Results 1 to 12 of 12
    Reputation: brankulo's Avatar
    Aug 2005
    what 650 tires will my fork clear?
    i have HD 160 with 650b wheels and 2012 36 talas 160 fork. running neo motos 2.3 front and back on flows. now rear one is pretty worn so will be puting front one to the back and was wandering if there is anything bigger for front that my fork will clear. with neo moto 2.3 there is still room under arch.
    HuRa
    architecture and interior design
    website facebook
    RENO/TAHOE
    Nov 2012
    A 27.5 by 2.35 kenda nevegal will fit and
    A 650b by 2.25 schwalbe nobby nic will fit..
    I have not tried new 2.35 schwalbe hans dampf yet!
    derp
    Reputation: danielsilva's Avatar
    Until these new tires begin to roll in, it's hard to tell but i bet the new Hans Dampf and Nobby Nic will clear the arch, might not completely clear the crown though.
    2006 Cannondale Rush 650b
    2010 Cannondale Trail SL 650b
    2013 Norco Range Killer-B
    Aug 2005
    is NN 2.25 bigger tire than neomoto 2.3? i keep reading about nevegals they are terribly slow rollers. is this big of a issue as a front tire too? i would sure be happy to fit HD 2.35
    HuRa
    website facebook
    It's not nearly as big an issue on the front, and the Nevegal 2.35 is an excellent front tire, IMO, especially if your riding swerves toward the chunky side. It's my go to front tire for the steep, mixed (but generally rocky) conditions on the home trails. Don't dig it quite as much on the rear.
    It fits great on a 32mm Fox fork so it should be even roomier on a 36.
    NedwannaB
    Reputation: JMac47's Avatar
    Nev up front
    Quote Originally Posted by brankulo View Post
    If you need soon, don't want to spend alot (almost 1/2 Schwalbes) and don't want to gamble on the others fitting. It will handle a little diferent then the Neo though.
    Wait,who did he tell you that?....
    Aug 2005
    how different? can anyone confirm HD 2.35 fit fox 36 fork?
    HuRa
    website facebook
    May 2005
    Yes, it will absolutely clear the arch as will the 2.35" Nobby Nick which is the tallest 650B tire I know of (it clears the arch of the Fox 32 also) at close to 28" tall.
    At bottom out the NN hit the bottom of the crown of the 32 Fox but the HD might clear or be very close as it's about the same height as the Nevegal 2.35". So the 36 I would think no problem at the crown. Not sure if the NN 2.35" would clear the 36 crown it's so tall. It would be nice if someone could check that.
    2013 Banshee Spitfire V2 650b
    Aug 2005
    any updates on hd 2.35 clearing fox 36 crown at bottom out?
    HuRa
    website facebook
    Reputation: Moodrid's Avatar
    I just got my 650 rolling about a month ago. I had concerns about the slow rolling reports of kenda nevegal but I put them on the front and rear. I like them alot. I ride on alot of rocky trail and they hook up good in the loose. I have the front on a Fox 32 clears with no prob.
    09 Ventana El Bastardo 650b
    10 Banshee Viento
    Aug 2005
    any issues running nevegals tubeless? i know it voids warranty but other than that? cant imagine going back to tubes
    HuRa
    website facebook
    None whatsoever for me....been running Nev's in various sizes on various rims with Stan's and homebrew sealant for the last 5 or 6 years.
