Page 1 of 2 1 2 LastLast
Results 1 to 25 of 36
Thread: 650b Hard Tail
    Reputation: TysonTy1's Avatar
    Mar 2011
    650b Hard Tail
    I want to try 650b XC in HT form for a while. I want an inexpensive frame, possibly something available used to build up/move parts to. I would like geometry built around a 120mm fork so I can use my current FOX shock.
    I really like the Lynskey Pro650 but they are way to proud to be asking 2k for a frame.
    Any suggestions for well built 650 frame that's not astronomical in price? Looking to spend around 500 (plus or minus a little) for the frame.
    Ventana El Bastardo 650B
    Spez Comp Carbon 29er
    Turner 5 Spot
    Giant NRS1
    Super V
    ProFlex
    IronHorse
    I'm toying with the idea of selling my Jamis Nemesis frame. It's a 19" and is in superb condition. Price sounds about right. PM if interested.
    Soma B-side is in that price range.
    Sixfifty Tomah is aluminum for 400 bucks.
    Also the Chinese carbon 650b frames?
    Mar 2011
    Quote Originally Posted by deuxdiesel View Post
    I'll do a little research on the Jamis and PM you,
    Turner 5 Spot
    Giant NRS1
    Super V
    ProFlex
    IronHorse
    Jamis Dragon 650b gets my vote. It is designed around a 120mm fork (their complete bike is offered with a White Brothers Loop 120mm fork). Reynolds 853 frame rides great. I'm lovin' mine.
    NedwannaB
    Reputation: JMac47's Avatar
    Not 120 Geo
    Quote Originally Posted by TysonTy1 View Post
    But this is getting more ride time then our sister bikes!!
    Wait,who did he tell you that?....
    The On One Whippet or 456 may be a good choice if you want carbon at your pricepoint.
    Mar 2011
    Steelbike - Soma looks to be designed for a 80mm fork (never like the looks of the Somas) The Tomah looks like a nice frame and would fit my current goods....have to look at this option a little more.
    HKMEUP - Ya the Dragon would be my #1 choice but I can't find a frame only option either new or used.
    JMAC - Can you give me more details...frame, fork, etc?
    Turner 5 Spot
    Giant NRS1
    Super V
    ProFlex
    IronHorse
    NedwannaB
    It's my several year old 26" Motobecane SuperFly (one of the first I played around with 650's on)100mm RL fork. I've also had them on a steel Voodoo Bizango. You can easily drop the fork down in travel on the one you have I would think. I'm running my Float 130 at 100 on the Ventana.
    Mar 2011
    What do you all think about the Voodoo Bokor.
    I have never run a bike that's SS/Geared. Will the Geared adapters hold up to XC pretty well vs typical vertical dropouts?
    Turner 5 Spot
    Giant NRS1
    Super V
    ProFlex
    IronHorse
    NedwannaB
    They should, those look like modified Paragon Sliders or is there a different set of dropouts for running it SS?
    My Kona Kula 2-9 had something similar to the ones on that VooDoo that worked ss/geared, but were more horizontal then semi-vertical.
    derp
    Reputation: danielsilva's Avatar
    Well i actually like my Cannondale Trail SL a lot, it's cheap and the max AC is 500mm so a 120mm is fine, it takes 2.25 tires with room and you can squeeze a 2.3 if mud isn't a problem. I was going to sell it but it works really well in 650b.
    2006 Cannondale Rush 650b
    2010 Cannondale Trail SL 650b
    2013 Norco Range Killer-B
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Quote Originally Posted by danielsilva View Post
    Would you happen to have pics of that rear 650B on that frame?
    Better to have and not need it, than to need it and not have it.
    derp
    The 2.25'' ? Nop just with a Quasi-Moto 2.0 but the difference isn't that much and before i put the quasi in there i tried the RaRa and it fitted without any problems. See this here -> http://forums.mtbr.com/650b/my-list-...ml#post9099823
    It has ~15mm to the seat tube and ~8mm each side from knobs to seat stay/chain stay, this with a Quasi and Crests.
    EDIT:
    Looking at Shiggy's numbers, you can fit a Neo-Moto 2.3 in there if you don't mid the mud clearance ( ~1mm to spare ) but a Navegal will probably rub the seat/chainstays.
    I'm eagerly waiting for the Vee Rubber Mission 2.3 to be available, looking at those knobs it will probably be an awesome rear tire for trail in this frame.
    PSE
    PSE is offline
    Reputation: PSE's Avatar
    Oct 2012
    You can use a 26incher aluminium Scott Scale (2012), they are not expensive and lots of used bikes can be found (Scale70-40).
    I have posted pictures of my Scale 60 in the 650 pricture thread. The bb sits at 12.1 inch, Actionsport wheels N-light, CL25 rims with Racing Ralphs 2.25's.
    650B Picture Thread
    Br Peter
    EDIT:
    Wow, that's lots of clearance. Looks like a Neo 2.1 would fit no problem
    Time to look for a 2nd hand Trail SL frame for sale...
    derp
    Quote Originally Posted by r1Gel View Post
    I was a bit surprised when I tried to fit the 2.25 RaRa in there and saw that it had lots of space. The frame is fairly light ( my Medium weighted 1550g ), the BB is 0.5" lower than the Flash so with the conversion you still end up with a low BB and you probably can buy one used for $200 or so.
    The only problem is that with >2010 you are stuck with Cannondale headsets.
    My Brain Hurts!
    Reputation: ProfGumby's Avatar
    Quote Originally Posted by JMac47 View Post
    650's fit on a Moto frame?
    Remember when we were kids and our Mom's said we could not play in the mud? I'm making up for it now!!
    NedwannaB
    Yes
    Quote Originally Posted by ProfGumby View Post
    Room even with WTB 2.2 Wolverines. Bike is front der equipped now too with no clearence issues.
    Also had them on my steel VooDoo Bizango as well.
    Dissolved member
    Reputation: StiHacka's Avatar
    Feb 2012
    Despite On one's asinine opinion about 650b, I still think 456C is a pretty good choice. It has enough clearance even for the largest 650b tires.
    My Brain Hurts!
    What year HT is that Moto in the pic above? That's interesting! I emailed them about when they'd offer a 650, and here is the beginning of that response from Chris @ Bikes Direct...
    "Hello,
    We do not expect a 650b bike until 2014, there is not enough clearance on any 26er to fit 650's."
    I wonder if specs changed since 2011?
    NedwannaB
    Got it new from BD around '03 I can't remember exactly.
    Nov 2012
    Apparently Kona is coming out with a 650B Explosif steel hardtail
    that will also be available as a frame.
    Might be a good alternative to the Jamis Dragon.
    May 2005
    Quote Originally Posted by lookiel View Post
    Frame only for $500. No hard geometry #'s yet so I've asked for those.
    From Kona
    "The frame will be raw steel with a phosphate dip and clearcoat over the top.The specs will be similar to the Honzo. Rear wheel has sliders and is 135x10. 44mm headtube drawn around the external lower cup so you can run a tapered fork".
    2013 Banshee Spitfire V2 650b
    Quote Originally Posted by skidad View Post
    From Kona
    this sounds promising!
