Results 1 to 38 of 38
    650b Trek Remedy
    Well, I installed a Kirk's P35 Velocity on the front of my 09 Trek Remedy 9 today. Haven't ridden it yet, but I'm excited as hell to. This wheel is so wide that you can fit the width of the Stan's Flow on the back inside the P35. Attached are photos showing how much room is leftover. The pics don't even do it justice - there's tons of room leftover. It actually looks like a 650b might fit in the rear.
    www.derbyrims.com
    Reputation: derby's Avatar
    It looked to me that a 650b would just clear the rear of a Remedy when I did some quick measurements. The chain stay area just next to the rings could be a width issue. If you can measure clear space 1/2 inch radius forward from your current rear 26" Nevegal knobs then the 650b Nevegal should clear.
    Cool bike! Bet it rides sweet with the PUSH tuned shock and fork.
    Reputation: MMcG's Avatar
    Jul 2003
    Wowza!
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Great looking bike. I'll be patiently awaiting a full ride report.
    Cheers,
    KP
    If you like my products and services tell everyone. If you don't, tell me - kirk(at)pacenticycledesign.com
    Well, I've got about an hour in the saddle with the 650b now. I have to say that I think the difference is beyond noticeable. The problem I always had with the bike before was cornering. It always seem to be unstable in the traction department. Washouts were fairly common and I never felt confident with the traction up front. What I noticed last night was unbelievable traction. I think I was just pushing it to see if it would break loose. I know that I was going into corners much hotter than before. That's not all good because I think I had to overbrake to negotiate the tight singletrack turns. I'm sure I can work on that though.
    I can say that I was looking for a smoother ride over all the rocks and roots we have out here on the East coast with the bigger front wheel, but I didn't notice a readily discernible difference. At least I didn't think I did. We have this really tight switchback that is rooted all to hell and it's typically hard to hold your line around the smoother outside. Yesterday, it was as smooth as I can ever remember and holding my line seemed pretty much effortless.
    I definitely need more time in the saddle with the 650b, but first impressions seem extremely encouraging. There is one problem though. I first set the front up as tubeless with the Nevegal, but I never could get the bead to seat on the P35 rim. I put it on a compressor and I'm embarrassed to say that I exploded the first Nevegal trying to get it to seat. Luckily I had a friend who had another and I just put a tube in it. It seems the vertical indentions (bead grippers) in the Nevegal sidewall are too close to the bead and air always leaked around the grooves. I'm guessing it's because the P35 is just so wide. Anybody have any recommendations for a tire that will go tubeless on the P35? I think I've heard a lot of people talking about the NeoMoto. Any other suggestions? Thanks.
    www.derbyrims.com
    Quote Originally Posted by runjhike
    .... There is one problem though. I first set the front up as tubeless with the Nevegal, but I never could get the bead to seat on the P35 rim. I put it on a compressor and I'm embarrassed to say that I exploded the first Nevegal trying to get it to seat. Luckily I had a friend who had another and I just put a tube in it. It seems the vertical indentions (bead grippers) in the Nevegal sidewall are too close to the bead and air always leaked around the grooves. I'm guessing it's because the P35 is just so wide. Anybody have any recommendations for a tire that will go tubeless on the P35? I think I've heard a lot of people talking about the NeoMoto. Any other suggestions? Thanks.
    Before converting a tire to tubeless, it helps a lot to mount up a tire with a tube overnight to allow it to stretch out and conform to the rim. Then use lots of soapy water, like 50% dish soap sloshed around the bead and inside the rim to mount tubeless.
    I haven't mounted a Nevegal tubeless, but the Neo-Moto's have mounted easily with a floor pump when using "ghetto" rim-strips, except once when I needed a shot of compressed air to get a bead seal going onto my front P35 and rear Blunt 650b rims. The Neo-moto's don't have any "bead-gripper" swipes above the bead like the Nevegals.
    Maybe someone else has tubeless mounting tips specific to the Nevegal.
    Not an O2 thief.
    Try the WTB Woverine 2.2. Nice all-rounder tire.
    Nice job on the mid-wheel rig. My wife rode the Remedy at the Trek demo and loved it but didn't like the tiny wheels. She's a 29er fan. This year she put almost an hour on the Rumblefish. The Remedy has so much more travel...with those tweener wheels you're gonna have a blast.
    Roll over the weak and bunny hop the dead!
    Blog this...!
    El Paso Puzzler 35 or 50 miler
    Reputation: salimoneus's Avatar
    Don't blame yourself too much on the kaboom, I've had more problems with non-UST kenda tires failing in a ghetto tubeless setup, than all other brands combined. This is most likely due having such thin/weak sidewalls. I avoid running Kendas now because of this, and have had very good results with all Panaracer tires, including the Neo-Moto which is holding up great. I definitely recommend Pacenti tires, top quality and great performers.
    Glad you like the new ride, sure is a beaut!
    Oh, and sorry if I missed it, but what's the final build weight?
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    runjhike, I'm not slamming the Nevegal, but I think you'd be impressed with the 2.3 NeoMoto. This is one of the best tires I've used over the years...26" or any other. The P35 and Neo make for a bulletproof tubeless setup IMO. I've been using one on the front of my Nomad for quite awhile.
    A buddy of mine told me about the Wolverine. I might try that later on. For now, I just ordered a NeoMoto, so we'll see how that goes running tubeless.
    Since the explosion, I've studied the 650b Nevegal and I can clearly see why it won't seal. The bead grippers are much closer to the bead on the 650b size than they are on the 26". I've been running Kendas tubeless in the 26" variety for a few years now and I haven't had any problems whatsoever. The only reason that I had the Nevegal up front on the 650b was due to a friend being a racer and being able to get me a good deal. Otherwise, my favorite tire around these parts is the Kenda Excavator. The only thing that I've found that is equal in the all-around traction department is the Maxxis Ignitor. Hopefully the NeoMoto will live up to its reputation and will be a keeper for the type of terrain that we have around these parts.
    As for build weight, I have no idea right at the moment. The last time it was weighed was a few weeks ago with the stock Rhythm Pro wheels. At that time, it weighed in at 29lbs. Now, I have the P35 up front and a Stans Flow in the back. I'd be surprised if I'm not up to 30lbs, since I think the current set-up is a bit more heavy duty. But the stock wheels and hubs never held up all that well and the traction upgrade to the 650b should make the weight gain well worth it.
    May 2010
    Sorry I know this thread is old but did you end putting a 650b on the rear?I have a remedy as well and am thinking about doing this conversion. Thanks
    Quote Originally Posted by [BTTW]BallsToTheWall View Post
    650b rear 29er in front.
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    ^^^ sweet tool boxes
    May 2005
    Quote Originally Posted by keen View Post
    What year Remedy? Are they all the same back there since the change to the ABP?
    Can you take some closeup shots of the stay and RD clearance.....or anything else that's really tight.
    Could you fit a 2.3 Neo-Moto in there?
    Oh....ride report please
    2013 Banshee Spitfire V2 650b
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Holy moly
    fitting a 2.2 wolverine in back to boot. Yeah more pics
    Reputation: Tkul's Avatar
    how does it handle?
    for me that is the future! or 26/650B up front!
    (although steel on 26ers...)
    Sail On!
    Reputation: Waterat Pat's Avatar
    I second that! Does it have enough clearance for muddy rides? Enquiring minds want to know.
    Would love to buy american as long as it works.
    Sweet, you have a Vic Hubbard sticker on your toolbox!!!
    Ok, so where is the ride report? I am turning my 2011 fuel EX into a 69er with a Maverick DUC so I will have 118mm travel up front and 120mm rear. I broke my top fuel 69er and the fuel ex seemed closer in geometry I will have the first ride Friday.
    So still no updates, looking for a new bike and the Remedy is near the top of the list. If it is 650B compatible...
    May 2005
    Fuel EX series no way, Remedy's big brother the Slash has plenty of room. Shop I went to recently didn't have a new Remedy but after looking at the Slash I'm hoping the Remedy would fit as well.
    Just be aware the Remedy BB height starts out at 13.9". Adding 650B will bring it to 14.4"
    Jul 2003
    Keen posted up a 650b/29er remedy in this thread - so it has clearance Clarence!
    Hello?
    Looks like the thread is dead, but would LOVE a response to some of the previous questions regarding clearance, etc., on the Trek Remedy 650b conversion.
    Quote Originally Posted by Master Slater View Post
    I have run a Pacenti Neomoto, WTB Wolverine and Kenda Nevegal 2.35 in the rear. Clearance is tight running the Kenda but it does clear upper seat stay brace by mm's.
    Awesome, thanks Keen!
    Other question: Did you have a particular fork that accommodated the 650b up front? Or was it stock? And what year is your Remedy?
    My 2010 Remedy is running a 29" front wheel. I have run 650b front's using a Rockshox Pike and Fox Float 36 - a few seasons ago. There are more options today.
    when that fork compresses all the way, ie, full travel, wouldn't your front wheel contact the downtube? curious.
    Reputation: OneEyedHito's Avatar
    Quote Originally Posted by skidad View Post
    That Bottom Bracket height is before Sag drop though so riding height is almost the same at 13.97 or so.....
    Keen have you had any issues running at full compression or mud clearance at all since trying this?! Replacement frame is enroute and I am really wanting to convert it to 650b I have all the components necessary just not the frame or knowledge that it is useable for real riding.....Almost forgot 2013 Remedy 18.5" Frameset.....Thanks in advance!
    Love the way the first post looks.
    Quote Originally Posted by OneEyedHito View Post
    Not a heavy mud rider. I run a 7.5" eye to eye shock vs. 7.75 so my BB height is about 13.6".
    Reputation: socalMX's Avatar
    Just picked up a 2011 carbon Remedy frame! So you mean to tell me I can set it up with my 2013 36 Float 650b with NO issues? I like running 2.35s front/back, whats the widest tire I can run out back?
    So does that give you a 140 rear travel? And it does look le the ardent 2.25" is a little taller side casing than I'd like. I'm at 2-3mm of clearance between the horseshoe and the tire.
    Nov 2012
    650b Trek Remedy
    I know this is an old thread but did anyone else put a smaller rear shock on their remedy? What are the downsides?
    Quote Originally Posted by Heath27 View Post
    A shorter shock will result in less travel & altered geometry depending on the tire combo & fork travel.
    Jun 2013
    It's funny how this thread came alive now. Trek has just announced a 2014 Remedy 650b!
    Nov 2012
    650b Trek Remedy
    Yea I know, kinda making me rethink this. If its an otherwise stock remedy, would the shorter shock slacken the bike out?
