Page 12 of 15 FirstFirst ... 2 8 9 10 11 12 13 14 15 LastLast
Results 276 to 300 of 359
  1. #276
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by cloudbuster View Post
    650 with good spec seem to be way overpriced still
    Correct. My enthusiasm has dampened the more I review the prices and the more it appears that some of the bikes will be difficult or impossible to get even if you have the coin.
    I can wait a year for this mess to sort itself out. Maybe by then the big companies will have 27.5" offerings, thereby increasing supply and choices, and reducing prices.
    Old enough to know better. And old enough not to care. Best age to be.
  2. #277
    Reputation: jazzanova's Avatar
    Same here. Let's add some bastardos!
  3. #278
    dwt
    dwt is offline
    Quote Originally Posted by daves4mtb View Post
    The Bastardo was no conversion! But a fun bike nonetheless
    Emphasis on was. AFAIK, Ventana now is selling only the bigger travel AM bike Zeus in 27.5"
  4. #279
    When I mentioned a "bastardo" I did not mean the Bastardo.
    I was thinking more of a bike born of 2 different parents, a 26er frame and a 650b wheel
  5. #280
    Jan 2013
    Any reason why the range killer b was not included in the roundup? Is it too similar to the sight? Only asking cause both intense's were included
  6. #281
    May 2005
    I thought at some point he mentioned he had a Range also but perhaps he's waiting to compare it to the 650 Banshee Rune which should be arriving at some point (Pink Bike has it now). At any rate Francois did mention this shootout will be a kind of work in progress as each new 650B bike becomes available to him for testing. Also absent was the Rocky Altitude (which many people were waiting for), Ventana Zues, Banshee Spitfire, and maybe a few others. For kicks I would like to see him compare the dedicated new 650 bikes to some good conversions like a Mojo HD and some of the Santa Cruz bikes (and you have to think SC is going to jump in soon with so many of their bikes being converted)
    2013 Banshee Spitfire V2 650b
  7. #282
    Quote Originally Posted by wipp View Post
    Pricey Eh!
    The frame only has a better shock than the B3, but I think amazingly thats it...
    Just interested, which shock is included with the "frame only" package?
    Also is/was there something else included, as someone mentioned that a reverb would be included with the frame only -set...?
  8. #283
    Is the Burner going to be added to the shootout and if so, do you know when?
  9. #284
    Subscribed.
    http://kevinboyer.zenfolio.com/
    *2015 Knolly Warden...Custom Build*
    *2014 Knolly Endorphin...Custom Build*
  10. #285
    Mar 2013
    Nice start on the reviews Francois!
    Any idea what the weight difference is between the Norco Range frame and the Sight?
    Thanks.
    Have you received your Range yet wipp? What is the frameset weight? Anyone know what the Sight frameset weight is?
  11. #286
    I ended up going with a Ventana Zues:
    Bike came in at under 29lbs dropper seatpost and peddles included.
    Quote Originally Posted by coffeeme View Post
  12. #287
    So...were those couple of awkward videos, which contained nothing but opinion, the entire extent of this "shoot out", or is something more thorough coming??? The videos were more about the components than the frames.
    whatever...
  13. #288
    Mar 2013
    Yep, I joined just to make this quote: "I have been left wanting!"
  14. #289
    Reputation: batts65's Avatar
    Nov 2006
    I hope there is more to come, I already bought a Carbine 275 but it is interesting to hear about other bikes. Vital is doing a trail bike review and they are putting up a different bike just about everyday. It is 26, 27.5 and 29ers, they have already done a review on the Tracer 275 and the Range Killer B and I thought their reviews were very well done.
  15. #290
    Mar 2013
    Why are they called 650b instead of 27.5" like 26 and 29?
  16. #291
    Oct 2012
    Apparently the new term (according to MBA) is a flat 27". Fine with me.
  17. #292
    Yeah, MBA (and Scott) can stuff their 27" nomenclature in a dark pit of despair. 27" is what old Schwinn and Raleigh road bikes use, and are still common enough that most bike shops will carry appropriate tires. If we want to see shops take up the 650b/27.5" tires as a stocking part, lets not confuse the customer from the get go.
  18. #293
    Oct 2012
    Quote Originally Posted by zombinate View Post
    Uh, can I get some of what you're smoking? Just give me what I want and label it simply enough for you to understand.
  19. #294
    650b All Mountain Bike Shootout
    Citing MBA as your source may lead to credibility problems.
    650b is the original name for wheels with 584mm Bead seat diameter....comes from a time when wheels (in mainland Europe) were measured by the tire's outside diameter (650mm in this case), and the letter corresponded to differing tire sizes.... So 650a, b, c would all have the same outer diameter, but 3 different tire volumes and rim diameters. And yep, there was a time when there were 700a, 700b, and 700c too.....but the a's and b's fell by the wayside.
    27.5" is accurate enough, unique enough, and in keeping with other Mtb convention that it will likely stick.
  20. #295
    How is that shootout coming along, Francois? craving info/opinions
  21. #296
    Oct 2012
    "27.5" is accurate enough, unique enough, and in keeping with other Mtb convention that it will likely stick. "
    I just want fewer syllables!
    On a pertinent note, where are the shootout results? Is this a dead project?
  22. #297
    Quote Originally Posted by AgentPhatrick View Post
    How 'bout "Six Fiddie"
  23. #298
    Reputation: SteveF's Avatar
    "Two seventy five" is one more syllable than "twenty nine er," if that works for you. I spend lots more syllables explaining the whys and wherefores in trailhead conversations than I do just saying it. B-)
  24. #299
    Reminds me of this old SNL skit:
    SNL Transcripts: Jason Patric: 01/08/93: The Road To Self-Improvement
    To ride this trail is completely free.
    Just show me a triangle..... make it three!
  25. #300
    Reputation: twowheelsdown2002's Avatar
    I just converted my Firebird to 650B, and I would put it up against any of these bikes, and I did not have to buy a whole new bike to do it.
  1. Mountain bike in north Vietnam ? the best adventure mountain bike
    By bikingvietnam in forum Vacations & Destinations
    Last Post: 06-11-2013, 02:46 AM
  2. 650b All Mountain Shootout
    By fc in forum All Mountain
    Last Post: 11-01-2012, 02:16 PM
  3. Replies: 0
    Last Post: 10-30-2012, 10:48 AM
  4. Best am shootout
    By Artin Aga in forum All Mountain
    Last Post: 09-08-2011, 10:07 PM
  5. 2011 Bike Park Shootout
    By nitecrwlr in forum Colorado - Front Range
    Last Post: 03-25-2011, 10:38 AM
