Results 1 to 12 of 12
    Sep 2013
    26in tubes in a 650b?
    Is this a good option or should I always try to use a 650b tube when possible? Just want to verify. Thanks!
    Reputation: NZPeterG's Avatar
    Good job!
    Hi 26" tube's will work great in any 650B tyre's.
    I used 26" tube's in 29"er's for year when there where very few 29"er's made.
    Go for it.
    Pete
    Sep 2013
    Quote Originally Posted by nzpeterg View Post
    hi 26" tube's will work great in any 650b tyre's.
    Go for it.
    Pete
    thanks!!
    easy fit
    I'm running Maxxis 26" flyweight 1.95-2,125 (95g) in my wheels with 2.0-2.1 Kenda tires. No issues at all but I bet they are pretty thin (0.45mm in 26" size) lol.
    A lot lighter than a standard 650b tube.
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    Running standard-weight 26" tubes in 2.00-2.25" 650B tires with zero issues.
    GRAVELBIKE.COM - ride everything
    Reputation: PuddleDuck's Avatar
    For 7 years I used lightweight Maxxix 26 tubes (~125g) on my 29er. Never had a problem. If you use a good quality tube you'll be fine.
    I usually run 26" tubes but make sure the tube doesn't go under the tire bead or it will take the tire right off the rim. I was airing up one of my first conversions, using an air compressor , filling full steam ahead. Got just over 20 psi and I saw the tire bead coming up / off rim and the tube starting to poke out. Before I could even put the tire inflator down the tire was un-beading and more tube was coming out then BLAM tube popped ringing my ears. I now always inflate slowly making the sure the bead stays over the tube. I will say I have had a couple close calls if I was rushing. That said all my future tube purchases will be tire size specific.
    Apr 2013
    Go tubeless. My tubes just sit in the bottom of my camelback now. Can't tell you last time I got a flat.
    Sep 2013
    That's where I would like to be eventually! I just wonder if tubeless issues are worth it...
    Quote Originally Posted by Bronsondude View Post
    You better knock on wood!
    Jun 2012
    Totally worth it.
    Reputation: michael9218's Avatar
    Interesting that a 26" tube can fit in a 29" rim. I wondered about that since I ride a 9er'B. I just assumed I should carry a 29" tube. Though I never get flats. I converted to tubeless a couple years ago and have only flatted once since making the switch. Sliced the sidewall on a new tire. I use tubeless ready tires, not UST tires.
  1. is the any 26in DJs available anywhere?
    By OrangeDevil in forum Urban/DJ/Park
    Last Post: 07-01-2013, 11:48 AM
  2. 650B - 27.5 mtb tubes in Durham or Toronto GTA?
    By morkys in forum Eastern Canada
    Last Post: 02-02-2013, 07:33 PM
  3. 26in>650B conversion thread.
    By colker1 in forum 27.5
    Last Post: 11-25-2012, 02:38 PM
  4. Inner tubes for 650B wheels?
    By thunderbolt413 in forum 27.5
    Last Post: 05-23-2012, 05:57 AM
  5. Question about 650B Tires and Tubes
    By Ratman in forum 27.5
    Last Post: 02-14-2011, 04:50 PM
