    araya rm20 tubeless??
    Anyone know if a tubeless conversion will work on these rims?
    sneezy1
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    No reason it shouldn't.
    www.derbyrims.com
    Reputation: derby's Avatar
    Without having flat UST compatible bead shoulders, the inside shape of this rim would be poor for a Stan's or other brand name tubeless conversion rimstrip. Any sidewall deflection such as from hard cornering or a rock pinch could easily burp air. However, with this rim a "ghetto" rim-strip (a split 24" inner-tube) will work OK, and the "ghetto" rimstrip is the best sealing and burp resistant rimstrip to use when converting clincher bead tires to tubeless with any rim.
    Read more from experts here: http://www.go-ride.com/Articles/ghetto_tubeless.html
    Attached Thumbnails Attached Thumbnails araya rm20 tubeless??-araya-rm-20.jpg
    Thats a great article derby...exactly what I'm looking for. Will try it at some stage using a homemade mix. Tires on there way now so should be up and running in a week or two.
    Thanks again
    sneezy1
