Results 1 to 5 of 5
    26'' wheel on a 27.5'' fork?
    Any reason why I can't or shouldn't go back and forth between 26 and 27.5 on a 650 b specific fork? I suppose a 26 might steepen the angles a bit, but assuming that wasn't a problem.
    undercover brother
    Reputation: tangaroo's Avatar
    Quote Originally Posted by outlierrn View Post
    If you're going to put 26" on the rear too, there shouldn't be any change in angle really.
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    It may slacken the HTA a bit if the fork has a taller A2C than the same 26" fork (assuming you are running 26" on both sides). Should give you a nice tall arch to run meaty 26" too.
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    You'll need to take into account the axle to crown measurement and see if it suits your frames geometry.
    Jan 2005
    does anyone know the fork offset for the Fox 650b forks vs, 26er forks?
  1. Need wheel swap help for new fork
    By coling in forum 29er Components
    Last Post: 02-21-2013, 05:06 PM
  2. Wheel Fork
    By stumpy6 in forum Cars and Bike Racks
    Last Post: 11-29-2012, 04:19 PM
  3. Wheel/Fork Organization
    By crazybeach in forum Tooltime
    Last Post: 10-26-2012, 02:50 PM
  4. AM hub, fork, and wheel build?
    By TrailNut in forum Shocks and Suspension
    Last Post: 10-26-2012, 12:47 PM
  5. Wheel wants to go one way, the fork the other!
    By Finch Platte in forum 29er Bikes
    Last Post: 03-15-2011, 05:24 PM
