Results 1 to 15 of 15
    Apr 2013
    new soma b-side build (but wrong fork travel, oops)
    i built up a soma b side but i used a 130mm travel white bros fork i got off ebay, I guess you are supposed to use 80mm forks. is it going to be a problem?
    new soma b-side build (but wrong fork travel, oops)-img_0114%25u0025255b1%25255d.jpg
    Reputation: Zerort's Avatar
    Jan 2013
    Why would it be a problem? How does it ride? Fine, then no problem.
    2013 Rocky Mountain Altitude 730
    2013 Pipedream Sirius R853 - 650b Belt Drive
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    Looks good. Doesnt look too raked out.
    Longer fork puts more force on the headtube. It doesn't look too bad, but an email to Soma would be the way to go.
    That kind of failure could be painful.
    -Carlos
    Flux
    Jan 2013
    Quote Originally Posted by los36 View Post
    Maybe painful on the wallet if it fails.
    It's not plastic, so unless Soma is using epoxy to hold their tubes together, the headtube is not going to separate from the frame.
    Also, the longer travel will actually dampen huge hits or drops more than short travel. I think the OP will be alright. Nothing to worry about.
    Jan 2011
    My B-Side broke clean in two, right in the middle of the downtube. I ride hard, but the frame had experienced no notable crashes. I was running a 100mm fork. They use thin tubing, I would be wary...
    Apr 2013
    Thanks guys, im new to mtb (road rider) so im not riding too hard right now, it honestly feels fine to me, yeah i just dont want the frame to break and get hurt. Maybe in a few months when i get a little ballsier ill look into a new fork
    I also recommend for you to reach out to Soma so you can get first hand communication whether its safe.
    Soma told me yesterday that any 100 mm travel 650b fork or a 26er fork with 120mm travel that fits 650b wheels will work on the B Side. I then verified with X-fusion that their Velvet fork converted to 650b @ 100 mm has an A2C of 489mm unsagged.
    A 130 mm fork is way more than 489 A2C. The bike will handle differently compared to 100mm but its always good to make sure that you will be safe on it. A quick email only takes a minute to type and send. They return emails pretty quickly.
    undercover brother
    Reputation: tangaroo's Avatar
    People make a way bigger deal out of it then necessary. If the ride feels fine to you, then it will be alright. If you threw a 150mm on there, then I'd be hesitant. Ride it and be happy.
    Apr 2013
    email from soma:
    Hi Alex,
    Looks good!
    I wouldn't worry about it much. If it rides ok, the there shouldn't be an issue. Bascially what happens when you run a longer fork is the head tube angle is reduced, so it changes the steering a little. Many agressive riders prefer a slacker head angle for descending so it might actually ride better for you.
    -Evan
    Soma Fabrications
    Now go rip it and give us a ride report.
    I am going to use a 100mm 29er fork with an A2C of 500 mm unsagged when my frame arrives.
    Reputation: MMcG's Avatar
    Jul 2003
    It looks awesome as you have it. Ride the crap out of it!
    Dec 2009
    I run 140mm forks on my Soma B with 650b wheels and a 100 29er fork with 29er wheels. Both are close in AC height and both a huge improvement over OE spec forks.
    Wrench
    Reputation: FNFAL's Avatar
    This will change your HT angle
    ... By about a degree and a half.
    Which makes for a slower steering bike that's a little less stable when climbing steep terrain.
    Quote Originally Posted by Alex Steiner View Post
    Reputation: Kyle509's Avatar
    I know, old thread. I am wondering what size that B-side is? Looks like a medium...
    I am 6'1 and torn on the sizing. 18.5" is really close to too small and the 20.5" seems like it might be a smidge on the big side for me. Wish there was a 19" with a 24" tt. I ride a large Chromag Stylus currently, but it's just a bit too small. Planning on running a lowered Pike 454 dual air with the frame.
  1. Replies: 0
    Last Post: 04-04-2013, 05:36 PM
  2. oops wrong forum - pls delete
    By treethumper in forum Ritchey Design
    Last Post: 03-14-2012, 07:41 AM
  3. oops, wrong thread - please delete
    Last Post: 02-12-2012, 02:23 PM
  4. My New Soma B-Side
    By mikeridesabike in forum 27.5 - 650b
    Last Post: 01-28-2012, 05:53 PM
  5. oops, wrong forum
    By dirt farmer in forum Oregon
    Last Post: 07-04-2011, 09:19 PM
