection
    TK 2.4 Black Chili
    Just double checked mine as I note your MK2 is protection which are always smaller than my Racesport version.
    Both Black chilli, prestretched and mounted on the same rims at the same presssure.
    TK2.4 [casing and tread are same width] and are 0.5mm wider than Mk2 2.4 [ [casing and tread are same width]
    TK2.4 casing and tread are both 3.9mm higher than MK2 2.4 casing and tread.[measured above the rim wall]
    So they are not a bad option if someone wants a tall tire but doesn't need the extra traction and protection that goes with the extra 280g of the TK2.4. From memory the Xking 2.4 is very similar dimensions as the MK2 2.4.
  • 01-03-2013
    R-DUB
    I have been riding a brand new 26" wheeled full suspension bike for the last few months. Upon reading some magazine articles about this 27.5/650b stuff I decided to go to the garage and measure the (outside-to- outside) diameter of my rear 26" WTB BRONSON 2.3 TCS tire. The measurement was just a few hairs over 27 inches. So I measured the the front 26" WTB WEIRWOLF 2.3 TCS tire and it came in at exactly 27". I have probably ridden a few hundred miles on these tires before this measurement was taken so I have to assume that some of the tread has worn off considering that the little whiskers have disappeared.
    I read most of you describing a half inch and an inch difference between most 26 and 27.5 in tires but really that difference would be the radius not the diameter since the axle to tire dimension is the only thing that changes. I may not be that in-tune with the way my bike handles, but I can't help wonder how anyone but maybe a pro would notice a 1/4 to 1/2 difference in tire radius. Still curious about the 27.5 format though.
  • 01-03-2013
    phoenixbikes
    I am not a pro. However, I can DEFINITELY tell the difference between 27.5 and 26. You can't really go by numbers alone, they are not the whole story. 27.5" wheels ride noticeably different from 26" wheels, but you have to RIDE them to actually feel that difference. Measuring tires and debating on an internet forum don't really do justice to the actual ride qualities of 27.5 wheels. Find a set, go out and ride them on the same trails (for awhile), and THEN you can make some judgements about them. It's hard to make any useful decisions without some actual riding time.
  • 01-03-2013
    smmokan
    Radius = 1/2 Diameter, so it's apples to apples. The 26 and 27.5 are measurements of diameter, so that's why it's being referred to.
    If a tire on a 26" rim is ~27" tall, then you have to correlate that the exact same tire on a 650B/27.5" rim is going to be around 28-28.5" tall. That's a noticeable difference any way you slice it. It might not be for everyone, but it's obviously for enough people if it's gaining popularity. Comparing different tires on different wheels on different bikes is stupid if someone wants to measure the difference in feel or performance.
    Look at it in relation to the ski industry. The key measurement of a ski is the width of the waist and the amount of sidecut a ski has. There are skis of every width from 65mm all the way up to 150mm (or more), and multiple sidecuts exist for every one of those widths. I'm willing to bet that an established skier could tell the difference in performance between most of them. If mountain bikes only have three (for now) wheel sizes and they're all more than 5% different from one another, you can bet that the performance will be quantifiable and noticeable.
  • 01-03-2013
    loamranger
    Large width 26 inch tyres are normally around 685mm (27ins.), exceptional height 26 inch tyres like the Conti 2.4 TK measure 695mm (27.4ins.). Typical first generation 650b tyres measure 705mm (27.8ins.) and the new generation of fat 650b tyres like Vee Rubber Trail Takers measure 710mm (28 ins.). Potentially 650b tyres could measure up to 720mm (28.4 ins.). So the measured differences between 26 and 650b could be up to 38mm (1.5 ins.) which would definately translate into a significant difference in performance.
  • 01-03-2013
    Thor29
    I'd like to see an all mountain/ trail 26 inch tire in a 2.7 to 3 inch width. Kinda like the Surly Krampus 29+ but in the little wheel version. The diameter would end up being close to 27.5 but you would get that extra fat tire goodness. You could build a frame for the fatter tires that could use either 26+ fatties or regular 27.5s.
