Thread: EC44/40 Headset
    Genius_rider
    EC44/40 Headset
    Hi,
    Has any one used the Cane Creek EC44/40 heaset to fit a tapered fork into a straight 1 1/8 designed headtube? If so, how does it work?
    This may be the answer to fit the 650b tappered forks to old style 1 1/8 designed bikes.
    From Russia with luv!
    Reputation: Triton Bikes's Avatar
    What's the ID (inner diameter) of your headtube? If it's 44mm, then you will be able to use tapered fork with EC44 headset.
    If it's a classic MTB 34mm ID headtube, then EC44 won't fit.
    And also, sterere won't fit.
    Dmitry
    PS: What's the frame? Take a picture and post here, this might help
    TritonBikes.com
    Titanium frames and components handbuilt in Russia
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    Sadly, your thinking is a bit skewed. The 44 designates the headtube ID. The 40 designates the crownrace of the fork. This lower headset cup is for a tapered fork and 44mm (ID) headtube.
    A traditional 1.125 headtube has an ID at 33.95mm which equals EC34, per the S.H.I.S .
    A Zero-Stack or Semi integrated headtube for 1.125 has an ID 43.95, and COULD accept the EC44 lowercup. if the headtube has a cup-depth ability of at least 12.5mm, where 15 is safer.
    Cane Creek has some great Tech Manuals located HERE
    Genius_rider
    It is a 2011 Specialized Camber with ZS 44 mm headset, so it seems the EC44 would work. I just read in this link
    I need your opinions on my fork
    that: "Nominal insertion bore depth for 44mm head-tubes is 9mm. EC44/40 requires an insertion depth of 15mm. Park Tool Reamer 788 should be used with the supplied spacer to reach the 15mm bore depth for EC44/40 Bottoms. " so I need to check if this reaming would be needed as well.
  1. Threaded headset to threadless headset conversion
    By op12389 in forum Bike and Frame discussion
    Last Post: 08-01-2013, 04:20 PM
  2. Replies: 6
    Last Post: 11-19-2012, 03:58 PM
  3. Replies: 2
    Last Post: 04-05-2012, 09:53 AM
  4. Cane Creek EC44/40 Head Tube adapter??
    By TRAIL CRANKER in forum Shocks and Suspension
    Last Post: 02-09-2012, 05:41 PM
  5. high stack EC44 lower cup?
    By DFYFZX in forum Shocks and Suspension
    Last Post: 12-18-2011, 08:45 PM
