Results 1 to 8 of 8
    Feb 2005
    650b just front wheel
    I'm think to try to use a 650b front wheel matched to fox 34 160 and keep 26 wheel on the back,what issues about mixing 27,5 in front and 26 in rear?Can I use a 36 fork?
    Sail On!
    Reputation: Waterat Pat's Avatar
    You can do all of the above. Works well on most bikes as it only raises the front end 3/4".
    I rode an older Blur LT this way for 2 years.
    I have done this with a Moots YBB, a Trek 9.8 hardtail, and a Trek Top Fuel. Currently using this set up on a Spot Brand as well. I love it, and have had no issues at all with any of the different frames.
    www.derbyrims.com
    Reputation: derby's Avatar
    Where I live there is much climbing, and after swapping to a 650b front wheel with 26" rear, my bars felts too high in front and frame geometry became too slack for easy climbing. To cure a light front end feeling, lower the bars down to the level they were previously and bump your seat forward about 1/4 inch to regain the previous familiar balance forward over the wheels and cranks. If the more forward seat feels too short in reach to the bars go with a wider bar to re-gain reach and also add stability.
    WTB 29 allmountain wheels
    Nov 2012
    Quote Originally Posted by derby View Post
    I've been considering this. Thanks for the great info.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Try it. Did a similar mod....
    My Stumpy FSR 29er got a mod. I kept the front 29", and put a 650b out back.
    Absolutely love it for hard trail riding.
    My set up slackened the front end and dropped the bb a bit, which I totally dig. However, I run a fatter tire out back so the overall drop out back was minimal. I subscribe to the moto style set up for hard trail riding.
    I may even end up bumping the fork up another 10mm from 130 to 140 if the fork is able.
    Reputation: nyrdrms's Avatar
    I ran a 650B on the front of my top fuel for a couple years. I've heard some say this is about 70% of the realized change of rolling over objects easier. I just completed my full 650B Santa Cruz Blur XC and I can tell you the rear made more than 30% difference for me. I think it is more like 50/50. I ride sitting up more than a XC Pro (short stem, high bars, etc) so my weight is more rearward than many riders. Anyway, it is a step in the right direction. Go full out and get a Blur. My BB height came in at 13" (I used a zero stack lower cup/bearing which help tremendously as well as help the slack steering).
    You might consider running a 26" Trail King at the back, the wheel radius difference between that and a 2.3 Pacenti or a Schwalbe Hans Dampf being 5mm, so the head angle will hardy change.
