Results 1 to 5 of 5
    Jan 2009
    low 'stack' front derailleur
    I set up my 07 stumpjumper FSR 650B. I am running a slant6 out back and it fits in the frame. I noticed on a recent ride I was getting rub somewhere. After further inspection It is when I bottom out the suspension in the rear and the tire rubs the front derailleur. It is currently a 9 speed Deore LX. Does anyone know of front mech that will stick closer to the frame? It is a clamp on.
    May 2005
    Shimano SLX M665 FD. It's a double specific only (no triple) and has a quite compact and short cage and the mechanism sits a little closer to the seat post than the LX. Might be what your looking for.
    Shimano SLX M665/7 Front Derailleur > Components > Drivetrain > Front Derailleurs | Jenson USA Online Bike Shop
    You should be able to find a better price. Link was just an example.
    Reputation: tominpinson's Avatar
    http://i630.photobucket.com/albums/u...psf3e41345.jpg
    I was inspired to try 650 pn my 2007 from your post. 1x with race face narrow wide chain ring.
    Jan 2009
    I finally got back on this bike last night. I realized that the issue only comes during wups. Like on a decent I assume the Brain has opened up and you get to a stream with a quick down/up transistion. That can compress the shock all the way.
    In your 1X can you get the rear tire to hit the frame? What rear are you running, the slant6?
    Small block 8 27.6 x 1.95. Will try quasi moto next.
    No rubbing so far. Plenty of room when I release al air from shock
  1. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  2. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  3. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
  4. Which front derailleur for my set up - xx or xtr
    By sclyde2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2012, 08:53 PM
  5. Which front S3 derailleur??
    By divingtigger in forum SRAM
    Last Post: 03-30-2011, 03:40 PM
