Page 23 of 54 FirstFirst ... 13 19 20 21 22 23 24 25 26 27 33 ... LastLast
Results 551 to 575 of 1333
  1. #551
    Uncle
    Reputation: Entrenador's Avatar
    add Ragley PIglet to the list
    Eat, ride, eat, rest, repeat.
  2. #552
    Uncle
    Quote Originally Posted by kahun4 View Post
    I would like to build up an Azonic AZ-7 hardtail frame with 650b Blunts. Anyone have any info on clearance issues with this frame? Thanx
    I can't find info about these frames anywhere -- not even geometry. Their website is useless, and I think they're probably missing out on lots of sales by not publishing details. I've passed on these frames a few times in the last few years alone (take a hint, Azonic!).
    If you turn this info up, post it up please.
  3. #553
    Genius_rider
    Specialized Camber
    Has anyone converted a 26" Specialized Camber? Mine has a 2011 Fox F Series 120 mm fork, which by reading this forum I understand will work well with 650b.
    The concern I have is that the seat stays have an arch joining them. With my current 26 Mavic Crossride wheel and Maxxis Crossmark 2.25 tires there is a gap of about 15 mm between the tire and the arch. I suspect this may be too tight for a 650b.
    Is there a listing of the diameter of the 650b available tires? I have only found the 702 mm of the 2.3 Neo Moto.
  4. #554
    Reputation: TORQUE-29er's Avatar
    Nov 2008
    Turner Flux with a RFX rear triangle.hey Lefty + 650b peeps...
  5. #555
    Dec 2009
    Confirm 2008 Merida carbon FLX 900 hard tail. Can't confirm if front derailleur fits.
    Attached Thumbnails Attached Thumbnails List of 27.5 Compatible 26ers-dscf0054.jpg
  6. #556
    Dec 2009
    Confirm 2009 Marin Wolf Ridge.
    Attached Thumbnails Attached Thumbnails List of 27.5 Compatible 26ers-dscf0036.jpg
  7. #557
    May 2005
    Quote Originally Posted by gvs_nz View Post
    Would that clear with a FD mounted up? ISCG tabs?
    How close to the seat post at full compression?
    What is the weight of the bike?
    2013 Banshee Spitfire V2 650b
  8. #558
    Dec 2009
    Can't confirm if FD would fit but my guess it would. There is miles of space at the bottom of the seat post and being a high pivot the wheel should move away from the derailleur.
    No isg tabs.
    Neo moto 2.3 just kisses seat post with no air in the shock.[ you'd never achieve that riding ]
  9. #559
    Reputation: jetboy23's Avatar
    Sette Serum
    Easy clearance for the seat stay and the bottom bracket area. No problem with the front derailleur. Might be limited to a Quasi Moto due to the clearance between the chain stay area. Only about 2-4mm space on each side of the knobs. Aired the tire up to 60psi to spin it and no rub. Went for a ride and no rub on tire compression/expansion.
    seat stay
    derailleur and BB
    BB and chain stay
    Running a Reba 80mm 29er up front
  10. #560
    I just built up a on-one inbred (with vertical dropouts) with 650b plenty of clearance, why does everyone say it doesnt work???
  11. #561
    Uncle
    Quote Originally Posted by DustinHaugland View Post
    Pics? Interested for sure.
    thx
  12. #562
    May 2010
    Does anyone know about the giant xtc?
  13. #563
    Reputation: trailbildr's Avatar
    Dec 2004
    Add the Spec'd stump fsr to the list. I have the expert carbon '10 and it fits fine. They all do.
    mk
  14. #564
    Genius_rider
    Quote Originally Posted by trailbildr View Post
    mk
    Can you post pictures? How does the rear tire fit?
  15. #565
    a great article contain many information like the person like me...thanks for publish this one....Nice article, i appreciate for putting this together! “This is obviously one great post. Thanks for the valuable information and insights you have so provided here. Keep it up!”....................
  16. #566
    a great article contain many information like the person like me...thanks for publish this one....Nice article, i appreciate for putting this together! “This is obviously one great post. Thanks for the valuable information and insights you have so provided here............
  17. #567
    is that all stump jumper fsr's, or jus the 2010?
  18. #568
    Dec 2004
    It's all that I've tried so that's all Stump FSRs since 2008. I had a 2.3" Pacenti rear that rubbed a hole in the seatstay bridge, but the 2.1 and 2.0 tires have had no issues. Here's a pic of the rear clearance from my first 650b stump fsr (I'm on my second). Ok, so mtbr won't let me upload. I have some pics on my blog at bigdaddymikesblog.blogspot.com.
    mk
  19. #569
    Has anyone seen a Felt Compulsion with a 650B rear?
    13 Lenz Lunchbox punkass
  20. #570
    Hi
    I am over in the UK and i'm looking at going 650b having had a few hours on a 29'er and feeling that 650b could be the perfect thing for me.
    I have an Evil Sovereign and a Lapierre Zesty '09 with carbon rear.
    Does anyone know if these can be converted.
    The Zesty may well be switched for a Nicolai AC (26'') which I would want to run 650b, will this work.
    I ride hard and aggresive and tend to use full travel on every ride so it is important to me that the rear tyre doesn't strike the seat tube at full compression.
    Thanks in advance for any help and advice.
    Err... just one last question (Colombo style) I love Bos Deville forks, does anyone happen to know if they will work.
    Thanks again.
    Nigel
  21. #571
    Mar 2011
    Hello, I'm James and I am Italian .. I would like to mount the wheels 650b on my Cannondale Scalpel 2008 .. Is it possible? If you do I do?
  22. #572
    Will a Evil Sovereign work?
    In my humble opinion, 650b transformed my Sovereign from a 10 out of 10 to an 11 out of 10.
  23. #573
    Quote Originally Posted by Supplejoe View Post
    Glad to hear that....
    I am going to convert that first and then i will have the wheels to try in my Zesty.
  24. #574
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Quote Originally Posted by mbcrazy View Post
    The Zesty is a great bike... keep us posted on it's 650b compatibility.
    Cheers,
    KP
    “Those that say it can’t be done should get out of the way of those doing it.”
    Pacenti Cycle Design
  25. #575
    Reputation: MMcG's Avatar
    Jul 2003
    Is your Sov one of the originals or one from the "new" Evil?
    Post up Pics please!!
  1. List of disc compatible kids frames (<=24" wheel)
    By ridemtn in forum Families and Riding with Kids
    Last Post: 06-02-2014, 12:42 AM
  2. List of Tubeless Compatible MONSTERCROSS Tires
    By FishMan473 in forum Wheels and Tires
    Last Post: 04-23-2012, 04:01 PM
  3. A list of 29er compatible 27,5ers- forks, frames
    By Davidcopperfield in forum 29er Bikes
    Last Post: 03-30-2012, 10:54 AM
  4. My list of 650b Compatible 29ers
    By Thustlewhumber in forum 29er Bikes
    Last Post: 03-30-2012, 01:32 AM
  5. List of belt compatible frames
    By fokof in forum Internal Gear Hubs
    Last Post: 10-18-2011, 08:34 AM
