View Poll Results: Would you buy some 36er tires?
Voters
235. You may not vote on this poll
  • Heck no.
    128 54.47%
  • I'll take one (unicyclist)
    12 5.11%
  • I'd buy a set for my bike.
    64 27.23%
  • I'd buy multiple sets, for my bike/uni, and to support the project
    31 13.19%
Page 1 of 10 1 2 3 4 5 ... LastLast
Results 1 to 25 of 239
    Moderator Moderator
    Poll: 36er tires
    So Matt and I are hearing some semi-encouraging things. Don't get too excited, there are a lot of hurdles remaining to jump through - but I want to take a minute to assess interest.
    How many of you would buy a set (or more) of 36er tires that fit this rough profile?
    -900-1000g weight
    -*Probably* sealant-ready for tubeless use
    -A tread pattern in the small-knob (think Kenda Small Block 8) or medium knob (think Maxxis Ignitor) range.
    -2.2 or 2.3" size
    -Cost of somewhere around $100/tire. That might come down some depending on interest, but it's probably not going to end up much below the cost of the Nimbus. If there's enough interest for a second run (or more) of tires, that cost will drop dramatically, of course.
    Please pass on the link to this poll to your unicyclist and 36er cyclist friends and have them come express their opinion.
    FWIW, we'd love to hear your opinions about what specific tread patterns/sizes you want as well, but our selection will be limited to already-existing patterns from the company (who I won't name, and you have most likely never heard of).
    Waltworks Custom Bicycles
    Park City, UT USA
    www.waltworks.com
    waltworks.blogspot.com
    Road unicyclist here:
    Any ideas on max pressure? Would it be pretty rough as-is on the road? Would I be able to cut off the knobs and get at least 1500km out of one?
    This is exciting!
    Phil
    Reputation: davidfrench's Avatar
    Jan 2011
    I'll take maybe two sets, my builder might take two sets more as he's building another 36er for a taller dude than me.
    thread thoughts : mine will be a randonneur, so 50% road/50% fire road, so a cyclocross type (small knob ok, not too aggressive) will be fine.
    Thanks Walt !
    DirtySixer36er, Ventana ElCapitan, Soma Smoothie 66cm, Trek T100, ChoiceCollective36er.
    DirtySixer
    36er
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    Id be in for 4-6 tires on the first go round!!!!
    PAYASO 36er.....Live the Circus
    Shop Owner/Frame Builder
    Ouch...$100 per tire.
    We'd definitely buy 2. We are planning to make a 36er soon and would love to have better rubber for it.
    CJB
    www.HammerheadBicycles.com
    Austin's dirty little secret
    www.TrueFabricationBicycles.com
    Texas Born; Texas Bred
    Jan 2011
    Quote Originally Posted by CBaron View Post
    CJB
    Nimbus Nightrider are at 82$ (plus tax, plus shipping I guess), so...
    DirtySixer
    36er
    I'd definitely be in for a set of two and perhaps a second set if it looked like a one shot run. Don't currently have a 36er but is on my must have list.
    I'm in for 4 tires personally and might could be talked into a little initial investment capital to help share the initial 'batch' purchase.
    That Unicycle Guy
    I started a thread on the unicycle forums linking to this one, might get a bit more attention.
    I would go for one for sure, preferably with the smaller knobs for a more versatile/road friendly tread.
    more love, less attitude
    I'd like at least 3. The knobbier the better please.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    One set please, for a project.
    Oct 2011
    I'd take three; my idea tread would be something similar to the Nightrider; for road and hard-packed dirt use (unicycle), but lighter.
    Reputation: mbeardsl's Avatar
    Quote Originally Posted by todwil View Post
    Thanks to Todwil for getting this rolling BTW. I am optimistic we can get this done.
    I'd take a couple pair and like David mentioned, Nightriders are 82 so I'd pay more for half the weight and better traction. I'll take whatever tread, would lean towards knobbier for eventual wet and loose conditions but could make a small block 8 work for 90% of what I ride.
    Matt
    Looks like 40ish so far, not bad. If a couple builders picked up a few pair it would go a long way too. I'll get in touch with James to gauge what he'd use in a year.
    36er subject is one of the reason I registered here (finally)
    Count me in for one set.
    Moderator Moderator
    Probably somewhere around 60psi?
    I do not have an answer to that question, but my assumption as of now is that these would be the same as any other mountain bike-type tire and have a max PSI in the 45-60 range somewhere.
    No idea on the durability minus knobs. This is not intended to be a road tire, really - more of an all-arounder capable of being used for riding offroad on most terrain.
    -Walt
    Quote Originally Posted by uniphil View Post
    This is exciting!
    Phil
    Park City, UT USA
    www.waltworks.com
    Mountain Unicyclist
    Reputation: DavidHood's Avatar
    May 2010
    unicycle 36" lightweight tire
    Quote Originally Posted by ericpulvermacher View Post
    Props to saskatchewanian for sharing this thread on unicyclistdotcom. The consensus over on RecSportUnicycle (RSU) seems to be similar to what Eric said looking for smaller knobs on paved roads with intermittent camber. Even then we might end up shaving some knobs off to save even more weight. I have already reduced the weight in my tube by 30% with the Nimbus FOSS tube. The most important weight to reduce is rotational weight and my Nimbus NightRider tire alone weighs 4 lbs! I would definitely purchase two. One for my Nimbus (disc brake) Impulse unicycle and another for my new Kris Holm (geared hub) Schlumpf unicycle. Check out what they are saying over on RSU. If you build it, they will come.
    Maybe?
    I'm definitely interested in 36er tires, but Small Block 8? Is that the "go-to" tread pattern for 29er's? I was thinking of something like the Mountain King....
    "I can only assume chan slap is what happens when you get assaulted by Jackie Chan. I don't think anybody can prevent that."
    One set plus a spare probably, Small Block 8 style knobs would work for me.
    Thumbs up for the guys who are pushing for this to happen !!!
    Over 50, & not '2' tired
    Reputation: unigeezer's Avatar
    I'll definitely take TWO!
    www.unigeezer.com
    "Over 50, and not '2' Tired!"
    Reputation: Keener's Avatar
    Feb 2005
    I would be happy to commit to 4 of the the 2.3" wide.
    Tread: if it has more open space then the Night rider and some side knob I would be so happy
    Side knob good ATMHO for 36er
    2.2 .. harder sell for me need some rubber between my rim and the rocks.
    I would still buy but more for the sake of science. and not 4 to start.
    Tire casing seems to make a bigger difference to me then the pattern of the knob.
    Supple side walls make for smoother ride then 4 ply.
    One pedal goes down
    the other goes up
    bike goes forward
    smile
    Bryan Keener
    HPV research since 1984
    Moderator Moderator
    As with 29ers...
    For a "first tire", we have to aim for the widest possible appeal. You may or may not remember the Nanoraptor (the "first tire" for 29ers) - it's essentially a semi-knob/semislick. It's not the perfect tire for everyone, or even most people, but it's acceptable to most riders on most terrain. That's what we're going for here. If in a few years everyone is riding a 36er, tire selection will probably improve.
    -Walt
    Quote Originally Posted by thesenator View Post
    Park City, UT USA
    www.waltworks.com
    Depends on what you ride. Ideally I would run a Nevegal up front and SB8 in the rear for 98% of the rides I do but no way there is enough demand for 2 separate tires yet. Only in mud have I ever not wanted the SB8 on back. Your terrain/skill/style may very well dictate something different.
    This is the choice we are discussing here (sorry for fuzzy pics), but all input is welcome:
    Attached Thumbnails Attached Thumbnails Poll: 36er tires-36er-choice.jpg
    Quote Originally Posted by Keener View Post
    Casing would be 120 TPI if 36er version mimics 29er tire.
    Pretty good showing so far if everyone is voting seriously, if we can double production numbers price would potentially drop 25% which would make these a bargain compared to Nightriders for a much better tire.
    Walt, Matt thanks for your effort!
    I ordered a 36er last week @ BS and would take 2 or 3 new tires in the hopefully near future
    Ridin ridin ridin..... raw ti!
  1. 36er
    By locobaylor in forum 27.5 - 650b
    Last Post: 12-16-2009, 09:36 AM
  2. New 36er rims and Tires!
    By benwitt11 in forum 29er Bikes
    Last Post: 02-04-2008, 10:06 AM
  3. POLL:The Best Tires/Tyres!!
    By rolling racer in forum Wheels and Tires
    Last Post: 10-08-2006, 11:14 PM
  4. Anyone seen one of these...a 36er?
    By DirkSSter in forum 29er Bikes
    Last Post: 11-17-2004, 11:00 AM
  5. Poll: Best Tires for Bootleg
    By Gungadin in forum Nevada
    Last Post: 08-08-2004, 12:55 PM
