Results 1 to 2 of 2
Thread: Haro Shift R5?
    Oct 2007
    Haro Shift R5?
    I've searched the forum but couldn't find any info...
    Has any body tried Haro Shift w/ 650B tires?
    It seems like a perfect Single Pivot bike for 650B...
    Sail On!
    Reputation: Waterat Pat's Avatar
    It will probably work. Single pivots are the easiest FS bikes to convert to 650B. A simple quick way to get an idea is if you can stick your index and middle finger between the tire and chainstay yoke it will work. Just make sure there is no seatstay bridge or you will need to check clearance for that. Last but not least the tire has to not hit the seat tube at full shock compression. You can get around this if it hits by shimming the shock so that it does not use the full stroke.
    I ride a 650Bed Superlight and love it. Good Luck
  1. Haro x7 frame and haro shift swingarm
    By Combatcm in forum Haro
    Last Post: 04-13-2011, 09:02 PM
  2. HARO Shift?
    By jdr6031 in forum Beginner's Corner
    Last Post: 01-20-2009, 05:16 PM
  3. Haro shift
    By crashdude in forum General Discussion
    Last Post: 07-31-2007, 03:52 PM
  4. Replies: 4
    Last Post: 03-12-2005, 06:41 AM
  5. 2004 Haro XLS R7 vs. 2005 Haro Shift R5
    By gtdrew in forum Haro
    Last Post: 01-10-2005, 06:10 PM
