Results 1 to 7 of 7
    President
    Reputation: 68point5's Avatar
    Oct 2007
    Kona HumuHumu 69er-fixed-gear MTB conversion
    Before:
    After:
    Not westauwant, westauwant!
    Reputation: fixinflag's Avatar
    Nice, I have a humu deluxe frame that i have wanted to build up as a 29er for a long time now, but I am starting to think i might try and put some 650 wheels in there instead.
    Mar 2006
    Like that alot.
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    I've always thought those Humu's had a lot of potential! Cool build. I think they used to call this bike the A'ha. Am I wrong?
    President
    Oct 2007
    Quote Originally Posted by Cracked Headtube
    I think you're right. But, to be honest, those Kona names are so weird, I even can't tell the full and correct name of my "Humu" by now.
    I bought it as pictured above for 299.- €, (approx. 210.- $) and I did not know, that it had a front brake (it was pictured without one by the bike-mailorder-shop). But then - surprise - it came with Hayes mechanical disc. After riding some days, I decided to change the rear wheel, cause theat cheap chinese coaster brake rear wheel allways had bearing play. So I converted a Mavic Crossride disc-front-wheel to a fixed rear-wheel.
    First I started with an 26'' front wheel and two Maxxis MTB-tires, but when I noticed the front tire clearence, I imediately had the plan to fit a 29'' front wheel someday. One or two weeks ago, I got a 29'' hub-dynamo-wheel for my Salsa 29er commuterbike and the original 29er wheel from my Salsa was left over. After an unsatisfying and dirty attempt to use a 2.1'' wide frontwheel, I changed to a 44mm so called "trekking" or "cross" (not cyclocross) wheel (approx. 1.8''), which approved the handling of the bike considerable.
    Eating Hot Pockets
    Reputation: A. Nony Moose's Avatar
    i think i like it better clean
    Reputation: BrandonNorCal's Avatar
    dang I like that. Is that frame strong enough to use as a full time mountainbike? Is it heavy?
    There's always money in the banana stand.
