Results 1 to 24 of 24
    May 2012
    20mm thru axle 650b forks?
    Hello all. The official fork thread is way too confusing to search. I am looking for a 20mm thru axle fork with 150 to 160mm travel that is 650b compatible. I am looking for a non tapered 1 1/8" steer tube. Does anybody know of a fork that is confirmed to work with 650b with the above requirements?
    Thanks.
    Fox will work.
    Reputation: rsullivan's Avatar
    2011 X Fusion Vengeance.....enough said. Running one on my SC Nickel.... lowered to 130mm for now though....
    Trying to painfully relive some of youthful adventures!!
    www.EpicCyclist.com
    Reputation: team_wee's Avatar
    Mar 2006
    fox 36
    May 2012
    Quote Originally Posted by rsullivan View Post
    Thanks for the suggestion, I hope you don't mind me asking a couple questions about the x fusion vengeance.
    I have heard that you can adjust the travel on these forks.... So how hard is it to change the travel from 170 to 130 like you have it?
    Does the axle to crown distance decrease when you lower the travel or does it just limit how far down the tubes can slide in to the stanchions?
    How much clearance do you have between the tire and the arch?
    Thanks for your help.
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    Quote Originally Posted by DimitrisCSD View Post
    Fox will work.
    Yep, I put a 27.5 on my 36 Talas no problems.
    I believe a RS Lyrik meets your criteria also.
    Quote Originally Posted by dhelm72 View Post
    It was a quick 15min job to lower the travel. It lowers the fork into the legs so only 130mm of travel is available. About a 1/2" - 5/8" clearance between tire and arch
    Using a lyrick with no problems.
    Reputation: Morpheous's Avatar
    Mar 2006
    I have one for sale, Fox Float Talas 36, 160mm-130-100 20mm thru, been running 650 on it for two years. PM me if interested.
    Fox 36 Float TALAS 160mm-130mm-100mm fork - Buy and Sell and Review Mountain Bikes and Accessories
    Quote Originally Posted by morpheus1029 View Post
    What size tire ? I tried a Nevegal 2.35 on a 2011 Lyrik and there was only about 1mm of clearance.
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    WB Fluid 650b, replaced by Loop which has 15mm TA
    New Fluids available here:
    http://sixfiftybikes.wordpress.com/2...uid-20mm-fork/
    Old enough to know better. And old enough not to care. Best age to be.
    Quote Originally Posted by keen View Post
    running a neo 2.3
    dwt
    dwt is offline
    running a neo 2.3
    I run Neo 2.3 with my Fluid20mm thru axle 650b forks?-imageuploadedbytapatalk1344968417.759986.jpg. Easy fit.
    a lot of forks that work.
    Fox 36, RS Lyrik, Totem, 2012 Sektor and revelation (I didnt try crown clearance for last 2)
    2013 Sektor seems will not fit, I measured the 15mm version the axle to arch, its just 350mm, so it will not clear a neo-moto 2.3.......
    This is what I have been looking for... so the Nevagal lyrik/domain is not a good combo, Right?
    May 2012
    Drummercat, you sure have done some experimenting! Thanks for everyone's help thus far. Does anybody know if the 2.35 nevegal or a 2.3 neo moto is taller? I am running a 2.35 nevegal up front now. I have a white brothers fluid 650b fork and I'm looking for a bit more travel.
    nevegal is taller as I remember. someone say 2.35 nev will not clear a 2011 /12 Giant Reign Rear, and the 2.35 neo-moto clears with 3-4mm clearance.
    according to shiggy`s tire spec, nev is 4mm taller in dia. (2mm taller axle to top)
    650B / 27.5" Tire Specs
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Manitou Nixon 160 with a 2.25 RR with tons of room to spare.
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
    www.derbyrims.com
    Reputation: derby's Avatar
    Can't imagine that any new 20mm axle fork would not clear all the 650b tires currently available. Marzocchi forks used to fail, but resent reports I've seen here is that now they do clear.
    Paper or plastic?
    Reputation: zorg's Avatar
    What about a 2011 Revelation RLT (20mm axle)?
    Faster is not always better, but it's always more fun
    Quote Originally Posted by zorg View Post
    That's what I'm running, which is barely adequate for a Neo Moto 2.3.... to be able to run a 2.35 Nevegal I had to file the arch out a little bit, which is why I didn't recommend it. It's a great fork though.... perfect balance of weight, travel, stiff, plush, adjustable yada yada. I'm looking forward to getting a proper 650b version of it some day.
    JR
    the fox 36 talas RC2 works very well (been stated many times before)
    better bike with the 650B on the front
    Attached Thumbnails Attached Thumbnails 20mm thru axle 650b forks?-img_0023.jpg
    bump and grind
    Reputation: cobym2's Avatar
    Apr 2005
    practically any 20mm thruaxle fork for 26ers will work, except some marzocchis, since they have that "M" casting on the arch. I've tried fox 36 van and float, lyrik and RS Pike. They clear well.
