Results 1 to 7 of 7
    artistic...
    Reputation: colker1's Avatar
    can someone post a pic of a Surly 1x1 fork running a 650B wheel?
    I need to know how much clearance it has and if i can go w/ a shorter fork.
    want: Ibis ti handlebar. suntour 31.8 front derr. bottom pull
    I'v got one in the shed with a 2.3 Neomoto and it has ample room. If no one posts before the morning i'll grab a picture for you.
    Reputation: in the trees's Avatar
    Mar 2005
    I have one as well (off the bike, just kicking around). I can place against a wheel to get an idea. Can't mount it to the fork, though - different axles.
    1x1 29er
    I'm currently riding my 1x1 w/ 29er studs so there's plenty of room for 650s. In fact I think the 1x1/Troll will shine even more w/ 650s. The 1x1 was designed for 26x2.7, which I think is bigger than any 650s currently offered, so it should feel completely normal.
    Pat
    artistic...
    my plan is to find a fork that let me use a front 650B wheel on a late 90s hardtail.. and not screw the handling.
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Quote Originally Posted by colker1 View Post
    As others have said, the 1x1 was practically made for 650b. That frame was designed to fit 26x2.1 tires (11.5" BB) up to 26x3" tires (13.0BB). Iirc, with 2.3" Neo's, there was lots of clearance in the fork and the frame and the BB ended up at 12.2".
    I have some rigid forks designed for 650b wheels here - with or without canti studs.
    Cheers,
    KP
    “Those that say it can’t be done should get out of the way of those doing it.”
    Pacenti Cycle Design
    EDIT: Resized...
