Results 1 to 6 of 6
    No Clue Crew
    Apr 2005
    Brown Santa delivers a suspension transformation
    Awesomized
    First shakedown run this morning on National.
    Wow.
    Reputation: AMjunky's Avatar
    Apr 2013
    Nice! So ... how does it compare to the craptastic 34 CTD?
    Did you go 150 or 160mm?
    Interested to know if they might have replaced a 2013 or 2014 Fox 34?
    No Clue Crew
    Apr 2005
    It replaced the stock 34 Float from the Bronson. I assume its a 2013.
    I went with the 160 Pike. Setup was dead simple. Damper wide open, rebound five clicks from full fast, 80 psi in air chamber (I'm about 185 before gear). 20-ish % sag and as you can see, nearly full travel today.
    Very plush, but not divey though midstroke. Exceptional small bump performance. I'm quite pleased. Previously, the rear suspension out-performed the front. Now the opposite is true.
    I do have a Bronson C on order that I'll be installing a CCDB Air on, so hopefully that'll balance out front to rear.
    No Clue Crew
    Apr 2005
    Forgot to mention, the Pike is more than 300 grams lighter.
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Quote Originally Posted by Blatant View Post
    Is the Pike truly 300g lighter than a Fox 34??
    Manufacturer weights for the 34 Float versus the Pike suggest 100g is closer.
    Rolling on 29", 650b, 8.3" and 23mm
  1. Brown Santa in JUNE????
    By pachaven in forum Santa Cruz
    Last Post: 06-27-2012, 08:51 PM
  2. Brown Santa came early
    By motobutane in forum North & South Carolina
    Last Post: 05-19-2011, 01:02 PM
  3. Brown Santa
    Last Post: 02-12-2011, 05:19 PM
  4. I love it when Brown Santa stops by,,,
    By zon in forum California - Norcal
    Last Post: 01-27-2011, 06:47 AM
  5. Brown Santa came today!!!!`
    By tsimbu in forum California - Norcal
    Last Post: 01-18-2011, 08:13 PM
