Results 1 to 9 of 9
    Reputation: miggy's Avatar
    Nov 2008
    27.5 pike compatability
    Future proofing a fork purchase!? Thinking about putting a 27.5 160mm pike on my pivot mach 5.7 26" frame, is it easy to put a spacer in making them 150mm and still run 26" wheels? Or will it make a raked out head angle and get all complicated?? Is anyone buying 26" forks anymore?!?
    Rolling & Tumbling
    Mar 2012
    Can't swap them out very easily. The damper is different for each travel fork. There's a few people that have done it, but it also sounds like its not reversible.
    Nov 2008
    Quote Originally Posted by jselwyn View Post
    I guess if I got the 150mm it would be all good
    Rolling & Tumbling
    insert sarcasm here
    Reputation: gbug's Avatar
    Why not just put the 160mm 27.5 on your Pivot? It will only slacken your head angle approx 0.5 degrees I believe. If you hate it you still have the option of dropping in a 150mm damper cartridge.
    I'm always looking for new people to ride with. If you are on the Front Range, shoot me a PM and let's go ridin'.
    I'm in the same boat. Thinking of getting the 150 to run on an HDR in 160/26 mode and rbuilding my wheels with 27.5 rims once ibis does a 150 mm shock version.
    Reputation: killjoyken's Avatar
    The damper is the same for all Pikes. To change to a different travel you only need to swap the air spring shaft which is about $40. You can even lower it to 140mm.
    Santa Cruz Bronson - Santa Cruz Highball - Ibis Mojo HD3 on order!
    Your thinking is sound, Miggy. The 650b Pike has a relatively short 42mm offset, which works well with the wheel size and angles your bike was designed around. You will be slackening things out a bit so stay with the 150mm. It will be about the same as putting a 160mm/26" fork on.
    DLd
    DLd is offline
    Feb 2005
    Quote Originally Posted by killjoyken View Post
    Do you have any more details on that? I've only seen the 140mm kit for the 29'er, can you just cut down the air spring shaft, or maybe use the 29'er 140mm shaft? I would like to have a 27.5 Pike at 140mm for the same application, a Pivot 5.7, I figure a 27.5 at 140mm should be about the same geometry as the 150mm fork with a 26" wheel. I'd prefer not to go slacker, but would like the stiffer chassis and better damping of the pike relative to a Revelation at 140mm. It's only about a 100gram weight penalty, no big deal.
    "Great things are not accomplished by those who yield to trends and fads and popular opinion."-Jack Kerouac
    Someone started a thread in the Santa Cruz section that covers lowering a Pike:
    Reducing a Pike 150>140 and a 160>150 tech thread
  1. Pike on ASR 5
    By charliemort in forum Yeti
    Last Post: 01-30-2014, 06:42 AM
  2. RS Pike VS Fox 36
    By murrdogg11 in forum Shocks and Suspension
    Last Post: 09-07-2013, 01:21 PM
  3. Replies: 12
    Last Post: 04-25-2013, 05:07 PM
  4. Comparability between DHX and Vivid springs?
    By scepticshock in forum Shocks and Suspension
    Last Post: 03-28-2013, 12:35 AM
  5. PIKE 351 is wet...
    By chelboed in forum Shocks and Suspension
    Last Post: 09-07-2012, 05:23 PM
