Page 1 of 8 1 2 3 4 5 ... LastLast
Results 1 to 25 of 182
    Mojo HD 650 Build
    Let the games begin! Still waiting on the wheels, BB, Stem and Bars
    Attached Thumbnails Attached Thumbnails Mojo HD 650 Build-240034_4102909463306_204737568_o.jpg
    Dissolved member
    Reputation: StiHacka's Avatar
    Feb 2012
    I'd call it a great start! I am building one, too; let's see who finishes his first. What fork do you plan to use?
    I've got the 650b talas waiting for the stem to attach it with. What are you going with?
    Dissolved member
    Feb 2012
    I have not decided yet if I want to run it as 140 or 160 so I went with a cheap Lyrik U-Turn as a temporary solution. When the XFusion 2013 models are out, I will be ready.
    The fox is pretty awesome. Some suspension purists get all twisted that it is not as infinitely tunable, me I just want to set it and forget it. Tires are a bigger issue,neos are all out I had to buy from Europe and they were 180 shipped.
    Dissolved member
    Feb 2012
    Ouch! The Neo situation feels like bait and switch - they get you interested in 650b but when you finally need them, there are nowhere to be found! At least they last for a while, I have close to 1.1k miles on my front tire and it is still in a pretty OK shape.
    Yeah I hear they are awesome. Nobby nic got great reviews from grams light bikes but as he told me they will be out in October? Also could be a mojo had clearance issue. I hope mojo builds a 650b rear triangle that we can swap out and limit the shock mods in 160 mode
    Jun 2005
    It will be worth the wait! I put some miles on my recently 650b'd HD and like it a lot.
    Still waiting for the "keystone" shipment so I made some headway and did what I could..... Installed the fd
    Got what seem to be one of the last pairs of neos in tonight. Ups says the keystone shipment is ais. Getting closer
    Smile
    Shipment due in today feels like Christmas morning. Put rd on mixed in some yumeya parts from the 970 days. Turns out there is no difference between 10/9 SPd jockeys.
    Also worked out the shock travel mod as I am running in 160 mode. Started with 1/8 inch worth of fiber washers from Home Depot. I am worried that the fiber will swell but its worth giving it a shot. Mod was easy let the air out, grab can and twist to unscrew. Carefully draw can down shaft then pull washer and oring down as well. These will physically limit the shaft travel as opposed to the volume reduction kit that sits above the shaft and makes the piston action more progressive but not any less travel. Last steps are to carefully re tighten can and then some tape over possible rub areas. I'll check the bottom out before reinflating.
    Dissolved member
    Feb 2012
    Those are some nice components. My build is simpler and I finished it last night and rode it this morning for the first time!
    Awesome how was the ride? Ps I guess you won the build race damn you ups
    Dissolved member
    Feb 2012
    Mostly very slippery. I rode out in fog after four days of rain. All the roots and rocks and wooden bridges were wet and slimey but I like the feeling and traction of the DW-Link suspection a lot. It made me grin.
    Put in a whole bunch of work to the chagrin of my wife
    Enve makes excellent stuff
    Don't forget the necessary tools to run the wheels tubeless
    Weird how the special disc bolts are the same bit as deck screws
    Coming along not in love with the controlls set up thinking may have to go for the integration kit for the shifter set. Between the short brake levers and having to put the Ks control inside its a reach to keep the hands out wide. I'll take her for a ride and see soon.
    Can't wait to swing a leg over her. Bottomed the shock without pressurizing clearance was perfect.
    Dissolved member
    Feb 2012
    Wow that is a real nice build!
    Feb 2007
    deofour,
    Can you post some pics of the rear tire clearence. I'm considering the same modification to 650B in the rear of my HD 160. I have already done the front. I'm running a Fox 36 Talas and love it.
    Custom Wheelbuilder
    Reputation: Zen Cyclery's Avatar
    This is a gorgeous build. Bravo on the HD. Makes me want to get one and go 650b!
    Check out www.zencyclery.com for fully customizable, handbuilt wheels.
    www.facebook.com/zencyclerywheels
    Reputation: in the trees's Avatar
    Mar 2005
    Is that a Fox 34 Talas 27.5"?
