Thread: Wheel set build
    Reputation: jet fixer's Avatar
    Feb 2006
    Wheel set build
    I'm thinking of converting an 08 Turner RFX with a Vanilla 36 fork to 27.5 but I'm having trouble making up my mind on rims and spokes. I'd also like to know if I can get away with alloy nipples.
    Spoke short list:
    DT Competition 2.0-1.8-2.0 stainless steel butted spokes
    or
    DT Champion 14 Gauge Spokes
    Rim short list:
    Stan's flow
    or
    Velocity blunt 35
    For tires I'm planning on Schwalbe Hans Dampf 2.35
    Any insight would be appreciated before I drop a huge chunk of change on these wheels.
    Too fat for XC, and not skilled enough for FR
    Jan 2011
    Competitions because they are butted, unless your pinching pennies.
    Flows seem to get better reports than blunts, but i've not had the flows or blunts.
    I have had good experiances with Stans rims though. Maybe you should consider the Pacenti DL31 as well..
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Wreck the malls with cows on Harleys
    Feb 2006
    Quote Originally Posted by guggas View Post
    My wheel builder doesn't stock pancenti so I never looked at them. I had a wheel set built about 10 years ago from universal cycles those wheels have been on three bikes and been abused; still have not needed to true them. I think I'll stick with what they stock I've had them build other wheels for me and the results are similar. I was a little concerned about the DT comps flexing, it might just be the old Mavic 721's I'm using. can you use a caffelatex kit with stans rims? I see the valves are a little different.
    Quote Originally Posted by jrm View Post
    Yes it does, with the photo's in the link I see I'm good on clearance in the rear. From what I've read the Fox 36 should handle almost anything.Think I'll resurrect that old thread for feed back.
    Now I just need to wait until Universal gets some navy CK hubs in-stock then Iwill be able to press on.
    I appreciate your help
  1. First wheel build
    By ianick in forum Wheels and Tires
    Last Post: 11-05-2012, 09:28 PM
  2. 32h hub and 36h rim wheel build
    By lgoldie10 in forum Wheels and Tires
    Last Post: 10-22-2012, 10:32 AM
  3. Wheel build
    By woodsey1 in forum Wheels and Tires
    Last Post: 09-15-2012, 01:41 AM
  4. first wheel build
    By brankulo in forum Wheels and Tires
    Last Post: 09-28-2011, 07:54 AM
  5. New wheel build: ZTR to CK
    By mhopton in forum Wheels and Tires
    Last Post: 09-27-2011, 02:48 AM
