Results 1 to 18 of 18
    Reputation: madsedan's Avatar
    Aug 2010
    Man, my 650 Nickel build is spiraling out of control
    I'm almost done but man it'll be nice when finished, I'm throwing it down for all the Nickel 650 builds lol. I'll post pics of the full build and some pics when I get the last piece in the mail in a couple days, inaugural ride should happen this weekend.
    -1x10 with X9/X0 components
    -X-Fusion Velvet, 15mm, tapered
    -Stans Flow EX wheelset with 3.30 hubs and Racing Ralphs courtesy of Hammerhead
    -Magura MTS brakeset, MT4 lever with MT6 caliper, from 2013 Epic Carbon
    Hopefully it'll be about 25#, I need to pick up a light saddle and the Easton EC70 is in the mail so it should be all done by the weekend.
    I had intended on doing the bike for around $2k but now I'm in the $3k range, as I was building it I kept buying nicer parts than what I intended originally and I wanted to keep everything red/black, simple color scheme, which made it even more costly....
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Oct 2007
    Quote Originally Posted by madsedan View Post
    Most of my builds usually end up nicer than I originally intended. But you may as well get it just the way you want it, in long run its cheaper then building on the cheap and then upgrading later on.
    2012 On One Whippet 650b
    2012 Santa Cruz TRc 650b
    2014 On One Dirty Disco
    2010 Soma Groove
    1987 Haro RS1
    ....and I wanted to keep everything red/black, simple color scheme, which made it even more costly....
    This made me laugh.....I do the same damn thing!
    Aug 2010
    My wife would crap a litter of kittens if she saw the spreadsheet with the weight and cost of all the build items
    Its charting out like it'll be in the low 24# range but figure with grease and stans it may be about 25#.
    May 2005
    What they don't know wont hurt them...or you from sleeping in the garage
    25lbs for a Nickle would be pretty amazing I think. I think of it (and the Butcher) more as a 30lb bike and perhaps one reason SC nixed them from the lineup.
    If you hit that 25lb mark I might crap a litter of kittens
    2013 Banshee Spitfire V2 650b
    Yup, I'm doing the same thing. Saving a bit in the short run as I'm pilfering a couple things off my Kona. Should be on the trail Sunday. I too am waiting on the postman. Don't forget to post pics when it's done!
    Sep 2012
    Me too, there should be a Nickel support group... LOL!
    I got stuff from all around the world heading to my house.. thanks to EBAY...
    Sep 2012
    Stans no tubes has been driving me crazy.. threre 650b ZTR flow EX shipment just got in today, so my wheels should be sent out by the 1st...
    Sep 2012
    Here's a list of the stuff I have and on the way.
    Should be a good build..(I Hope!)
    2012 black Nickel
    M800 Saint cranks 1x10 setup 32x 11-36
    Hutch beartrap pedals
    Shimano Saint M820 1x10 Speed Rear Trigger Shifter
    SRAM X5 PG-1030 11-36T 10 Speed Cassette
    Shimano XT M780 GS Mid-Cage 10-speed Shadow Rear Derailleur
    Shimano Deore M595 Hydraulic Disc Brakes Set
    RavX Disc Rotor HD (Size 160mm/180mm)
    X Fusion Vengence HLR DLA 170mm -> 140mm 20mm axle
    Stans Flow EX wheels (650b) with 20mm front hub
    Kenda Nevegal 650b Tires 2.35/2.10
    DT Swiss 10mm thru-bolt
    Cane Creek 40 series head set
    Truvativ 700 20 Rise 31.8 Hussefelt Comp Riserbar (Blast Black)
    90 mm BLACK 31.8 ORIGIN 8 ULTIM 8 STEM
    and still shopping!!
    Reputation: rupps5's Avatar
    I am curious to see what the weight comes out to be. If I had to put in a guess I would say 27# range.
    BMF
    Oct 2007
    Your build is turning out the same as every build I've done - way over budget!
    Reputation: MTBforlife's Avatar
    Im curious to see how the frame works in the 650b format. I have been considering converting my Nickle. My bike has a 200x57 rear shock on it so im curious to see if I can run 650b and still get 140 mm of travel.
    Reputation: 4Butter's Avatar
    Now I have to do a weight spread sheet too.. Killing me Smalls!
    Dissolved member
    Reputation: StiHacka's Avatar
    Feb 2012
    Quote Originally Posted by MTBforlife View Post
    It works quite well but I do not think you can safely get 140mm with 650b wheels.
    Sep 2012
    Nope
    not enough clearance.. my 2.10 Nev has 1/8 inch under full compression with the standard 200x50 shock.
    Good luck!
    any progress? Just purchased this frame and curious as to how yours turned out. I to am thinking of going 650b.
    Reputation: Morpheous's Avatar
    Mar 2006
    Dont think about it, just do it. You just bolt everything on and mount up the wheels, No mods.
    2012 SC NOMADc
    2011 SC Driver8 BikePark Sled
    2012 Surly Pugsly Fatty Trail/Dogrunner
    Reputation: Barnes10's Avatar
    Jun 2012
    Very nice build. Hope to hear how she rides
