Page 18 of 32 FirstFirst ... 814151617181920212228 ... LastLast
Results 851 to 900 of 1580
  1. #851
    Quote Originally Posted by fiddlr40 View Post
    Good to see another Bomba!
  2. #852
    Reputation: fiddlr40's Avatar
    Quote Originally Posted by LNBright View Post
    Thanks! I like your orange one -- the fastest color, you know.
  3. #853
    PSE
    PSE is offline
    Reputation: PSE's Avatar
    Oct 2012
    tested my wheels on a friends Kona Hei hei
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-2012-10-24-12.36.jpg
  4. #854
    PSE
    PSE is offline
    Oct 2012
    EDIT; uploaded some newer pics
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-2012-11-09-15.06.39.jpg
  5. #855
    650b me
    Reputation: golden boy's Avatar
    My UBI-built hardtail
    First ride photos...
  6. #856
    Dave
    Reputation: liteandfast's Avatar
    Nov 2007
    Quote Originally Posted by PSE View Post
    what about the brakes do they reach the rim? I have a VooDoo DJab 26er Ti and It looks like one would fit also. But I keep thinking that brakes wouldn't adjust that far down. Got to try it........
    I need to ride more and work less.
  7. #857
    PSE
    PSE is offline
    Oct 2012
    Quote Originally Posted by liteandfast View Post
    with the XTR v-brakes it didnt look like it would work, but these rims tested on has not a real braking surface, so if that would have been a bit wider and maybe som small amount of modifying of the brakes I dont think its impossible
  8. #858
    Feb 2012
    This thread is pure awesomeness...
    Quote Originally Posted by golden boy View Post
    ^^ you are a prime candidate for a bling ring. Drop that spider from your nice cranks!
  9. #859
    underachiever
    Reputation: misterdangerpants's Avatar
    Oct 2007
    My 1994 Rhygin 650B. For a full build thread, to here.
  10. #860
    My C'dale flash with 650b wheels.
  11. #861
    Reputation: skyak's Avatar
Name:	first ride (1).jpg
Name:	first ride (4).jpg
    Nice Ride!
  12. #862
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    + Rep for you, That is awesome.
    I have a 6 Berth Motorhome that I rent out . It is based in Tauranga, New Zealand
  13. #863
    Reputation: seat_boy's Avatar
    650B, the RC cola of the bike world:
    I have to admit, I stole that line from Grant Petersen of Rivendell fame.
  14. #864
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Hey mate. Would you happen to have photos of the chainstay area, to show tire clearance? I'm considering this frame, and will put a 2.1 Neo on there.
    Better to have and not need it, than to need it and not have it.
  15. #865
    Last pic before new frame. Old Schwinn Moab to be replaced by a Blue Pig.
  16. #866
    PSE
    PSE is offline
    Oct 2012
    Quote Originally Posted by r1Gel View Post
    Ok, here you go.
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-20121211_174015.jpg
  17. #867
    Reputation: sandyeggo's Avatar
    Mar 2011
    Quote Originally Posted by Lars K. P. View Post
    I love it! I've converted a Rush and had a Flash 29er. Didn't like it because it felt too big for me (I'm 5'6) and I kept getting pedal strikes. A conversion seems like a match made in heaven for me. Too bad Cannondale no longer offers a Flash 26 in the states..
    2015 Trek Stache 7 SS
    2015 Cannondale Bad Habit
    2015 Niner RLT
  18. #868
    NedwannaB
    Reputation: JMac47's Avatar
    If you have Stans 355 rims you can use Paul mx v-brakes that will adjust up to have pads hit the rim surface. Velocity may have some earlier style hoops that are rim brake compatible.
    Wait whuuut, who did he tell you that!?!?....
  19. #869
    Has a 120mm PBR Lefty right now. waiting on spacer from cannondale to get it down to 100mm. 22.5 lbs as it sits. My attempt at a budget race bike.
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-20121215_074213.jpg
  20. #870
    My new Intense Carbine 27.5
  21. #871
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Quote Originally Posted by gcohen View Post
    Whoa... Enve, XX1... Which rich relative did you knock off to score that?
    That is sick!!! Ridden it yet? let us know how you think it might hold up as an XC racer.
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
  22. #872
    Quote Originally Posted by mattsavage View Post
    I got a ride in on Friday. Bike is absolutely insane. I could not be happier. It weighs 26.5lbs as it sits in those pics. With lighter tires and a carbon seatpost rather than the dropper it could be sub 25lbs. I think in that setup it would be an amazing xc bike.
  23. #873
    Dec 2012
    Nice bike! What does it weigh?
  24. #874
    Dec 2012
    Oh, never mind - didn't see your last post with the weight.
  25. #875
    Dec 2012
    My new-to-me 650B FM-136 with SRAM X0 2x10 grip shift setup, light-bicycles.com 25mm 650B tubeless wheels w/Novatec DS811/812 hubs, Schwalbe Rocket Ron tires, Rockshox Revelation XX 650B fork. I plan on using it for XC racing and general bombing around.
  26. #876
    What bike shop is that picture taken in?
  27. #877
    Quote Originally Posted by procos View Post
    Briarcliff Bikeworks in Briarcliff NY. They are great.
  28. #878
    Reputation: vizsladog's Avatar
    Morph very Nice 650 hardtail.....very nice
    that intense is sick also
  29. #879
    @morphtcat: Nice setup, my next project is based on that frame, do you have a picture of the rear tire clearance ?
    Did the frame weight as low as expected?
    Thanks!!!
  30. #880
    Dec 2012
    Quote Originally Posted by dagcosta View Post
    Thanks!!!
    No sorry I don't, but it's pretty good clearance. The frame came in at about 1050 grams if I recall correctly. The entire bike is around 21-22lb. If I could use a SID fork, the bike could get down to about 20lb, maybe less.
  31. #881
    bump and grind
    Reputation: cobym2's Avatar
    Apr 2005
    Old voodoo d-jab
    Rebooted as a 650b
    Voodoo D-jab Ti, Fox Van 140 R (once with a F29 120 RLC), Hope hubs, Notubes 355 650b rims and DT champ spokes, Pacenti Neo 2.3 front and WTB Wolverine 2.2 rear, Old school Suntour 8 speed cranks, 8 speed XTR 950 gear. Its quite tall, but I think I like it.
  32. #882
    Dec 2009
    My WR upgraded with No Ni's. Needed 3mm shock shim and cable tie around fork staunchion to accommodate the taller tire, compared to a neo 2.3.
  33. #883
    Dec 2012
    Quote Originally Posted by morphtcat View Post
    I measured the clearance - it is 1.5 inches.
  34. #884
    2650b : )
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-2012-11-21_14-55-36_568.jpg
  35. #885
    Dos: 140 up front
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-2012-11-22_12-49-04_904.jpg
  36. #886
    NedwannaB
    New treads
    Quote Originally Posted by gvs_nz View Post
    How are the NN's working out for you?
  37. #887
    Reputation: dhbomber's Avatar
    Nov 2006
    Converted On One Whippet! Very cool bike! 22.2 lbs
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
  38. #888
    Reputation: RSAmerica's Avatar
    Jamis Dragon 650
    White Brothers Loop TCR 650B Fork, XT Groupo 2 x 10, Chris King Head Set, Chris King Hubs/Stans ZTR Chest rim, Schwalbe Nobby Nic 2.35,
    XTR Pedlal, Kent Eriksen Sweetpost Seatpost, Ritchey Stem, Easton Haven Carbon Handle Bar
    Head Badge: Tribute to Fat Chance Yo Eddy
    Attached Thumbnails Attached Thumbnails 650B Picture Thread-jamis-dragon-650b.jpg
  39. #889
    MTB NOLA
    Reputation: vudu's Avatar
    2010 Lynskey Ridgeline SS
  40. #890
  41. #891
    The Crow
    Reputation: Iwan's Avatar
    My Momsen SL650B
    There's a feeling I get
    When I look to the West
    And my spirit is crying for leaving
  42. #892
    Reputation: Motomatt's Avatar
    New question here.
    That is awesome,I like your 650b what is the stand over height?
  43. #893
    Heres mine
    Kent Eriksen TI 650b hardtail
  44. #894
    Dec 2005
    @Motomatt
    Do you mean Iwan or someone else?
  45. #895
    Feb 2012
    The Red Fox is back. On one 456C with a 2x9 drive train.
  46. #896
    New question here.
    Nice bike What is the stand over height ?
  47. #897
    Quote Originally Posted by Kili@n View Post
    @Motomatt
    I meant morphtcat;9979607 sorry for bad post
  48. #898
    Mar 2012
    Coooooooooool
  49. #899
    PSE
    PSE is offline
    Oct 2012
    New picture of the Scale:
  50. #900
