Results 1 to 19 of 19
    Jul 2013
    27.5 bike frame that will fit 2.6 tire
    Hello all,
    I am looking for a list of 27.5 bikes that will accommodate the 2.6 tire width. Pardon me if I missed a past post discussing the same topic. Thank you for all the great information. You all have been a terrific resource.
    Reputation: MSU Alum's Avatar
    My Yeti SB5 V1 fits a Rocket Ron 2.6" 35mm id rims on the back and my wife's V2 fits it even more easily on 29mm id rims. I expect I could get a 2.8" on hers, assuming dry conditions.
    Apr 2017
    the guerrilla gravity shredog accommodates a 2.6 wide tires with 145mm rear travel.
    Jul 2013
    Thanks for the feedback. I checked out a few other threads but did't see anything specific to this topic. Is is uncommon to have a max tire width named? As you may suspect, I am looking for a 27.5 that will meet this criteria.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Quote Originally Posted by Hayes View Post
    Max tire width? Do you mean volume 2.6, for example? or at the bead? If you're talking clearance between the stays, then 100% of 27.5" bikes will accommodate 26" wheels and tires. It just depends on the volume and how much clearance you're looking for.
    Tell us what your goal or intended use is and we may be able to provide better answers.
    JPark - 3.5- don't listen to dremer
    Quote Originally Posted by Ken in KC View Post
    I think he just wants to know if tires that are labelled 27.5x2.6, will fit, not if 26" tires would.
    Feb 2015
    Devinci Django 27.5
    May 2012
    Ibis Mojo 3 27.5 from 2.35 to 2.8" Width. Mojo HD3 & HD4. Santa Cruz 5010 V2, I think someone have ran the Maxxis Rekon 2.6". I squeeze a schwalbe rocket ron to the Giant Anthem Advanced on a 35mm IW rims. 2017-2018 Giant Tranced
    '18 SC Tallboy CC_Wife
    '17 Giant Anthem Adv_Kid
    '17 Ibis Mojo 3
    '17 SC Bronson CC
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Knolly's Endo fits the new 2.6" tires. They list 2.5" as max, but the 2.6" Forkaster fits fine with 35i rims.
    Sep 2014
    Pivot Mach 5.5 comes standard with 2.6 tires so I imagine they'd fit on that bike.
    You can't buy happiness. But you can buy a bike. And that's pretty close.
    Sep 2015
    Alu 27.5 Norco Sight here with 2.6 clearance. Best to dish the rim over just a little to non-drive side.
    Prob worth keeping in mind that Norco are one brand that alters chainstay length with frame size.
    Quote Originally Posted by MSU Alum View Post
    D'oh! Thanks.
    Yes the Pivot Mach 5.5 fits 27.5 x 2.6 tires!
    Aug 2017
    Hello all,
    As long as the bike is Boost Spec, meaning the hubs are 10mm wider than standard, the frame and fork will hold a 2.6. It ill also fit a 29er so long as you keep the tire size smaller than 2.25.
    Jul 2013
    Msu alum: that is exactly what I am looking for.
    Zacklawhon: Perhaps I should have phrased my questions by asking for the bikes that are boost spec if that is what is needed for the wider tire.
    Thanks for all who contributed. 2.6 is great and 2.8 is better! Id like to avoid the premium cost on the boost bikes may if the frame can handle it the width.
    I am a weekend warrior kind of rider. I guess I should brush up on the proper technical terms.
    At any rate, great feedback. The 5010 sounds like it could fit the bill and is available locally. The Pivot is gorgeous but more than I need and out of my budget. Keep-em coming and thanks again!
    Apr 2017
    the guerrilla gravity Shred dogg can actually go up to 2.8's. I was mistaken before with the 2.6 width, that was for the megatrail which is 150/165mm rear travel.
    Feb 2015
    Max tire size on the 5010 is 2.5 according to the SC website. I had one and the 2.5 WTB Breakout was a tight fit.
    Good info here. Not all boost frames will fit 2.6s so model specific to info is helpful.
    2016 Cannondale Habit SE. 2.6 Swchalbe Rocket Ron on Stan's Notubes Flows MK3.
    Attached Thumbnails Attached Thumbnails 27.5 bike frame that will fit 2.6 tire-20170715_091556.jpg
  1. Replies: 2
    Last Post: 10-13-2013, 10:20 AM
  2. Is Road bike fit the same for MTN bike fit??
    By !TREK4ME! in forum All Mountain
    Last Post: 12-18-2012, 12:58 AM
  3. Tall hardtail frame that will fit a 2.5" tire
    By Sasquatch1413 in forum Clydesdales/Tall Riders
    Last Post: 07-14-2011, 02:42 PM
  4. Tall hardtail frame that will fit a 2.5" tire
    By Sasquatch1413 in forum 29er Bikes
    Last Post: 07-11-2011, 06:35 PM
  5. I need a little tire help, tire fit
    By jormar23 in forum 29er Bikes
    Last Post: 06-10-2011, 05:10 AM
Members who have read this thread: 19
