Results 1 to 2 of 2
    Pike Air U-turn OK?
    Read that the Pike coil works a-OK with the neo and moto.
    anyone try out the air version? I know the casing is the same but obviously the internals are very different and I'd like to be sure about this
    Reputation: MMcG's Avatar
    Jul 2003
    I would think it would be fine and actually it might allow you to make it even safer (but it also may make the fork a bit less responsive) because you could air it up to have a "stiffer" feel and action to it vs. coil where you'd have to swap springs to heavier ones to get that affect.
