Results 1 to 6 of 6
Thread: 650B Lefty
    Nov 2012
    650B Lefty
    I bet this has been asked a lot, but I want to build a 650b hardtail with a Lefty fork. Do I need a 26er or a 29er fork and why?
    They're exactly the same fork, just travel is reduced internally to prevent fork from bottoming out...
    You need about 10-20mm more travel than you want from a "26" lefty so that you can reduce it to the correct size. Or, 10-20 less on a "29er" since you will be adding travel... e.g. if you need 120mm, an xlr 130 (labeled for 26) or a xlr 100 29er would be useable, and are equivalent.
    And yes, this has been covered. A lot.
    Quote Originally Posted by sickspeed16
    Your not all mountain unless your runnin' crushed dew cans..
    '12 Scalpel 29er Carbon 1
    '13 SuperSix EVO Red Racing
    i think you can go all the way up to a 28" tire without limiting the travel. come to think of it i should check that. 27 9/16 for sure rode all summer on that
    i'm thinking of swapping my lefty speed to a lefty ultra xbr with 120mm travel on my rush 650b.
    anyone else have issues with changing the geometry?
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    I have been running a Lefty MAX 140 on my Prophet with 650b wheels for a couple of years. No reduction in travel, no strikes. I have Neo-Moto 2.3's front and back.
    Is the axle to crown different on the speed and ultra xbr? I think the Ultra is longer so the bike would be more slack if you swap.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Reputation: Jetman46's Avatar
    Oct 2007
    I put a lefty on a Ventana a few years ago. I got it from Project 321, they can help you out.
  1. Replies: 16
    Last Post: 02-13-2013, 10:38 AM
  2. 650b Lefty fork
    By Hurricane Jeff in forum 27.5
    Last Post: 01-29-2013, 10:20 AM
  3. 650B x C-Dale Lefty
    By coconinocycles in forum 27.5
    Last Post: 04-20-2012, 10:35 AM
  4. 650B x 2009 Lefty RLC
    By superfred in forum Cannondale
    Last Post: 04-20-2012, 08:29 AM
  5. hey Lefty + 650b peeps...
    By ohpossum in forum 27.5
    Last Post: 07-24-2011, 06:12 PM
