    Apr 2018
    2018 specialized pitch tubeless conversion
    What is the best way to convert? Do I just need rim tape and a stans valve? Or do I need to but the rubber strip with the valve attached?
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Gorilla Tape tubeless values Stan's or what ever you like better.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Mar 2018
    Like said above. Other than that just look a few youtube videos about it before you do anything.
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    I'm not familiar with those rims/tires.
    Wire bead tires - are they tubeless compatible (says 2bliss on the side)? If not, they'll need more sealant or may not work at all. Others may have experience with your particular tire. If the tire doesn't work well, you may want to wait until they're worn out before converting.
    See how tight the tire bead fits when it's deflated first. If it's loose you'll want the gorilla tape to help it fit tighter. Otherwise, any of the tubeless tapes in the correct width (add 2-3mm to the inner width of the rim) should work.
    +1 for watching several vids to get the idea of how to do it first BEFORE you start. It's easy to overlook something simple and get frustrated when you're new to tubeless.
  1. 2018 Pitch Comp vs Rockhopper Comp
    By NigelMTB in forum Beginner's Corner
    Last Post: 03-29-2018, 05:48 AM
  2. 2017 or 18 Pitch comp verus 2018 Rockhopper comp
    By twentysevendays in forum Beginner's Corner
    Last Post: 02-02-2018, 05:33 PM
  3. 2018 Specialized Pitch 27.5
    By bronco5 in forum Families and Riding with Kids
    Last Post: 12-28-2017, 08:21 PM
  4. 2018 pitch comp vs Rockhopper sport
    By krel in forum Specialized
    Last Post: 11-22-2017, 09:33 PM
  5. used Specialized pitch vs. used specialized stumpjumper
    By jbourne84 in forum General Discussion
    Last Post: 02-09-2013, 07:28 PM
Members who have read this thread: 30
