Results 1 to 5 of 5
    Reputation: jazzanova's Avatar
    Which fork for a TRc? White Brothers or X-Fusion or?
    Please forgive me, if this has been discussed before, but I couldn't find any comparison between White Brothers Loop 650b and X-Fusion 650b
    I am planning 650b setup on my Santa Cruz TRc.
    Which fork should I use? I am not sure if to go with a 130mm or 140mm. 150mm?
    Reputation: Morpheous's Avatar
    Mar 2006
    130mm is optimal for the TRc and Nickel.
    Can you advise which one? Fox, WB or X-Fusion?
    Mar 2006
    I am a Fox fan/user, but X-fusion is making a good product as well. Your best bet for parts/service at many shops (if you dont do it yourself) will be in this order: Fox, X-Fusion, then WB.
    Morpheous has a reasonable point about shop availability.
    However, based on ride quality, I would place the WB above the current crop of FOX forks (no experiance with X-fusion). Things may change with the new CTD damper Fox is using for 2013, but right now, I find the WB much easier to tune and I think their Aura damper is the real deal. If it were me, if you have a shop that has access to the WB stuff, it would be my choice. If you get everything off the internet, then Fox would be better.
