Results 1 to 2 of 2
    Jan
    Jan is offline
    Use of EBB to lower crank?
    I'm planning to convert a mtb to 650b and think to lower the crank by using an eccentric bottom bracket for standard frames like the "exzentriker" or this one: http://forums.mtbr.com/singlespeed/another-eccentric-bottom-bracket-standard-frames-473562-post5144832.html
    Have anyone tried this? How many mm can I lower the crank?
    It requires the use of a half-link, so it probably only has a couple mm of throw. I'd guess it could lower your BB as much as 5 mm, if that.
