Results 1 to 8 of 8
    Feb 2005
    27.5 v/s 29er for hardtail trailbike
    I'm only 5'6" and have been riding small XC 29er bikes. It's a fast riding bike but I watch my line and stay on point because of the unforgiving geometry. I was thinking of building up something aggressive with a 120 or maybe a 140mm fork and wide rims. It will be geared since I have a 29er SS.
    [COLOR="Black"]HARDMTNBIKER on Instagram
    Seven Sola SLX ENVE MTN SS
    Sir9 Carbon Niner SS
    #1gearallyear #Iridemtn
    Wrench
    Reputation: FNFAL's Avatar
    For the sake of something different, try the 650b. 2.3" tires and a 120mm fork. Maybe a steel frame.
    Look at the Jamis Dragon. Fantastic frames.
    29 front/650 rear?
    Seriously--then you get the stronger, stiffer, lower-gear-ratio wheel out back, along with better cornering traction and rollover up front where you want it. (And you increase the odds of fitting a high-volume rear tire with a front derailleur, which is good for the fast, rocky trails of the San Gabes front country.)
    Feb 2005
    I like steel, I was thinking of the Kona Exsplosif. It's has a pretty good build,I'd only change the fork and wheels. The Dragon ups the Kona with the 853 steel. Does Jamis have 142x12 rear axle?
    I've got an Explosif. Great riding bike, great geometry--with one exception. The 2013 model bb is super low @ 11.75" with the stock 120mm fork. Most of the time it's not an issue, but climbing on, say, Sam Merrill--or virtually any San Gabes canyon trail, for that matter--sets you up for pedal strikes. Pedaling in the rocks is not the frames strong suit unless you run a longer fork to compensate for the bb height.
    Feb 2005
    I could build it with a 140mm fork that would raise the BB. I think I'd go for that before putting a 29 wheel in front.
    Yeah, I think 140mm would be about right for the Explosif.
    A waste of time it is is
    Reputation: emu26's Avatar
    Yeah I know steel is real and all but for a hardtail that meets what you are talking about I really think you are hard pressed to go past an ON-One 456. Happily takes a 140mm fork, forgiving geo, strong as an ox and at that price in the link, really what have you got to lose? Yes, it will take 650b
  1. Eternal question: Arch ex or flow ex for 29er trailbike???
    By unrooted in forum Wheels and Tires
    Last Post: 09-03-2013, 03:40 PM
  2. Replies: 6
    Last Post: 03-15-2013, 10:58 AM
  3. Go 29er or long-travel 26er trailbike?
    By Cayenne_Pepa in forum General Discussion
    Last Post: 11-20-2012, 11:24 PM
  4. 29er Hardtail Trailbike Search
    By blackbart in forum 29er Bikes
    Last Post: 04-09-2012, 07:01 AM
  5. Replies: 3
    Last Post: 10-20-2011, 05:33 PM
