Results 1 to 19 of 19
    Reputation: MMcG's Avatar
    Jul 2003
    Rim Brake Compatible 650b rims - Only the two options?
    Are the only two options for rim brake compatible 650b rims the Velocity Synergy rims or the Sun Ringle CR18s?
    Or am I forgetting another viable option or two?
    The reason I ask is for a bike that would be V-brake in back and disc up front.
    Mark
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    Weinman Discovery. I don't know where to get them, though.
    Rigida makes (or made) the Sphinx in a 36h. Check with some touring type websites.
    velo orange has gear.
    Also the Stan's ZTR's
    Jul 2003
    ZTRs are rim brake compatible???
    They aren't optimal, but, yes, you can run a rim brake with them. With some use the ano will wear off, providing a better braking surface.
    Mark, I replaced my Synergy's with the ZTR and run v-brake on the rear. It brakes at least as good as the Synergy and is the best fit for the Neo-Quasi out of the Synergy, Blunt, ZTR that I have. But the Synergy fits Fatty Rumpkins better. The Neo, Quasi, Rumpkin's are the only 650b tires that I've tried. I'm interested in hearing how the newer tires do.
    Quote Originally Posted by MMcG
    Jul 2003
    Thanks for the scoop steelbike.
    I also checked Velo Orange and they have the CR18s and a 36H Weinmann ZAC 19 rim available. I wonder how these Weinmann's perform. Do you think the Weinmann Discovery rims are OEM versions of thes ZAC 19s?
    http://www.velo-orange.com/weza65rim.html
    Let's compare:
    Discovery:
    Zac 19:
    Long live long rides.
    Reputation: Life and Liberty's Avatar
    really good to know you can run the ZTR with V brakes...
    i <3 this forum.
    Dec 2004
    QBP will have Velocity Dyad 650b rims in the near future.
    master blaster
    Reputation: veloreality's Avatar
    any updates on this? new reviews? what rim brake hoop is most worthy to lace up to chris kings?
    anyone selling/looking to trade a 650b rim brake wheelset for a chris king 26" rim brake wheelset?
    underachiever
    Reputation: misterdangerpants's Avatar
    Oct 2007
    Quote Originally Posted by veloreality
    I laced up some Velocity Synergy rims to some Chris King hubs. I think they're certainly worthy and will be perfect on the Northeast singletrack that I'm going to subject them.
    master blaster
    did you use 'front' rims front and rear?
    underachiever
    Oct 2007
    Front for both.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Quote Originally Posted by misterdangerpants
    I really like the Synergy rims. They hold up well. Really well.
    I used the "front" rim for back.
    master blaster
    man, i cant find the syergy's in stock anywhere(wholesale)
    but qbp has the dyad rims in stock in silver....not sure if im down with the semi aero look though, what do you think?
    I don't think it is too crazy- maybe about as semi aero as the Synergy, really.... Guess the Synergies got plugged.
    master blaster
    Quote Originally Posted by umarth
    seems like it. i think ill give j&b a shot before i order up the dyads. they always seem to have the stuff i cant find anywhere else.
    underachiever
    Oct 2007
    Harris Cyclery has them (they're local to me).
