Results 1 to 2 of 2
    Trek 69er and offset fork ?
    I read the Trek 69er is equipped w/ an offset fork. What if a standard 29er fork is used ie. Reba, Minute etc ? Thanx
    The Fox is a Fisher G2 geometry fork with 51 mm of offset. The new 09 Reba is 46 mm and the standard Fox are 44 mm. Not sure on the Manitou. It should work fine, but might be a little slower steering than the Fox. That might not be a bad thing. I've kicked around swapping to a new Reba on my TopFuel 69er.
