Results 1 to 7 of 7
    Jan
    Jan is offline
    Cannondale Bad Boy with 650b?
    Do you think it's possible to fit a 650b wheel in a Bad Boy 700 or Ultra frame? Someone tried this? Here is a photo of a Bad Boy 700, it looks like it has good space between the chainstays:
    ride more
    looks maybe doable? give it a shot....
    Since it already handles 700c wheels, what specific reasons as to why it wouldn't it is more the question than if it's possible...Is there something about the frame or fork you have you think might be limiting?
    suum quique
    Reputation: thunderbolt413's Avatar
    Bad Boy Ultra uses the same frame as an F-seris Caffeine, so 650b will work. Not sure about Bad Boy 700.
    Jan
    Jan is offline
    Quote Originally Posted by Bikinfoolferlife
    The problem might be when using wide mtb tires. The tires on a Bad Boy 700 are not so wide.
    Full Tilt Boogie
    May 2005
    We have a customer who has an older one. On that bike, a 700x28c tire barely clears the fork crown. The rear has a lot of clearance, but the headshock fork does not. What's the fork look like on your's, as I doubt it would fit in her's.
    I sell bikes here. Check out the Blog here. Facebook.
    I run a 700X35 on my BB700. Thats about as big as you could go at 700.
    When I swap to the 26 wheels I can run a 2.1 Furious Fred with no probs.
    I been also considering swapping rims to a 650b if I could get a slightly bigger tire in,. So I am curious to see others results.
