    30-ton War Machine
    Reputation: edgerat's Avatar
    Norco Faze 2????
    I saw a post and someone mentioned that the faze MIGHT clear a quasi-moto in the rear??? Can anyone confirm that? I bought the bike as my first bike back on the trails after a long lay-off and my current weight throws me over the front-end on descents because the fork can't support my weight. The thought I had was to put a Fox Talas on it and a 650b setup and have the Talas Push'd to closer support my current 250lbs. So, anyone know if the Faze will clear a quasi-moto???
    Isaac
    30-ton War Machine
    In an effort to further this post I thought I would post pictures of the rear end. That is a brand-new Nevegal 2.10x26" in the rear-end. Soooo, will a 650b clear folks???
    Isaac
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Possibly but the clearance at the top of the tire will be tight. At your weight though you're better off using a 26 x 2.35.
    30-ton War Machine
    Thanks bro! I will get in the saddle and start dropping pounds!
    I appreciate the info,
    Isaac
