Results 1 to 3 of 3
    Jun 2013
    Ibis HDR 650b SLX or SC Bronson Carbon RAM 27?
    The Ibis is a couple of hundred more with these specs. Haven't gotten around to test riding either. It's been hot as hell here and I've just started considering longer travel 650bs instead of mid travel 120-130mm 29ers. Both are at my absolute maximum budget. Any thoughts appreciated.
    First the Bronson 650b:
    REAR DER: Shimano M675 SGS (SLX) Shadow Plus
    FRONT DER: Shimano M611 or 610 (Deore)
    SHIFTERS: Shimano M660 (SLX) 10spd
    CRANKSET: Shimano M610 24/32/42 (Deore) 10spd
    BOTTOM BRACKET:
    CASSETTE: Shimano HG 81, 11-36 (SLX) 10spd
    CHAIN: Shimano HG 75 10spd
    BRAKES: Shimano M615 (Deore) w/ 160mm rear/180mm front rotors
    BARS: Raceface RIde low riser 710mm
    STEM: Raceface Ride 70mm or 80mm
    GRIPS: Lizard Skin 494
    HEADSET: Cane Creek 10
    SEAT POST: Raceface Ride 30.9x375mm
    SADDLE: WTB Volt Race
    WHEELS: WTB ST i23 TCS rims laced to SRAM MTH716 15mm front hub and SRAM MTH 746 rear hub w/ DT 14 gauge spokes, brass nipples
    TIRES: Maxxis High Roller 2 2.3 EXO Tubeless Ready Kevlar
    TUBES: Stans Sealant
    Now the Ibis Mojo HDR 650.b
    BUILD KIT: SLX + 2000
    COMPONENT TYPE STANDARD COMPONENT
    Fork 2014 Fox Float 34 CTD 27.5 140mm travel, Kashima Coat, 15QR thru-axle, tapered steerer, black
    Shock 2014 Fox Float CTD Adjust Factory Series with Kashima Coat, 7.875 x 2.0
    Wheels Stan's ZTR Flow EX 650b Rim 32H Black, w/Speed Tuned XM hubs
    Tires Pacenti Neo-Moto 2.3
    Brakes Shimano Deore, 180mm Front Rotor, 160mm Rear Rotor
    Cranks Shimano FC-M670, SLX, Hollowtech 2, 10-SPD, 175MM, 42X32X24T
    Rear Derailleur Shimano RD-M675, SLX DIRECT MOUNT TYPE, SGS 10-SPD SHADOW+
    Front Derailleur Shimano FD-M671D, SLX, TRIPLE, DOWN-SWING, TOP-PULL, DIRECT MOUNT
    Shift Levers Shimano SL-M610 Deore
    Cassette Shimano HG-62-10 11-36
    Headset Cane Creek 40: ZS44 1 1/8" top/EC49/40 Traditional 1.5" bottom
    Handlebar Ibis 31.8 AL-7075 T6 4 x 9 deg bend 710 mm wide 270g
    Stem Ibis 3D forged 31.8 clamp/28.6 Steerer 50~120 in 10mm increments
    Seatpost Ibis 31.6 x 350 L, 7075 220g
    Saddle Ibis
    Have you ridden DW link? Have you ridden VPP bikes? I like the idea of the Ibis...YOLO I don't understand why both use triple crank sets. If money is tight look at the Norco or wait for Giant.
    Jun 2013
    Quote Originally Posted by migueladobe@gmail.com View Post
    Thanks, no to either. I'm going to wait until next week when the weather cools down here in the N/E to test ride. I don't know much about Norco, so I'll check them out. I heard Trek is coming out with Remedy 650bs, but thought Giant only had a couple of lower end 650bs. I do know Kona came out with the Process 134 and 153, which looks good on paper and price. 650 bs are taking off like crazy for 2014. It's difficult to keep up with all the new models.
  1. Replies: 2
    Last Post: 10-09-2014, 08:27 AM
  2. 2014 Bronson or Heckler 650b w/ RAM 27 Build?
    By Trek13 in forum Santa Cruz
    Last Post: 07-17-2013, 08:47 AM
  3. 2012 Stumpy EVO carbon or the New Bronson Carbon?
    By Drightjustin in forum All Mountain
    Last Post: 06-11-2013, 01:58 PM
  4. 2012 Stumpy EVO carbon or the New Bronson Carbon?
    By Drightjustin in forum General Discussion
    Last Post: 05-30-2013, 08:33 PM
  5. Replies: 5
    Last Post: 04-22-2013, 09:40 AM
