Results 1 to 7 of 7
    What size rigid fork to use 26 or 29?
    I am thinking of converting my son's bike into a 650. It is a 26'er right now. If I go rigid with the front fork do I use a rigid 26'er, or a rigid 29'er. I don't know if this is a stupid question or not. It seems like one, considering it is a 26'er and not a 29'er. But hey I just don't know, and it's late and I'm tired. Thanks for the help.
    P.S: the bike is a DB. in case it makes a difference.
    Just remember,Where ever you go there you are...
    Reputation: JonathanGennick's Avatar
    Not really a dumb question. If you use a suspension-corrected rigid fork, then a 26er might be a better fit. FWIW, my Surly Karate Monkey 29er rigid fork is only about 3mm different from my Surly Instigator 26er rigid fork. The reason they are so close is that the 29er fork corrected to 80mm, whereas the 26er is corrected to 100mm.
    Obviously you want the tire to fit inside the fork. Then you want the axle-to-crown to be in the zone for which your frame is designed.
    Thanks Jonathan. How much width is needed to accomadate a 650b tire(both F/R).
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    Quote Originally Posted by kitts21j View Post
    the kenda nevegal 2.1 650b tire in my opinion is the shortest tire and has
    the minimal width, so going with thsoe may be a safe bet.
    I have three 26" forks I run 650b wheels on. All 3 can run a Neo Moto 2.3 with no problems. The forks are a Kona Project 2, an Origin 8 Black Ops Carbon, and a Redline Monocog fork. The Origin 8 fork has the most clearance, followed by the Redline fork. If you want something cheap, try the Redline option. I run a Nevegal 2.3 in that fork with plenty of clearance.
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    If yur interested I got a Haro Beasley rigid fork unused I could sell.
    Reputation: MMcG's Avatar
    Jul 2003
    Quote Originally Posted by JonathanGennick View Post
    Instigator and Karate Monkey are more than 3mm different.
    Karate Monkey fork = 468mm
    Instigator Fork = 447mm
    That's a grand total of 21mm difference.
