Results 1 to 3 of 3
    ccm
    ccm is offline
    West Coast Racing
    simple 26 650b 29er question
    as far as going in straight line over bumps, rocks and roots
    is a 140mm/140mm 26er = 132mm/132mm 650b = 120mm/120mm 29er?
    all else in the way of appropriate geometry and equivalent wheels and tires being equal
    Nov 2006
    29er, it's not about suspension as much as the angle at which the tire hits the obstacle. But that's a simplification of the question. The rider makes the most difference.
    Reputation: stevemtu's Avatar
    Mar 2006
    Quote Originally Posted by ccm View Post
    I know I am going to sound like a jerk, but the wheels can't be equivalent even if you are talking about the same brand or even the same weight.
    I can only compare a 26 FS 100mm to a carbon HT 29er, both with crest wheels and Ikon tires, and must say these observations are my own experience and may differ from others. The 29er roll over capability and momentum conservation compared to the 26 is undeniable. The ability of the 29er to hold a line through bumpy rocky rooty track because of the larger wheel inertia is something I certainly appreciate.The price I pay is in acceleration due to the larger mass of the wheel/tire of the 29er being a larger distance from the wheel center (this I can definitely feel), not to mention the weight cost between the wheels/tires. Another tradeoff is that the same inertia that makes the 29er hold a line makes it more difficult to change direction compared to the 26.
    My own feelings about advantages/disadvantages of the 29er relative to the 26 relate to the strength of the rider. A fit, athletic rider that can put out a lot of power may not even notice the the acceleration problems with the 29er and feel there is no down side to that wheel size.
    I should also mention the stability of the 29er wheel size makes it feel "safer" compared to the 26.
    All this trade-off stuff is why I am interested in the 27.5 as a 'compromise'.
  1. Simple question
    By Totoslave in forum 29er Bikes
    Last Post: 07-28-2013, 08:14 PM
  2. simple question..
    By frank6262 in forum 27.5 - 650b
    Last Post: 11-20-2012, 09:18 PM
  3. 650b or 29er? That is the question.
    By RobbVII in forum 27.5 - 650b
    Last Post: 04-27-2012, 01:24 PM
  4. a very simple question
    By shekky in forum General Discussion
    Last Post: 03-04-2012, 07:39 PM
  5. simple question...
    By wildskycomet in forum Brake Time
    Last Post: 06-09-2011, 02:35 PM
