• 11-20-2012
    myitch
    What Large Volume 650b Tires Clear a TRc and X-Fusion Velvet?
    I'm going for the 650b conversion on my TRc. But before spending $60-$80 per tire, I'd like to know what large volume tires clear.
    I like aggro tread and high volume and would hate to spend those dollars if there werent much clearance. The Schwalbe NN and R. Ralphs look good on their website but what widths are they? From the pictures, it looks like the NN is good for front and RR for rear.
    What tires have been tried and trued?
  • 11-21-2012
    Gripo
    Largest I've had in the back of the TRc is a 2.35 Nevegal and the new 2.35 Nobby Nic.....maybe 7mm of clearance, dry weather only.
  • 11-21-2012
    myitch
    What rim was the tire on? How you liking that 650b TRc and NN tire? What you have up front?
  • 11-21-2012
    Gripo
    Probably had one, if not the first conversions I know of back in September last year.
    First off with American Classics and RaRa then I had 2 sets of Stans Crest/Hope hubs again with RaRa for trailriding and the 2nd set of wheels with 2.35 Nevegals for shuttle days.
    Both tyres I mentioned in the my other post are on Stans Crest.
  • 11-21-2012
    StiHacka
    Which Velvet, which year? I have a 2011 (or 2010) Velvet RL without the 605b shim and when fully compressed, a NeoMoto 2.3 on Alex XD Lite (a narrow rim) just clears the crown. With the shim installed, you should have plenty of clearance for the biggest tires.
  • 11-21-2012
    skidad
    The new NN 2.35" tire measures 2.3" with my caliper so width is no issue. About 711mm tall though (almost 28") and this is where you'll need to shim the shock even more on a TRc if you want to run that tire. The Velvet or a regular Fox fork would need to be shimmed or you would have crown contact at bottom out.
  • 11-21-2012
    myitch
    What do you mean even 'more'? More than what? I plan to run a NN or HD on the rear of my TRc so your words of experience are appreciated.
  • 11-26-2012
    myitch
    Even more?
  • 11-26-2012
    StiHacka
    Originally Posted by myitch View Post
    Even more?
    This goes back to history. You should be able to find threads about rear shock shimming for NeoMoto 2.3 clearance for a bunch of frames. Neo 2.3 used to be the benchmark tire for conversions. I am guessing that by even more, Skidad means more than what was discussed in the past as sufficient for it.
  • 11-26-2012
    jayoutside
    Everything I've read so far states that the nobby nic 2.35's are much bigger than the neo-moto. As someone who is looking to B a TRc, I' think I'm going to go nobby nic 2.25 in rear b/c I THINK what skidad meant is that the schwalbe tires are bigger than the pacenti's thus requiring more travel limitations.
    from what I read from a poster's conversion, Shimming the shock 3mm reduces travel by almost 10mm. I don't want to loose any more travel than that.
  • 11-26-2012
    myitch
    Oh, that's what I was afraid of, losing more travel to accommodate bigger meats. We're already going to have to shock shim for any 650b tire. It's not like 125mm is a ton of travel already and to lose more is just not worth it. I think I'll have to go the 2.25 route also for NN. Now that might be too small compared to the 2.35 HD I plan for up front. It might be a motocross bike...
    Just how much bigger are the 2.35 NN than the largest Neo Moto anywaz?
    Wait a minute. On bikediscount (Germany) the NN's aren't available in a 2.25. Are they elsewhere?
  • 11-26-2012
    mestapho
    I have a NN coming on Wed. so I'll take some before and after pics of the difference in clearance (currently on a Neo moto 2.3) I don't plan on adding more than the 3mm of shims I already have.
  • 11-26-2012
    StiHacka
    Yup, here you go - Schwalbe Nobby Nic 650b/27.5"" x 2.25 Tubeless Ready Folding Pacestar Tires - Pro Bike Supply
  • 11-26-2012
    myitch
    dang. $20 more than bikediscount's 2.35 NN. is this the cheapest price around?
  • 11-26-2012
    jazzanova
    subscribed
    subscribed
  • 11-26-2012
    StiHacka
    How much do the Germans charge for shipping? The last time I ordered RaRas from Germany, shipping was like 50% of the total.
  • 11-26-2012
    OldManBike
    I paid $26.48 shipping on 4 schwalbe evo tires from bike-discount the beginning of the month. (And still am waiting for them to arrive.) Order worked out to $46 a tire shipped.
  • 11-26-2012
    skidad
    Yes, that's exactly what I meant. Thanks StiHacka :thumbsup:
    The Nobby Nick 2.35 measures about 711mm in diameter where the Neo Moto measures approx. 698.5mm. A Nevegal 2.35 is approx 704mm and my WTB Wolverine 2.2's are also approx 704mm in diameter.
  • 11-26-2012
    myitch
    What size you planning on putting back in the rear? Pics would be great and very helpful. My 650b wheels are on the way and I need to order tires soon.
    I plan to go 2.35 HD front and would like a 2.35 NN rear, but I'll wait to see what you're running. Thanks
  • 11-26-2012
    pwu_1
    I test fitted a 2.3 Neo Moto on the rear of my TRc the other day and it was a super tight fit already. I shimmed the shock using 3mm of washers and even then at full compression the tire just buzzes the front derailleur cable and the wheel was somewhat tough to install due to the axle hitting the derailleur hanger when you are trying to put the wheel on.
    If the NN 2.35s are any bigger in diameter than the Neo Motos then I don't think they would fit.
  • 11-26-2012
    myitch
    Well, then. No go on Neo Motos. Thanks for that info.
    What's the "next" biggest tire then for the TRc rear? The NN 2.25? What did Francois use?
  • 11-27-2012
    mestapho
    The 2.3 Neo Moto works fine on the rear of a TRc. I've bottomed my shock out plenty of times with it and haven't had an issue. It did buzz my Big Air tire inflator that was in my seatpost. I just flipped that upside down. I have pics around this thread or on the SC TRc thread of the tire clearance with the TR. Just off the top of my head it's about .25-.3" of clearance in front of the tire and about the same on the sides.
    I do have my shock shimmed 3 mm's.
    I'm not convinced its needed as I don't think you can achieve full compression of the shock with it aired up. I figured it's cheap and easy insurance so I shimmed it anyways. There is no noticeable change in the ride with the shims.
  • 11-27-2012
    mestapho
    Here is the view of a 2.3 NeoMoto from underneath on a TRc:
    http://imageshack.us/a/img651/713/img1864qf.jpg
  • 11-27-2012
    StiHacka
    I have ordered a NN 2.25 recently and I am hoping it will work in RS Lyrik. I'll compare it with the 2.3 Neo when it arrives.
  • 11-27-2012
    fsrxc
    Me too - 4 tires (2 folding + 2 wire bead studded) shipped to Canada in just under 3 weeks for $28.
