Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 25 of 119
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Fattest 650b tire?
    I'm running a 2.35" Nevegal right now, which I like, but have the room and desire to go fatter and taller.
    Any other options?
    I'm thinking about the Hans Dampf, but not sure if that is any bigger.
    Jun 2012
    The 2.35 Hans Dampf is probably the biggest 650b tire out right now. I think someone measured it to be almost 27.75"
    The HD is super sweet. Large volume, squishy soft nobs, awesome traction. No wonder many stores sell out of them, even at the $90 price. If you like loads of squishy traction, you won't be disappointed!
    We Ride In God's Country!
    Reputation: yetimeister514's Avatar
    believe the 2.35 NN is the tallest at 27-13/16 (27.87 in.) but the HD may be the widest available until we see the 2.4 Pacenti Mega-motos.
    my yeti is smarter than your honor student !
    Keep on Rockin...
    Nov 2003
    So, no doubt the HD is an awesome tire, but I'd still like some numbers on how wide and tall the beast is.
    Anyone care to take a ruler to the top of a knob from the ground up, and take the calipers to the widest part (be it casing or side knob)?
    As for the NN, this tire is on a heavy duty trail/AM bike, with wide rims, and tires are run at low pressure. I need something with more meat to prevent squirm.
    Actually, the Nev does a great job, tubeless and all, at an amazing price (sounds like a comercial, I know). But again, still looking for a step up in size and burliness.
    Thanks.
    Cutting transition knobs
    Cuting the transition knobs on the nevegals (front only) is a real eye opener......
    Keep on Rockin...
    Nov 2003
    Front...
    Quote Originally Posted by cptjack View Post
    I run the 29" Nev up front and really like it. No complaints at all. Might think about it though as I've done this with other tires in the past.
    Dec 2005
    HD 2,35" (61mm wide, diameter around 710mm) - on a ZTR Flow
    May 2005
    Quote Originally Posted by Kili@n View Post
    That sounds to tall for the HD from other posts I've seen measuring it more in the 704/5 range. Would be nice if it's really that tall which is right at the NN height of 27.875" or 708mm (I just measured yet again).
    The NN is advertised as a 2.35" but measures 2.3" just like a Neo Moto.
    Bigger meats are on the way but apparently the re-design and production of the Mega Moto 2.4" is moving to slow for Kirk's pleasure.
    2013 Banshee Spitfire V2 650b
    Aug 2010
    Anyone know the diameter of the Maxxis Ardent 27.5 x 2.25?
    How is the rolling resistance on the HD and Nobby Nic compared to the Nevegal?. Obviously they are going to roll better but by how much?
    Indy, In.
    Niner Rip 9
    Epic Expert Carbon 650b
    Karate Monkey SS
    Misfit DiSSent SS
    Sette Razzo
    Keep on Rockin...
    Nov 2003
    Close...
    Just measured the Nev 2.35 and it comes in extremely close to those measurements. Maybe a mm or two less on both height and width at most. That is to the side and top of the knobs.
    That is on a Flow EX.
    The side tread on the Nev protrudes significantly farther out than the sidewall. A good thing I'd say.
    I doubt I'd get much more volume out of the HD. Still might give it a shot if I find a good deal on one. But, for the price the Nev is hard to beat if grip is what you need most.
    NedwannaB
    Reputation: JMac47's Avatar
    Quick thread related hyjack
    Quote Originally Posted by GChambers View Post
    GC what mtb tires did you run in the back of the Reken before you urbanized it?
    Thanks in advance
    Wait,who did he tell you that?....
    Quote Originally Posted by JMac47 View Post
    Thanks in advance
    It's been an urban bike since I built it. It has a 1.5in Continental Tour Ride on it now. I'd guess there might be enough room for the Racing Ralph. When I get a chance I'll see if it fits.
    Indy, In.
    Niner Rip 9
    Karate Monkey SS
    Misfit DiSSent SS
    Sette Razzo
    May 2005
    Never run the Nevegal before but I feel the NN rolls better than a 2.3 Neo Moto which from all reports rolls a good bit better than a Nevegal. Hows that for scientific I'm very happy with the NN so far. Just gotta set it up tubless now.
    Quote Originally Posted by skidad View Post
    The HD rolls well, also. I can confirm it measures 705mm dia.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    One thing to remember comparing Kenda to Schwalbe is the majority of Schwable's tires are casing wide / tread narrow where Kenda is the other way around. Nevagals may compare in terms of overall width to the biggest Schwalbes but they're doing it with fat poor rolling tread. Myself, I'd rather have the extra air volume and faster rolling / smaller knobs of the schwalbe. The only Kenda tires of note that are measured casing width without over hanging tread are the Karma and Slant Six.
    I don't post to generate business for myself or make like I'm better than sliced bread
    LyN
    LyN is offline
    Reputation: LyN's Avatar
    Quote Originally Posted by Miker J View Post
    I have used the Nevegal for some time and moved to the 2.35 HD recently. Although the tires are not that different in size (the HD is about 2mm wider) the behaviour is night and day. The Nevegal is not too bad in dry conditions, but it wipes out on loose terrain and does not give confidence on the wet, specially while on the brakes.
    The HD is one of the grippiest tires I have ridden (my background is on High Rollers, Minions, Bontrager XR4, Stick-E Nevegals, etc.). Good in the dry, incredible in the wet, never wipes, amazing braking...
    Keep on Rockin...
    Nov 2003
    Thanks to all...
    Quote Originally Posted by LyN View Post
    No doubt the HD is a higher quality tire.
    I'm running the tire, rear, on a Flow EX, and like the "big rubber" feel you get on a DH tire with low air pressure and good sidewalls. While I know there is not a lot of love out there for the Nevegal it seems to give a great "cushion" feel without feeling flimsy in the sidewall even at very low pressure. Can I suspect at least the same out of the HD, if you follow my very subjective descriptions?
    The HD weighs in somewhat heavier, and is almost definitely a higher quality tire and as long as it is at least the same size I'm interested in giving it a shot.
    Pace or Trail version?
    Where to buy online?
    Thanks.
    Mar 2012
    Will you be mounting th NN"S on your A C BXC wheels? Interested very much, will be waiting for your report.
    NedwannaB
    Hmmm
    Thanks. Must have been thinking of someone elses build. I'll soon find out what works best as I'm going to order frame in next couple days along with an IRD Fire XC and a set of CrossMarks. Plus I can try my Quasi, 2.1 Neo and Nevegal. Doubt the Wolverine will fit.
    May 2005
    Quote Originally Posted by Ridezum View Post
    Nope, those have been put aside with the stock 2.2 Wolverine's. I've got the NN mounted on a Flow in the back and a TL28 in the front. Have about 50 miles on the tires and the shock on the Jamis puked oil all over itself (besides not getting full travel). Rock Shox replaced the shock under warranty, upgraded it to a RT3 and gave me the tune I wanted and I just got it back today. I guess there is a god after all. Anyway the tires are really nice, roll great, grip rocks good and seem to get decent traction even though I've got em at 30psi and they get bouncy like that. I've need to set em up tubeless and drop the pressure and they'll be better. I'm gonna run them awhile but I'm thinking a HD on the front and a NN on the back might be an awesome combo to try.
    LyN
    LyN is offline
    Thanks.
    I am using the HD at the front, so I do not have a precise feelibg of the cushioning of the tire, although I would say itnis very similar to the Nevegal.
    I am using the Trailstar compound which I would say feels grippier that Kenda's Stick-E. I bought the tire out of ebay because it was the first place where it was available, but now I would buy it from oje of the German shops that retail it for 36,90€, like bike-discount.de.
    Sep 2012
    Check this baby out Vee Rubber Trail Taker 650Bx2.4
    it's BIG! and it's out on ebay
