Results 1 to 8 of 8
    May 2013
    650b compatible 26" fs with easily removable swingarm?
    Looking for a lightweight full suspension 26" bike that will accept 650b wheels...but I also need the rear triangle (or swingarm) to be easily and quickly removable because I plan to pack the bike (and the 26" wheels) into a large suitcase for when I'm flying, without having to pay crazy airline bicycle fees. I want 650b wheels for use when I'm home, but they'll be too big for the luggage. A 26x26x10" bag should do it while staying within the allowed checked bag sizing. I was looking at some newTrek fs bikes today, but the crank has to be removed to get the swingarm bolts out. Any suggestions?
    NedwannaB
    Reputation: JMac47's Avatar
    Late model Superlight
    Quote Originally Posted by crgf1k View Post
    Pretty sure depending on what crank setup you run. That's what I'm hoping to be able to do with a 1x setup.
    Name:  650 superlight.jpg
    *Disclaimer-Pix credit to tommyrod. He is selling this almost new frame/fork actually. Size Large I believe.
    Wait,who did he tell you that?....
    May 2013
    I see what you mean...a triple sprocket setup might prevent those bolts from being removed. I wonder how long those bolts are.
    Dec 2010
    I have a Carbine with XT cranks,both come off easy in minutes!
    NedwannaB
    Maybe 2.75-3" max I would think. If they come off from the opp side then no prob! May drop by lbs today for some weekend riding supplies I can look at a '13 (26" version 3.3 has tapered head tube change only I think) they have there. But I'll know for sure Mon-Tues when my frame arrives.
    May 2013
    Quote Originally Posted by techfersure View Post
    Ya looking at a picture of a Carbine Intense, it looks like the rear triangle could be removed while the cranks, upper & lower links and shock could all stay in place(?)
    Reputation: slo_rider's Avatar
    i dissembled my '03 heckler (medium frame w/ ~17" ST and ~22.7" ETT) for packing into standard sized luggage so as to avoid extra fees charged by airlines for bikes.
    i separated the swingarm from the frame, and packed everything except fork and bars in one of those S&S Coupler hard shell suitcases. i packed the fork and bars (along w/ my riding gear) in a 30" rolling duffel bag.
    that was years before riders started converting 26" bikes to 27.5" wheels, but the S&S Coupler suitcase was designed to fit 700 road wheels (622mm rim diameter) so it should fit the 27.5"/650B rims (584mm diameter) without any problems.
    i don't remember if i had to remove crankset from the frame to remove the swingarm.
    and of course, ymmv depending on which SC single pivot model/year/size frame you choose for your conversion.
    NedwannaB
    Looks doable
    No problem getting pivot bolt out to me.
  1. 26" frames that are 650b compatible?
    By tittiot in forum 27.5 - 650b
    Last Post: 06-29-2013, 03:58 PM
  2. Easily install/removable hitch rack?
    By TManiac in forum Car & Biker
    Last Post: 05-14-2013, 05:33 PM
  3. 26" 34 Talas 160 CTD 650b compatible
    By Nate3510 in forum 27.5 - 650b
    Last Post: 03-24-2013, 09:48 PM
  4. 650b compatible 26" forks
    By speederson in forum 27.5 - 650b
    Last Post: 04-05-2012, 09:53 PM
  5. 5" Trail and 6" AM frames (650B compatible)
    By Morpheous in forum 27.5 - 650b
    Last Post: 02-17-2012, 12:46 PM
