Results 1 to 6 of 6
    FMF brake for 650b conversion
    Thanks to all who mentioned these previously. While not as nice as my Avid Ultimates they get the job done for using 650's in a 26" rim brake frame or fork. Lots of adjustment and easy enough to set up. MMcG, you might be interested in these. I think they can still be found on ebay.
    Reputation: dRjOn's Avatar
    could use paul motobmx....
    'Calm Down'
    Reputation: GrumpyOne's Avatar
    Paul motobmx have enough pad adjustment, but the cable carrier is large and not high enough. So they didn't give enough clearance above the tire when I tried them. Looks like the FMF's may have slightly longer arms, which would give more tire clearance under the cable.
    jw
    Quote Originally Posted by dRjOn
    "And single-speeding 29ers are mountain biking's equivalent of Scientologists..." - Captain Dondo
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Cane Creek
    The Cane Creek brakes could also be made to work by machining a new brake slot. If you look closely at the pick the brakes are mounted onto a modular plate. If you were to make a new plate with a longer slot, I think they could work for 650B rims.
    http://www.canecreek.com/direct-curve-5-brakes.html
    Cheers,
    KP
    “Those that say it can’t be done should get out of the way of those doing it.”
    PacentiCycleDesign
    Reputation: MMcG's Avatar
    Jul 2003
    I have a set of these ordered up!
    Thanks again to steelbike and others for pointing out their adjustability capability!!!
    These have worked fine for me. I changed out the pads for Kool-Stops which are an improvement over the pads the brake came with. The FMF does not look very fancy but it's great for the adjustments.
    Hopefully I'll have a dedicated 650b frame in the spring running discs and then I'll use this on the front of an older Ibis with a 26" fork with a 650b.
    Quote Originally Posted by MMcG
